Hello,
I am trying to send string between two arduino using NRF24L01 and the tmrh20 library. So i use the code from Dynamic_payload_example and simplify it but it still not working. I know my wiring is correct as it work with static payload.
So the code to send the data is :
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(8,9);
// sets the role of this unit in hardware. Connect to GND to be the 'pong' receiver
// Leave open to be the 'ping' transmitter
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
const int min_payload_size = 4;
void setup(void)
Serial.println(F("RF24/examples/pingpair_dyn/"));
// Setup and configure rf radio
radio.begin();
// enable dynamic payloads
radio.enableDynamicPayloads();
// optionally, increase the delay between retries & # of retries
radio.openWritingPipe(pipes[0]);
radio.printDetails();
void loop(void)
{Serial.print(F("Now sending length "));
static char send_payload[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ789012";
radio.write( send_payload, min_payload_size );
And the receiver is :
// ON the NodeMcu the CE ies connecte to D2 which mean GPIO4 for the arduino CSN is on D8 which is 15 for the arduino
#include <SPI.h>
#include "RF24.h"
RF24 radio(4,15);
char receive_payload[min_payload_size];
radio.begin();
radio.openReadingPipe(1,pipes[0]);
radio.startListening();
while ( radio.available() )
// Fetch the payload, and see if this was the last one.
uint8_t len = radio.getDynamicPayloadSize();
// If a corrupt dynamic payload is received, it will be flushed
if(!len){
continue;
radio.read( receive_payload, len );
// Put a zero at the end for easy printing
receive_payload[len] = 0;
// Spew it
Serial.print(F("Got response size="));
Serial.print(len);
Serial.print(F(" value="));
Serial.println(receive_payload);
// First, stop listening so we can talk
radio.stopListening();
// Send the final one back.
But the receiver doesn't receive anything it just print the radio details. Any idea ?
