Error: error opening datalog.txt
I am trying to save accelerometer data to a sd card, but when I run the code, it spits out crazy values and gives me the error: “error opening datalog.txt”
I am using the teensy 3.2 and adxl375 high g accelerometer
PLEASE HELP!!
//Add the SPI library so we can communicate with the ADXL375 sensor
#include <SPI.h>
#include <SD.h>
int CS = 15;
#define  DEVID   0x00  //Device ID Register
#define THRESH_TAP  0x1D  //Tap Threshold
#define OFSX    0x1E  //X-axis offset
#define OFSY    0x1F  //Y-axis offset
#define OFSZ    0x20  //Z-axis offset
#define DURATION  0x21  //Tap Duration
#define LATENT    0x22  //Tap latency
#define WINDOW    0x23  //Tap window
#define THRESH_ACT  0x24  //Activity Threshold
#define THRESH_INACT  0x25  //Inactivity Threshold
#define TIME_INACT  0x26  //Inactivity Time
#define ACT_INACT_CTL 0x27  //Axis enable control for activity and inactivity detection
#define THRESH_FF 0x28  //free-fall threshold
#define TIME_FF   0x29  //Free-Fall Time
#define TAP_AXES  0x2A  //Axis control for tap/double tap
#define ACT_TAP_STATUS  0x2B  //Source of tap/double tap
#define BW_RATE   0x2C  //Data rate and power mode control
#define POWER_CTL 0x2D  //Power Control Register
#define INT_ENABLE  0x2E  //Interrupt Enable Control
#define INT_MAP   0x2F  //Interrupt Mapping Control
#define INT_SOURCE  0x30  //Source of interrupts
#define DATA_FORMAT 0x31  //Data format control
#define DATAX0    0x32  //X-Axis Data 0
#define DATAX1    0x33  //X-Axis Data 1
#define DATAY0    0x34  //Y-Axis Data 0
#define DATAY1    0x35  //Y-Axis Data 1
#define DATAZ0    0x36  //Z-Axis Data 0
#define DATAZ1    0x37  //Z-Axis Data 1
#define FIFO_CTL  0x38  //FIFO control
#define FIFO_STATUS 0x39  //FIFO status
const int chipSelect = 15;
  //UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
  //SPI.setMOSI(7);  // Audio shield has MOSI on pin 7
  //SPI.setSCK(14);  // Audio shield has SCK on pin 14
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  pinMode(chipSelect, OUTPUT);
  digitalWrite(chipSelect, HIGH);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  //Initiate an SPI communication instance.
  SPI.begin();
  //Configure the SPI connection for the ADXL375.
  SPI.setDataMode(SPI_MODE3);
  //Create a serial connection to display the data on the terminal.
  //Set up the Chip Select pin to be an output from the Arduino.
  pinMode(CS, OUTPUT);
  //Before communication starts, the Chip Select pin needs to be set high.
  digitalWrite(CS, HIGH);
  //Put the ADXL375 into +/- 2G range by writing the value 0x00 to the DATA_FORMAT register.
  writeRegister(DATA_FORMAT, 0x00);
  // disable interrupts
  writeRegister(INT_ENABLE, 0x00);
  //Put the ADXL375 into Measurement Mode by writing 0x08 to the POWER_CTL register.
  writeRegister(POWER_CTL, 0x08); //Measurement mode
  readRegister(INT_SOURCE, 1, values); //Clear the interrupts from the INT_SOURCE register.
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
    readRegister(DATAX0, 6, values);
  //The ADXL375 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
  //The X value is stored in values[0] and values[1].
  x = tenBitTwosComplementToDecimal((((uint16_t)values[1]<<8)|(uint16_t)values[0]) & 1023);
  //The Y value is stored in values[2] and values[3].
  y = tenBitTwosComplementToDecimal((((uint16_t)values[3]<<8)|(uint16_t)values[2]) & 1023);
  //The Z value is stored in values[4] and values[5].
  z = tenBitTwosComplementToDecimal((((uint16_t)values[5]<<8)|(uint16_t)values[4]) & 1023);
  //Convert the accelerometer value to G's.
  //With 10 bits measuring over a +/-4g range we can find how to convert by using the equation:
  // Gs = Measurement Value * (G-range/(2^10)) or Gs = Measurement Value * (8/1024)
  xg = x * 0.00390625;
  yg = y * 0.00390625;
  zg = z * 0.00390625;
      Serial.print(xg,2);
      Serial.print("g,");
      Serial.print(yg,2);
      Serial.print("g,");
      Serial.print(zg,2);
      Serial.println("g");
  /*for(unsigned char i = 0; i < 6; i++)
    Serial.print(values[i]);
    Serial.print(",");
  Serial.println();*/
int16_t tenBitTwosComplementToDecimal(uint16_t x)
  boolean negative = (x & (1 << 9)) != 0;
  if(negative)
    return x | ~((1 << 10) - 1);
   return (int16_t)x;
//This function will write a value to a register on the ADXL345.
//Parameters:
//  char registerAddress - The register to write a value to
//  char value - The value to be written to the specified register.
void writeRegister(char registerAddress, unsigned char value){
  //Set Chip Select pin low to signal the beginning of an SPI packet.
  digitalWrite(CS, LOW);
  //Transfer the register address over SPI.
  SPI.transfer(registerAddress);
  //Transfer the desired register value over SPI.
  SPI.transfer(value);
  //Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
//  char registerAddress - The register addresse to start the read sequence from.
//  int numBytes - The number of registers that should be read.
//  char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, unsigned char * values){
  //Since we're performing a read operation, the most significant bit of the register address should be set.
  char address = 0x80 | registerAddress;
  //If we're doing a multi-byte read, bit 6 needs to be set as well.
  if(numBytes > 1)address = address | 0x40;
  //Set the Chip select pin low to start an SPI packet.
  //Transfer the starting register address that needs to be read.
  SPI.transfer(address);
  //Continue to read registers until we've read the number specified, storing the results to the input buffer.
  for(int i=0; i<numBytes; i++){
    values[i] = SPI.transfer(0x00);
  //Set the Chips Select pin high to end the SPI packet.
Report to moderator
