Error during uploading firmware to Printrboard Rev D
I am trying to upload firmware to my new printrboard but keep getting an error as given below -
Arduino: 1.8.1 (Windows 10), TD: 1.36, Board: "[BootloaderCDC]Teensylu/Printrboard"
Warning: Board teensy:avr:utteensylu doesn't define a 'build.board' preference. Auto-set to: AVR_UTTEENSYLU
Warning: Board teensy:avr:teensypp2 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSYPP2
Warning: Board teensy:avr:cdcteensylu doesn't define a 'build.board' preference. Auto-set to: AVR_CDCTEENSYLU
Warning: Board teensy:avr:usbtiny1286 doesn't define a 'build.board' preference. Auto-set to: AVR_USBTINY1286
Warning: Board teensy:avr:teensy1 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSY1
Warning: Board teensy:avr:teensypp1 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSYPP1
Warning: Board teensy:avr:teensy2 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSY2
Warning: Board teensy:avr:avr1091286 doesn't define a 'build.board' preference. Auto-set to: AVR_AVR1091286
Build options changed, rebuilding all
exec: "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/": file does not exist
Error compiling for board [BootloaderCDC]Teensylu/Printrboard.
I also copied the files from 'at90usb1286txt' to c drive arduino folder after changing line no 176 to teensy but not able to figure out the reason behind the error.
I followed the steps shown in video - QUBD One/Two-Up Tutorial - Installing Firmware - YouTube
Can somebody help.....
(deleted)
Can I run both 1.8.1 & 1.0.5 simultaneously?
Yes, just use the "Windows" download link instead of "Windows Installer". With the non-installer version you can have as many copies of the Arduino IDE as you like.
I downloaded the 1.0.5.r2 & compiled the marlin (version - RCBugfix), below are the errors......
In file included from /Marlin.h:36,
from blinkm.cpp:28:
/MarlinConfig.h:37:21: error: Arduino.h: No such file or directory
In file included from /MarlinConfig.h:39,
from /Marlin.h:36,
from blinkm.cpp:28:
/SanityCheck.h:33:4: error: #error "Marlin requires C++11 support (gcc >= 4.7, Arduino IDE >= 1.6.8). Please upgrade your toolchain."
/SanityCheck.h:576:37: error: missing binary operator before token "("
/SanityCheck.h:578:40: error: missing binary operator before token "("
/SanityCheck.h:580:40: error: missing binary operator before token "("
/SanityCheck.h:582:39: error: missing binary operator before token "("
In file included from blinkm.cpp:28:
/Marlin.h:44:30: error: HardwareSerial.h: No such file or directory
/Marlin.h:55:21: error: WString.h: No such file or directory
/Marlin.h: In function 'void serialprintPGM(const char*)':
Marlin.h:106: error: 'Serial' was not declared in this scope
/Marlin.h: In function 'void refresh_cmd_timeout()':
Marlin.h:249: error: 'millis' was not declared in this scope
I've also attached marlin file in the post.
Marlin_bug_fix_26Mar17.zip (707 KB)
Arduino IDE 1.0.5 is definitely not going to work with the version of Marlin you're using and really that IDE version is so outdated. Much better to forget about Arduino IDE 1.0.5 and see if we can solve your problem using a modern version of the Arduino IDE. Please do this:
  • Start Arduino IDE 1.8.1
  • Open the firmware file
  • File > Preferences > Show verbose output during: > compilation (check) > OK
  • Sketch > Upload
  • After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a reply on this thread click the code tags button on the toolbar (</> button).
  • Paste the error messages.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
Below are the errors........I divided the message into three parts because it overshoots 9000 char limit. Below is the first part.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Gaurav\Documents\Arduino\libraries -fqbn=teensy:avr:cdcteensylu -ide-version=10801 -build-path C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311 -warnings=none -prefs=build.warn_data_percentage=75 -verbose F:\extra\Marlin\Marlin_bug_fix_26Mar17\Marlin-RCBugFix\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Gaurav\Documents\Arduino\libraries -fqbn=teensy:avr:cdcteensylu -ide-version=10801 -build-path C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311 -warnings=none -prefs=build.warn_data_percentage=75 -verbose F:\extra\Marlin\Marlin_bug_fix_26Mar17\Marlin-RCBugFix\Marlin\Marlin.ino
Using board 'cdcteensylu' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
second part..
