Error: expected constructor, destructor, or type conversion before ';' token. Error is occuring at void_mStop
int signal_emission = 7; //The emission of an ultrasonic signal
int signal_recieve = 8; //Recieving back the signal
//mapping of motor variables to arduino I/O pins
/3/int motor_right_out1 = 13; //Turning of right motor through output 1 from H bridge - clockwise - Green wire
int motor_right_out2 = 12; //Turning of right motor through output 2 from H bridge - anticlockwise - Yellow wire
int speed_control_mtr_left = 3; //Controlling RPM of left motor through PWM pins
int motor_left_out3 = 11; //Turning of left motor through output 3 from H bridge - clockwise - Orange wire
int motor_left_out4 = 10; //Turning of left motor through output 4 from H bridge - anticlockwise - Purple wire
//function for the robot to move forward
void_mForward(){
analogWrite(speed_control_mtr_right, 80); //Using an analog function to determine the speed of the right motor
// right motor turning clockwise
digitalWrite(motor_right_out1,HIGH);
digitalWrite(motor_right_out2,LOW);
analogWrite(speed_control_mtr_left, 80); //Using an analog function to determine the speed of the left motor
// left motor turning clockwise
digitalWrite(motor_left_out3,HIGH);
digitalWrite(motor_left_out4,LOW);
Serial.print("ROBOT_MOVING_FORWARD");
//function for robot to move backwards
void_mBackwards(){
// right motor turning anticlockwise
digitalWrite(motor_right_out1,LOW);
digitalWrite(motor_right_out2,HIGH);
// left motor turning anticlockwise
digitalWrite(motor_left_out3,LOW);
digitalWrite(motor_left_out4,HIGH);
Serial.print("ROBOT_MOVING_BACKWARD");
//function for robot turning left
void_mLeft(){
Serial.print("ROBOT_TURNING_LEFT");
//function for robot turning right
void_mRight(){
Serial.print("ROBOT_TURNING_RIGHT");
//function for robot to stop
void_mStop(){
analogWrite(speed_control_mtr_right, 0); //Using an analog function to determine the speed of the right motor
// right motor stop
analogWrite(speed_control_mtr_left, 0); //Using an analog function to determine the speed of the left motor
// left motor stop
Serial.print("ROBOT_STOP");
//defining Input & Outputs of the ultrasonic sensor
pinMode(signal_emission, OUTPUT); //Emission of wave
pinMode(signal_recieve, INPUT); //Recieving wave
//defining Inputs & Outputs of the motor system
pinMode (speed_control_mtr_right, OUTPUT); //Defining PWM pin 5 as an output
pinMode (motor_right_out1, OUTPUT); //Defining right motor cw as an output
pinMode (motor_right_out2, OUTPUT); //Defining right motor acw as an output
pinMode (speed_control_mtr_left,OUTPUT); //Defining PWM pin 3 as an output
pinMode (motor_left_out3, OUTPUT); //Defining left motor cw as an output
pinMode (motor_left_out4, OUTPUT); //Defining left motor acw as an output
You are not going to make a lot of friends with that first post.
Read the forum guidelines to see how to properly post code and some information on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
ok thanks
What is wrong with that function name? Maybe Mr. void needs some space?
Hi
Etc.......
This code is for what kind of IDE and micro controller?
loop() function, "void loop()" is missing.
In addition to missing some definitions.
Use cntl T to organize your code and follow @groundFungus guidance
Here is a version that compiles without errors.
The end of the file got cut off when you posted.
The declaration of 'speed_control_mtr_right' was missing. There was a "/3/" at the beginning of a line. There were spaces missing between the 'void' keyword and the name of some functions.
const int signal_emission = 7; // The emission of an ultrasonic signal
const int signal_recieve = 8; // Recieving back the signal
const int speed_control_mtr_right = 6; //Controlling RPM of right motor through PWM pins
const int motor_right_out1 = 13; //Turning of right motor through output 1 from H bridge - clockwise - Green wire
const int motor_right_out2 = 12; //Turning of right motor through output 2 from H bridge - anticlockwise - Yellow wire
const int speed_control_mtr_left = 3; //Controlling RPM of left motor through PWM pins
const int motor_left_out3 = 11; //Turning of left motor through output 3 from H bridge - clockwise - Orange wire
const int motor_left_out4 = 10; //Turning of left motor through output 4 from H bridge - anticlockwise - Purple wire
void _mForward()
  digitalWrite(motor_right_out1, HIGH);
  digitalWrite(motor_right_out2, LOW);
  digitalWrite(motor_left_out3, HIGH);
  digitalWrite(motor_left_out4, LOW);
void _mBackwards()
  digitalWrite(motor_right_out1, LOW);
  digitalWrite(motor_right_out2, HIGH);
  digitalWrite(motor_left_out3, LOW);
  digitalWrite(motor_left_out4, HIGH);
void _mLeft()
void _mRight()
void _mStop()
  // right motor stop
  // left motor stop
  pinMode (speed_control_mtr_left, OUTPUT); //Defining PWM pin 3 as an output
///////////// The file was cut off here ///////////
void loop() {}
