Error en codigo de reloj
hola soy Santiago y yo tengo un problema con el código de mi reloj con un lcd; aquí dejo el código,
porque yo no se como solucionar el problema
#include <Wire.h>
LiquidCrystal_I2C lcd( 0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE );
//SE AGREGA LIBRERÍAS PARA RTC
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(4,7,2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
void setup ()
    Serial.begin(57600);
    Serial.print("compiled: ");
    Serial.print(__DATE__);
    Serial.println(__TIME__);
    Rtc.Begin();
    RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
    printDateTime(compiled);
    if (!Rtc.IsDateTimeValid())
        // Common Causes:
        //    1) first time you ran and the device wasn't running yet
        //    2) the battery on the device is low or even missing
        Serial.println("RTC lost confidence in the DateTime!");
        Rtc.SetDateTime(compiled);
    if (Rtc.GetIsWriteProtected())
        Serial.println("RTC was write protected, enabling writing now");
        Rtc.SetIsWriteProtected(false);
    if (!Rtc.GetIsRunning())
        Serial.println("RTC was not actively running, starting now");
        Rtc.SetIsRunning(true);
    RtcDateTime now = Rtc.GetDateTime();
    if (now < compiled)
        Serial.println("RTC is older than compile time!  (Updating DateTime)");
    else if (now > compiled)
        Serial.println("RTC is newer than compile time. (this is expected)");
    else if (now == compiled)
        Serial.println("RTC is the same as compile time! (not expected but all is fine)");
void loop ()
    printDateTime(now);
    if (!now.IsValid())
        // Common Causes:
        //    1) the battery on the device is low or even missing and the power line was disconnected
    delay(10000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
    char datestring[20];
    snprintf_P(datestring,
            countof(datestring),
            PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
    Serial.print(datestring);
//SE CREA Y CONFIGURA OBJETO PARA MANEJAR RTC
ThreeWire myWire(4,5,2); //PINES IO, SCLK, CE -> DE RTC DS1302
void setup () {
  // SE INICAR MONITOR SERIE E IMPRIME FECHA Y HORA
    Serial.print("CONFIGURACIÓN INICIAL ");
    lcd.begin(16,2); //SE INICIARLIZA LCD
    Rtc.Begin();// SE INICIALIZA RTC
    RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);//SE CONFIGURA FECHA Y HORA ACTUAL
    printDateTime(compiled); //SE IMPRIME FECHA Y HORA
void loop () {
  //SE OBTENIE FECHA Y HORA ACTUAL Y SE ACTUALIZA
    printDateTime(now);
    if (!now.IsValid()){
        Serial.println("ERROR EN FECHA Y HORA");
    delay(1000);RETARDO DE 1 SEGUNDO
//FUNCION PARA IMPRIMIR FECHA Y HORA CON FORMATO ADECUADO
void printDateTime(const RtcDateTime& dt){
            PSTR("%02u/%02u/%04u %02u:%02u:%02u"),//SE CONFURA FORMATO DE FECHA Y HORA
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
    //SE IMPRIME LA FECHA Y HORA EN LCD
    lcd.setCursor(0,0);
    lcd.print("DATE  ");
    lcd.print(dt.Month());
    lcd.print("/");
    lcd.print(dt.Day());
    lcd.print("/");
    lcd.print(dt.Year());
    lcd.setCursor(0,14);
    lcd.print(" ");
    lcd.setCursor(0,1);
    lcd.print("TIME  ");
    lcd.print(dt.Hour());
    lcd.print(":");
    lcd.print(dt.Minute());
    lcd.print(":");
    lcd.print(dt.Second());
    Serial.print(datestring);//SE IMPRIME EN MONITOR SERIE
¿Y cuál es el problema y/o error?
Edito: Ya lo vi, tienes repetido setup(), loop() y algunas cosas más.
El tema entonces debería ser "Necesito unir éstos 2 códigos para hacer un reloj y no se resolverlo."
Se resuelve con orden.
  1. Todos las librerías sin repetir.
  2. Las variables, objetos y contantes sin repetir.
  3. Un setup() que contemple lo necesario a ambos códigos.
  4. Un loop que tenga la misma consideración que el punto 3)
  5. los procedimientos o rutinas y las funciones que sean necesarias.
Con estos 5 puntos resuelves tu problema sin ayuda del vecino.
