// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_ACCESS_PASSWORD "toptech2008"
int button1 = 22;
int button2 = 24;
int button3 = 26;
int button4 = 28;
int button5 = 30;
int button6 = 32;
int button7 = 34;
int button8 = 36;
int button9 = 38;
int button10 = 40;
int button11 = 42;
int button12 = 44;
int PIN_RELAY1 = 53;
int PIN_RELAY2 = 51;
int PIN_RELAY3 = 49;
int PIN_RELAY4 = 47;
int PIN_RELAY5 = 45;
int PIN_RELAY6 = 43;
int PIN_RELAY7 = 41;
int PIN_RELAY8 = 39;
int PIN_RELAY9 = 37;
int PIN_RELAY10 = 35;
int PIN_RELAY11 = 33;
int PIN_RELAY12 = 31;
int status= false;
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,13,0,62,0,12,2,11,122,5,
2,1,4,8,21,9,0,205,94,24,
24,79,78,0,79,70,70,0,2,1,
4,23,21,8,0,205,94,24,24,79,
78,0,79,70,70,0,2,1,35,9,
21,8,0,205,94,24,24,79,78,0,
79,70,70,0,2,1,35,23,21,8,
0,205,94,24,24,79,78,0,79,70,
70,0,2,1,4,37,21,8,0,205,
94,24,24,79,78,0,79,70,70,0,
2,1,4,51,21,8,0,205,94,24,
35,36,21,9,0,205,94,24,24,79,
78,0,79,70,70,0,2,1,35,50,
21,9,0,205,94,24,24,79,78,0,
79,70,70,0,2,1,4,64,21,8,
70,0,2,1,35,63,21,9,0,205,
2,1,36,76,20,9,0,205,94,24,
5,77,20,8,0,205,94,24,24,79,
78,0,79,70,70,0,65,4,27,10,
5,5,0,65,4,57,77,5,5,0,
65,4,57,64,5,5,0,65,4,57,
51,5,5,0,65,4,57,38,5,5,
0,65,4,57,9,5,5,0,65,4,
57,24,5,5,0,65,4,27,51,5,
5,0,65,4,27,65,5,5,0,65,
4,27,78,5,5,0,131,1,0,93,
63,5,1,2,31,72,111,109,101,32,
65,117,116,111,109,97,116,105,111,110,
32,66,121,32,84,111,112,32,84,101,
99,104,0,69,1,15,8,10,10,0,
69,1,5,7,10,10,0,69,1,36,
8,9,9,0,69,1,46,7,10,10,
0,69,1,5,22,10,10,0,69,1,
14,22,10,10,0,69,1,36,22,10,
10,0,69,1,46,22,10,10,0,69,
1,5,36,10,10,0,69,1,15,36,
10,10,0,69,1,36,35,10,10,0,
69,1,17,50,10,10,0,69,1,5,
50,10,10,0,69,1,47,36,10,10,
0,69,1,36,62,10,10,0,69,1,
46,50,10,10,0,69,1,36,49,10,
10,0,69,1,47,23,10,10,0,69,
1,18,75,10,10,0,69,1,16,63,
10,10,0,69,1,5,76,10,10,0,
69,1,4,63,10,10,0,69,1,37,
75,10,10,0,69,1,46,76,10,10,
0,65,4,27,25,5,5,0,65,4,
27,39,5,5,0,4,128,5,0,55,
7,0,2,26,69,1,46,63,10,10,
0 };
// this structure defines all the variables and events of your control interface
struct {
// input variables
uint8_t PIN_RELAY_1; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_2; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_7; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_8; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_3; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_4; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_9; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_10; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_5; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_11; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_12; // =1 if switch ON and =0 if OFF
uint8_t PIN_RELAY_6; // =1 if switch ON and =0 if OFF
int8_t PIN_RELAY_13; // =0..100 slider position
// output variables
uint8_t PIN_RELAY_1_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_13_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_12_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_11_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_10_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_7_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_9_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY_4_r; // =0..255 LED Red brightness
uint8_t _5_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY__6_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY__2_r; // =0..255 LED Red brightness
uint8_t PIN_RELAY__3_r; // =0..255 LED Red brightness
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
#define PIN_RELAY_1 53
#define PIN_RELAY_2 51
#define PIN_RELAY_7 41
#define PIN_RELAY_8 39
#define PIN_RELAY_3 49
#define PIN_RELAY_4 47
#define PIN_RELAY_9 37
#define PIN_RELAY_10 35
#define PIN_RELAY_5 45
#define PIN_RELAY_11 33
#define PIN_RELAY_12 31
#define PIN_RELAY_6 43
#include <IRremote.h>
int RECV_PIN = 12; //tsop1738 output pin connected to D8
#define buzzer 10 //buzzer conected pin 12
int a = 1;
int b = 1;
int c = 1;
int d = 1;
int e = 1;
int f = 1;
int g = 1;
int h = 1;
int i = 1;
int j = 1;
int k = 1;
int l = 1;
IRrecv irrecv(RECV_PIN);
decode_results results;
int receiver = 3;
IRrecv IRrecv(receiver);
decode_results Results;
#include <TimerOne.h>
volatile int m = 0; // Variable to use as a counter
volatile boolean zero_cross=0; // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 5; // Output to Opto Triac
int dim2 = 0; // led control
int dim = 128; // Dimming level (0-128) 0 = on, 128 = 0ff
int freqStep = 75; // This is the delay-per-brightness step in microseconds.
