error: expected ')' before numeric constant LiquidCrystal lcd (3, 4, 5 6, 7, 8
I am trying to write some code for a prject that I am working on but i got this error message that I don’t know how to fix.
#include <Servo.h>
#include <LiquidCrystal.h>
#include <Wire.h>
Servo myservo;  // create servo object to control a servo
int servo_pin = 12;
int brightness_lcd_pin = 11;
int text_lcd_pin = 10;
int color_lcd_pin = 9; // Sets the pin values for the receiver
int pos = 95;    // variable to store the servo position
#define REDLITE 0
#define GREENLITE 1
#define BLUELITE 2
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd (3, 4, 5 6, 7, 8);
int brightness = 255;
  myservo.attach(13);  // attaches the servo on pin 9 to the servo object]
  pinMode(servo_pin, OUTPUT);
  pinMode(brightness_lcd_pin, OUTPUT);
  pinMode(text_lcd_pin, OUTPUT);
  pinMode(color_lcd_pin, OUTPUT);
  pinMode(REDLITE, OUTPUT);
  pinMode(GREENLITE, OUTPUT);
  pinMode(BLUELITE, OUTPUT);
  if (digitalRead(servo_pin) == HIGH)
    for (pos = 95; pos <= 0; pos -= 1) { // goes from 0 degrees to 95 degrees in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
   if (digitalRead(servo_pin) == LOW)
    for (pos = 0; pos <= 95; pos += 1) { // goes from 0 degrees to 95 degrees in steps of 1 degree
if (digitalRead(brightness_lcd_pin) == HIGH)
   brightness = 200
   if (digitalRead(brightness_lcd_pin) == LOW)
   brightness = 100
  if (digitalRead(text_lcd_pin) == HIGH)
    // set up the LCD's number of rows and columns:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Goodbye Rocky  ");
  lcd.setCursor(0,1);
  lcd.print(" Ford Highschool ");
   if (digitalRead(text_lcd_pin) == LOW)
    lcd.begin(16, 2);
  lcd.print("Class of  ");
  lcd.setCursor(0,1);
  lcd.print(" 2019!!! ");
  if (digitalRead(color_lcd_pin) == HIGH)
  for (int i = 0; i < 255; i++) {
    setBacklight(i, 0, 255-i);
    delay(5);
    setBacklight(255-i, i, 0);
    delay(5);
    setBacklight(0, 255-i, i);
    delay(5);
   void setBacklight(uint8_t r, uint8_t g, uint8_t b) {
  // normalize the red LED - its brighter than the rest!
  r = map(r, 0, 255, 0, 100);
  g = map(g, 0, 255, 0, 150);
  r = map(r, 0, 255, 0, brightness);
  g = map(g, 0, 255, 0, brightness);
  b = map(b, 0, 255, 0, brightness);
  // common anode so invert!
  r = map(r, 0, 255, 255, 0);
  g = map(g, 0, 255, 255, 0);
  b = map(b, 0, 255, 255, 0);
  Serial.print("R = "); Serial.print(r, DEC);
  Serial.print(" G = "); Serial.print(g, DEC);
  Serial.print(" B = "); Serial.println(b, DEC);
  analogWrite(REDLITE, r);
  analogWrite(GREENLITE, g);
  analogWrite(BLUELITE, b);
   if (digitalRead(color_lcd_pin) == LOW)
Here is the error message.
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
Cap:18:28: error: expected ')' before numeric constant
Cap:18:35: error: no matching function for call to 'LiquidCrystal::LiquidCrystal(int, int, int, int, int)'
In file included from C:\Users\Kasey\Desktop\Cap\Cap.ino:3:0:
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
   LiquidCrystal(uint8_t rs, uint8_t enable,
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note:   candidate expects 6 arguments, 5 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
   LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note:   candidate expects 7 arguments, 5 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note:   candidate expects 11 arguments, 5 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note:   candidate expects 10 arguments, 5 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate: constexpr LiquidCrystal::LiquidCrystal(const LiquidCrystal&)
 class LiquidCrystal : public Print {
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note:   candidate expects 1 argument, 5 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate: constexpr LiquidCrystal::LiquidCrystal(LiquidCrystal&&)
C:\Users\Kasey\Desktop\Cap\Cap.ino: In function 'void loop()':
Cap:48:3: error: expected ';' before '}' token
Cap:51:3: error: expected ';' before '}' token
C:\Users\Kasey\Desktop\Cap\Cap.ino: At global scope:
Cap:53:3: error: expected unqualified-id before 'if'
Cap:57:3: error: 'lcd' does not name a type
Cap:58:3: error: 'lcd' does not name a type
   lcd.setCursor(0,1);
Cap:59:3: error: 'lcd' does not name a type
Cap:60:3: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
LiquidCrystal lcd (3, 4, 5 <shouldn't there be a comma here?> 6, 7, 8);
You should check the placement of your { and }
Probably should throw in a few ; too.
      brightness = 200
    brightness = 100
