Error ESP8266 to Firebase
I'm sorry sir, I newbie learn about IoT. I have a problem when I setting my ESP8266 to firebase I have a problem like that so what solution for that? actually, I search for all solutions to solve the problem of Error compiling for board NodeMCU 1.0 (ESP-12E Module). But I didn't found a solution for this problem
Arduino: 1.8.15 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 57600"
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:50: error: no matching function for call to 'begin(const char*, const char [60])'
   47 |     http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\ABWLurr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
  166 |     bool begin(String host, uint16_t port, String uri = "/")  __attribute__ ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\ABWLurr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note:   conversion of argument 2 would be ill-formed:
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
      |                              const char*
C:\Users\ABWLurr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
  167 |     bool begin(String url, const uint8_t httpsFingerprint[20])  __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\ABWLurr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note:   conversion of argument 2 would be ill-formed:
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
      |                              const char*
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
C:\Users\ABWLurr\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:51:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
   51 |     http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
      |                                                            const char*
C:\Users\ABWLurr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note:   initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
  168 |     bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20])  __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
exit status 1
option enabled in File -> Preferences.
What's your question?
I'm sorry sir, I newbie learn about IoT. I have a problem when I setting my ESP8266 to firebase I have a problem like that so what solution for that? actually, i search all solutions to solve the problem of Error compiling for board NodeMCU 1.0 (ESP-12E Module).
      |                              const char*
      |                              const char*
      |                                                            const char*
exit status 1
Excellent, we are getting there. Can you post your code and a picture of your setup too? This will help others to help you.
This is a demo from Arduino to test the firebase but I think i have problem with my library
// Copyright 2015 Google Inc.
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "tess-esp8266-defaaseio.com"
#define FIREBASE_AUTH "bGY0VwkJfHTmcaEISlVtwaltgardJ"
#define WIFI_SSID "ABC"
#define WIFI_PASSWORD "huijau"
  // connect to wifi.
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
    Serial.print(".");
  Serial.print("connected: ");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
int n = 0;
  // set value
  Firebase.setFloat("number", 42.0);
  // handle error
  if (Firebase.failed()) {
      Serial.print("setting /number failed:");
      Serial.println(Firebase.error());
      return;
  // update value
  Firebase.setFloat("number", 43.0);
  // handle error
      return;
  // get value
  Serial.print("number: ");
  Serial.println(Firebase.getFloat("number"));
  // remove value
  Firebase.remove("number");
  // set string value
  Firebase.setString("message", "hello world");
  // handle error
      Serial.print("setting /message failed:");
      return;
  // set bool value
  Firebase.setBool("truth", false);
  // handle error
      Serial.print("setting /truth failed:");
      return;
  // append a new value to /logs
  String name = Firebase.pushInt("logs", n++);
  // handle error
      Serial.print("pushing /logs failed:");
      return;
  Serial.print("pushed: /logs/");
  Serial.println(name);
and this is the message from compiler
      |                              const char*
      |                              const char*
      |                                                            const char*
exit status 1
this is the screenshot
I'm not familiar with firebase so I cannot help you further, but now that you've posted all this info and formatted it, others will be able to help you easier.
No problem. Thank you for help me to make question in the forum