RemoteXY_Init ();
pinMode (PIN_RELAY_1, OUTPUT);
pinMode (PIN_RELAY_2, OUTPUT);
pinMode (PIN_RELAY_7, OUTPUT);
pinMode (PIN_RELAY_8, OUTPUT);
pinMode (PIN_RELAY_3, OUTPUT);
pinMode (PIN_RELAY_4, OUTPUT);
pinMode (PIN_RELAY_9, OUTPUT);
pinMode (PIN_RELAY_10, OUTPUT);
pinMode (PIN_RELAY_5, OUTPUT);
pinMode (PIN_RELAY_11, OUTPUT);
pinMode (PIN_RELAY_12, OUTPUT);
pinMode (PIN_RELAY_6, OUTPUT);
// TODO you setup code
pinMode(PIN_RELAY_1, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(PIN_RELAY_2, OUTPUT);
pinMode(button2, INPUT_PULLUP);
pinMode(PIN_RELAY_3, OUTPUT);
pinMode(button3, INPUT_PULLUP);
pinMode(PIN_RELAY_4, OUTPUT);
pinMode(button4, INPUT_PULLUP);
pinMode(PIN_RELAY_5, OUTPUT);
pinMode(button5, INPUT_PULLUP);
pinMode(PIN_RELAY_6, OUTPUT);
pinMode(button6, INPUT_PULLUP);
pinMode(PIN_RELAY_7, OUTPUT);
pinMode(button7, INPUT_PULLUP);
pinMode(PIN_RELAY_8, OUTPUT);
pinMode(button8, INPUT_PULLUP);
pinMode(PIN_RELAY_9, OUTPUT);
pinMode(button9, INPUT_PULLUP);
pinMode(PIN_RELAY_10, OUTPUT);
pinMode(button10, INPUT_PULLUP);
pinMode(PIN_RELAY_11, OUTPUT);
pinMode(button11, INPUT_PULLUP);
pinMode(PIN_RELAY_12, OUTPUT);
pinMode(button12, INPUT_PULLUP);
digitalWrite()
digitalWrite(PIN_RELAY_1, LOW);
digitalWrite(PIN_RELAY_2, LOW);
digitalWrite(PIN_RELAY_3, LOW);
digitalWrite(PIN_RELAY_4, LOW);
digitalWrite(PIN_RELAY_5, LOW);
digitalWrite(PIN_RELAY_6, LOW);
digitalWrite(PIN_RELAY_7, LOW);
digitalWrite(PIN_RELAY_8, LOW);
digitalWrite(PIN_RELAY_9, LOW);
digitalWrite(PIN_RELAY_10, LOW);
digitalWrite(PIN_RELAY_11, LOW);
digitalWrite(PIN_RELAY_12, LOW);
irrecv.enableIRIn(); // Start the IR receiver (classic remote)
pinMode()
pinMode(AC_pin, OUTPUT); // Set the Triac pin as output
attachInterrupt()
attachInterrupt(0, zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
Timer1.initialize(freqStep); // Initialize TimerOne library for the freq we need
Timer1.attachInterrupt(dim_check, freqStep);
void zero_cross_detect()
zero_cross = true; // set the boolean to true to tell our dimming function that a zero cross has occured
i=0;
digitalWrite(AC_pin, LOW);
// Turn on the TRIAC at the appropriate time
void dim_check()
if(zero_cross == true) {
if(m>=dim) {
digitalWrite(AC_pin, HIGH); // turn on light
m=0; // reset time step counter
zero_cross=false; // reset zero cross detection
else {
i++; // increment time step counter
void translateIR() // takes action based on IR code received
switch(results.value)
case 33464415:
if (dim<127)
dim = dim + 8;
if (dim>127)
dim=128; // in vechiul sketch era 127
case 33448095:
if (dim>5)
dim = dim - 8;
if (dim<0)
dim=0; // in vechiul sketch era 1
RemoteXY_Handler ();
digitalWrite(PIN_RELAY_1, (RemoteXY.PIN_RELAY__1==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_2, (RemoteXY.PIN_RELAY__2==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_7, (RemoteXY.PIN_RELAY__7==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_8, (RemoteXY.PIN_RELAY__8==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_3, (RemoteXY.PIN_RELAY__3==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_4, (RemoteXY.PIN_RELAY__4==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_9, (RemoteXY.PIN_RELAY__9==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_10, (RemoteXY.PIN_RELAY__10==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_5, (RemoteXY.PIN_RELAY__5==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_11, (RemoteXY.PIN_RELAY__11==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_12, (RemoteXY.PIN_RELAY__12==0)?LOW:HIGH);