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\Marlin.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\M100_Free_Mem_Chk.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\MarlinSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\Marlin_main.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\Sd2Card.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\SdBaseFile.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\SdFatUtil.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\SdFile.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\SdVolume.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\blinkm.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\cardreader.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\configuration_store.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\dac_mcp4728.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\digipot_mcp4451.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\endstops.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\mesh_bed_leveling.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\nozzle.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\planner.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\planner_bezier.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\printcounter.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\qr_solve.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\servo.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\stepper.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\stepper_dac.cpp" -o "nul"
Last part....
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\stepper_indirection.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\stopwatch.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\temperature.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\twibus.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\ultralcd.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\utility.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\vector_3.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\watchdog.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" -E -CC -x c++ -w      -DARDUINO=10801 -DF_CPU= -D -DLAYOUT_ "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\sketch\Marlin.ino.cpp" -o "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_497311\preproc\ctags_target_for_gcc_minus_e.cpp"
exec: "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/": file does not exist
Well I remember now that this came up before:
https://forum.arduino.cc/index.php?topic=418025.0
but I don't like installing teensyduino because it messes with my Arduino IDE so I ended up getting stalled by not being able to test changes. Basically the problem is the "Teensyduino Modified Config Files" files you downloaded are made for an old version of Teensyduino. So when you copied those files over the stock Teensyduino files there are missing configurations, which causes the error. So those files are made for old Teensyduino and thus old Arduino IDE but the Marlin version you're trying to use is made for the new Arduino version. If you want to follow the video instructions you need to use the old version of Marlin that the video was made for. If you want to use the new version of Marlin then you will need to uninstall and then reinstall Teensyduino to undo what you broke and then figure out how to update the "Teensyduino Modified Config Files" to be compatible with the new version of Teensyduino before you copy them over. I can't seem to find the unmodified Teensyduino files (boards.txt, boards.txt.nopjrc, programmers.txt, platform.txt). If you will attach those files I'll take a look and see if I can spot what I missed before.
teensyduino files are attached.......
at90usb1286txt.zip (4.99 KB)
No, I need the unmodified ones from a stock installation of Teensyduino before you replaced them with the modified files.
Unmodified files are attached & downloaded from link given below....
http://blog.lincomatic.com/wp-content...
at90usb1286txt (1).zip (4.9 KB)
Hi Pert,
You got any feedback........
pert:
I can't help you unless you make the effort to provide me the files I need. I'm not going to install Teensyduino.
Let me understand your requirement correctly.
You need installation files of teensyduino........right?
Attached are teensyduino files before modification........
  1. Boards
  2. Keywords
  3. Platform
teensy.zip (9.69 KB)
OK, give the attached boards.txt a try. Just replace the one in the Teensyduino installation folder with this one.
boards.txt (48 KB)
Below are the errors after replacing with new file................
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Gaurav\Documents\Arduino\libraries -fqbn=teensy:avr:cdcteensylu -ide-version=10801 -build-path C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168 -warnings=none -prefs=build.warn_data_percentage=75 -verbose F:\extra\Marlin\Marlin_bug_fix_26Mar17\Marlin-RCBugFix\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Gaurav\Documents\Arduino\libraries -fqbn=teensy:avr:cdcteensylu -ide-version=10801 -build-path C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168 -warnings=none -prefs=build.warn_data_percentage=75 -verbose F:\extra\Marlin\Marlin_bug_fix_26Mar17\Marlin-RCBugFix\Marlin\Marlin.ino
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\Marlin.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\M100_Free_Mem_Chk.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\MarlinSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\Marlin_main.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\Sd2Card.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\SdBaseFile.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\SdFatUtil.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\SdFile.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\SdVolume.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\blinkm.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\cardreader.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\configuration_store.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\dac_mcp4728.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\digipot_mcp4451.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\endstops.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\mesh_bed_leveling.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\nozzle.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\planner.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\planner_bezier.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\printcounter.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\qr_solve.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\servo.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\stepper.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\stepper_dac.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\stepper_indirection.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\stopwatch.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\temperature.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\twibus.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\ultralcd.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\utility.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\vector_3.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/avr/bin/avr-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -fno-exceptions -felide-constructors -std=c++0x -mmcu=at90usb1286 -DTEENSYDUINO=136 -DARDUINO_ARCH_AVR -DARDUINO=10801 -DF_CPU= -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy" "C:\Users\Gaurav\AppData\Local\Temp\arduino_build_522168\sketch\watchdog.cpp" -o "nul"
