I m trying using a different Pc to upload esp32cam , but that was an error
as below message ,
exec: "cmd": executable file not found in %PATH%
Error compiling for board ESP32 Wrover Module.
Arduino: 1.8.1 (Windows 10), Board: "ESP32 Wrover Module, Huge APP (3MB No OTA/1MB SPIFFS), QIO, 80MHz, 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -ide-version=10801 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_420342 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\User\Documents\Arduino\CameraWebServer\CameraWebServer.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -ide-version=10801 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_420342 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\User\Documents\Arduino\CameraWebServer\CameraWebServer.ino
Using board 'esp32wrover' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Build options changed, rebuilding all
cmd /c if exist "C:\Users\User\Documents\Arduino\CameraWebServer\partitions.csv" copy /y "C:\Users\User\Documents\Arduino\CameraWebServer\partitions.csv" "C:\Users\User\AppData\Local\Temp\arduino_build_420342\partitions.csv"
Summary
This text will be hidden
What do you think will happen if you ask amazon-alexa "Alexa bring me 1 million dollar!"??
See also FAQ - Arduino Forum for general rules on forum behavior and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frus…
1. Arduino programming language
The Arduino basically uses the industry-standard C++ language, implemented by the GNU g++ compiler.
For information on basic things like loops, strings, functions, data types, and so on try consulting one of the many online C++ references. Hint: Google "C++ tutorial".
The main sketch is C++, however the IDE does do a certain amount of pre-processing (in particular, generating function prototypes for you) before submitting the code to the main C++ compiler (see …
pert
June 4, 2021, 5:53am
3
It looks like C:\WINDOWS\system32
is for some reason not in your system's PATH
environment variable.
Try this:
Right click the Windows Start button.
From the menu, click "Run" .
In the "Open" field, type "SystemPropertiesAdvanced
Click the OK button. The "System Properties" window will now open.
Click the "Advanced" tab.
Click the Environment variables... button.
In the "System Variables" list, you should see "Path
". Click on it.
Click the Edit... button. This will open the "Edit environment variable" dialog.
Click the New button.
Click the Edit... button. This will open an input field to define a new PATH entry.
Add the following text%SystemRoot%\System32
Click the OK button on the "Edit environment variable" dialog.
Click the OK button on the "Environment Variables" dialog.
Click the OK button on the "System Properties" window to close it.
Now try uploading again.
thks
upload done , unable to detect wifi
Brownout detector was triggered
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
I admit that I did not know how to help with your first question.
Your last post shows the output received in the serial monitor.
The error-message says:
Yes and this is was happened.
brownout means the voltage of your power-supply dropped below the minimum that is required. So a general advice would be
"use a sufficient power-supply"
Though this sentence does not help very much.
You could receive much better advice if write down a detailed description
if you have a digital multimeter (which is a must when working with microcontrollers)
your knowledge-level about electronics
what exactly EPS32-board you are using
what powersupply you are using
pasting pictures into a posting that show your hardware
posting such short messages provokes asking back questions which slow down the speed to find the solution.
best regards Stefan
HI StefanL38,
this is the hardware I was using, I did much time was successful
but now totally have no idea what happening with eso32cam it can`t work
Yes you are right insufficient power supply 3.3v , changed to 5v it work ,
StefanL38 thanks alot ,
and everyone here
HI , pert ,
another problem error come can help me thanks
below is the error message
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
you are very short on words. Write detailed description
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
srnet
June 11, 2021, 9:21am
10
Describing what your actually doing when you get that message would help us to help you.
hi srnet,
I m new to doing esp32camera to view from the internet everywhere,
using Arduino IDE different PC to trying upload program code
This is one of my Pc unable to upload code
to test the esp32cam
thanks
this is the error
"A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header "
You were asked to post informatin that goes BEYOND the sentence
""A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header ""
MORE INFORMATION ! MORE DETAILS about what you are doing.
For making progress
for solving your problem
for making it work
it is essential that you post ALL the informations like described in this message
Hello,
system
Closed
October 10, 2021, 5:17am
13
