Error during compiling with typedef
Hello everyone,
I'm currently building a dashboard for Simracing Rigs with the help of some online source code and adjusting/adding more functions to my liking.
Now an issue came up when I switched from an Arduino Uno to a Micro Pro.
typedef enum {
  RPM,
  RPM_TICK,
  SPEED,
  GEAR,
  TYRE_STATUS,
  TYRE_TEMP,
  TIME,
  INIT,
  FUEL,
  LAP,
  CURRENT_TIME,
  FUEL_TICK,
  CURRENT_POSITION,
  PERFORMANCE_METER,
} MessageType;
The code above compiles perfectly fine on the Uno and also works in conjunction with the rest.
However, since I try to move the project to the smaller Micro Pro, i get these error messages:
  • error: expected identifier before numeric constant
  • SPEED,
  • error: expected '}' before numeric constant
  • error: expected unqualified-id before numeric constant
  • error: expected declaration before '}' token
  • } MessageType;
Commenting the line "SPEED," resolves the issue, but leads to the problem that I cant use further methods later on in the code, since it wasn't declared above.
Now I'm wondering why this is only happening to the Micro Pro. I couldn't find any sources online relating to a SPEED constant, but maybe someone here knows.
The error also occured when I tried creating a new sketch with nothing but this
typedef enum {
  SPEED,
} MessageType;
I didn't try a different Micro Pro yet, but will do so by Tuesday.
Regards.
It seems likely that SPEED is already #defined. As an experiment, take it out of the enum so that you are not defining it and try printing it in setup(). What is printed ?
Thank you for the reply,
it actually prints "3"
So it is already defined somewhere. Just change the name of your version
Thank you for your suggestion, I could verify its working with a different name now.
