Error: expected constructor, destructor, or type conversion before '(' token conversion
Hello I am Making a project involving the 'HC - SR04' ultrasonic sensor and the 'HC - 05' Bluetooth
module. I am having the following error in the code. When I didn't add the Bluetooth module in the code it was working just fine. Help will be appreciated.
CODE:
int Trig = 7;
int echo = 6;
int Led = 12;
long Time;
int distance;
int VALUE;
  pinMode(Trig,OUTPUT);
  pinMode(echo, INPUT);
  pinMode(Led, OUTPUT);
  pinMode(11, OUTPUT);
  if (Serial.available() > 0)
  VALUE = Serial.read();
  if(VALUE == '1'){
    digitalWrite(Led, HIGH);
  }  else if(VALUE == '0'){
    digitalWrite(Led, LOW);
  digitalWrite(Trig, LOW);
  delay(2);
  digitalWrite(Trig, HIGH);
  delay(10);
  Time = pulseIn(echo, HIGH);
  distance = Time*0.034/2;
  if(distance <= 30){
    delay(200);
    delay(200);
    Serial.println("INTRUDER ALERT!!");
    digitalWrite(11, HIGH);}
Thank you.
You've got an extra } that needs to go...
   if (VALUE == '1')
   else if (VALUE == '0')
} // <<<<<<<<<<<<<<<<<<<<   extra } closes loop() early
delay(2);
delay(10);
Use the very handy IDE autoformat tool (ctrl-t or Tools, Auto format) and you will see the above. Note the indenting plainly shows where you have the extra closing curly bracket pointed out by member @red_car. Since the loop() function is closed early, all the rest of the code is outside of a function which is an error.
Thank you very much. Will do the following changes.
