Hi all!
I'm receiving this error message and I've looked into a bit, and I'm not sure why I am receiving the message.
The code I am trying to use is Nick Gammon's SPI examples found Here
Here's the specific code I am using:
// http://www.gammon.com.au/spi
// Written by Nick Gammon
// February 2011
#include <SPI.h>
char buf [100];
volatile byte pos;
volatile boolean process_it;
void setup (void)
Serial.begin (115200); // debugging
// turn on SPI in slave mode
SPCR |= bit (SPE);
// have to send on master in, *slave out*
pinMode(MISO, OUTPUT);
// get ready for an interrupt
pos = 0; // buffer empty
process_it = false;
// now turn on interrupts
SPI.attachInterrupt();
} // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR; // grab byte from SPI Data Register
// add to buffer if room
if (pos < (sizeof (buf) - 1))
buf [pos++] = c;
// example: newline means time to process buffer
if (c == '\n')
process_it = true;
} // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
if (process_it)
buf [pos] = 0;
Serial.println (buf);
pos = 0;
process_it = false;
} // end of flag set
} // end of loop
I'm using arduino IDE 1.8.5 and the code compiles just fine for an Arduino Uno. The problems comes when I switch to an Arduino Zero (native port) board in the IDE. When I switch to that board, the error message is:
SPI_test_Slave:33: error: expected constructor, destructor, or type conversion before '(' token
ISR (SPI_STC_vect)
C:\Documents and Settings\User\My Documents\Arduino\SPI_test_Slave\SPI_test_Slave.ino: In function 'void setup()':
SPI_test_Slave:17: error: 'SPCR' was not declared in this scope
SPCR |= bit (SPE);
C:\Documents and Settings\User\My Documents\Arduino\SPI_test_Slave\SPI_test_Slave.ino:17:3: note: suggested alternative: 'SPI'
SPCR |= bit (SPE);
SPI
In file included from sketch\SPI_test_Slave.ino.cpp:1:0:
SPI_test_Slave:17: error: 'SPE' was not declared in this scope
SPCR |= bit (SPE);
C:\Documents and Settings\User\Local Settings\Application Data\Arduino15\packages\arduino\hardware\samd\1.8.6\cores\arduino/Arduino.h:120:25: note: in definition of macro 'bit'
#define bit(b) (1UL << (b))
C:\Documents and Settings\User\My Documents\Arduino\SPI_test_Slave\SPI_test_Slave.ino:17:16: note: suggested alternative: 'SPI'
SPCR |= bit (SPE);
C:\Documents and Settings\User\My Documents\Arduino\SPI_test_Slave\SPI_test_Slave.ino: At global scope:
ISR (SPI_STC_vect)
exit status 1
I've looked into this error message, but it appears to not be from the usual causes, plus there's the fact that it compiles fine for an Uno, but not a Zero that has me stumped at the moment.
Any insight would be most welcomed!
Randy