digitalWrite(PIN_RELAY_6, (RemoteXY.PIN_RELAY__6==0)?LOW:HIGH);
// TODO you loop code
// use the RemoteXY structure for data transfer
// do not call delay()
int fanspeed = RemoteXY.PIN_RELAY__13 * 2.5
;analogWrite (1, fanspeed)
;if (digitalRead(button1) == true) {
status = !status;
digitalWrite(PIN_RELAY_1, status);
} while(digitalRead(button1) == true);
delay(50);
;if (digitalRead(button2) == true) {
status = !status;
digitalWrite(PIN_RELAY_2, status);
} while(digitalRead(button2) == true);
delay(50);
;if (digitalRead(button3) == true) {
status = !status;
digitalWrite(PIN_RELAY_3, status);
} while(digitalRead(button3) == true);
delay(50);
;if (digitalRead(button4) == true) {
status = !status;
digitalWrite(PIN_RELAY_4, status);
} while(digitalRead(button4) == true);
delay(50);
;if (digitalRead(button5) == true) {
status = !status;
digitalWrite(PIN_RELAY_5, status);
} while(digitalRead(button5) == true);
delay(50);
;if (digitalRead(button6) == true) {
status = !status;
digitalWrite(PIN_RELAY_6, status);
} while(digitalRead(button6) == true);
delay(50);
;if (digitalRead(button7) == true) {
status = !status;
digitalWrite(PIN_RELAY_7, status);
} while(digitalRead(button7) == true);
delay(50);
;if (digitalRead(button8) == true) {
status = !status;
digitalWrite(PIN_RELAY_8, status);
} while(digitalRead(button8) == true);
delay(50);
;if (digitalRead(button9) == true) {
status = !status;
digitalWrite(PIN_RELAY_9, status);
} while(digitalRead(button9) == true);
delay(50);
;if (digitalRead(button10) == true) {
status = !status;
digitalWrite(PIN_RELAY_10, status);
} while(digitalRead(button10) == true);
delay(50);
;if (digitalRead(button11) == true) {
status = !status;
digitalWrite(PIN_RELAY_11, status);
} while(digitalRead(button11) == true);
delay(50);
;if (digitalRead(button12) == true) {
status = !status;
digitalWrite(PIN_RELAY_12, status);
} while(digitalRead(button12) == true);
delay(50);
if (irrecv.decode(&results))
Serial.println(results.value, HEX);
if (results.value == 0x1FE48B7) // paste your hex code
a++;
int x = a % 2;
digitalWrite(53, x);
else if (results.value == 0x1FE50AF) //paste your hex code
b++;
int x = b % 2;
digitalWrite(51, x);
else if (results.value == 0x1FED827) //paste your hex code
c++;
int x = c % 2;
digitalWrite(49, x);
else if (results.value == 0x1FEF807) ///paste your hex code
b++;
int x = d % 2;
digitalWrite(47, x);
a++;
int x = e % 2;
digitalWrite(45, x);
int x = f % 2;
digitalWrite(43, x);
} else if (results.value == 0x1FEF807) ///paste your hex code
c++;
int x = g % 2;
digitalWrite(41, x);
b++;
int x = h % 2;
digitalWrite(39, x);
a++;
int x = i % 2;
digitalWrite(37, x);
{int x = j % 2;
digitalWrite(35, x);
c++;
int x = k % 2;
digitalWrite(33, x);
b++;
int x = l % 2;
digitalWrite(31, x);
irrecv.resume(); //resume,continue recieving ir-signals
if (irrecv.decode(&results)) // have we received an IR signal?
translateIR();
irrecv.resume(); // receive the next value
Error: exit status 1
expected unqualified-id before '{' token
