I am getting an error when trying to compile my code, and I've tried to add/remove semicolons from the end of the variables. Here's my code (not yet finished):
#include <U8x8lib.h>; // Include the OLED Screen library (U8X8)
#define breakout 0; // If you have broken out the OLED Module, set this to 1
#define ledPin 3; // Define a PWM capable pin
#define analogIn 0; // Defines the potentiometer input
int analogVal 0; // Value of the potentiometer
int PWMOut 0;
int square 0; // PWM Wave
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE); // Tell the OLED library which display you are using
pinMode(ledPin, OUTPUT);
pinMode(analogIn, INPUT); // Set pin modes for the LED and potentiometer
u8x8.begin // Initialize the OLED Display
Serial.begin(9600); // Start serial at 9600 baud
if(breakout = 0){
u8x8.setBusClock(100000); // Sets I2C Bus clock speed (Not needed if the module is connected to the PCB)
analogVal = analogRead(analogIn);
PWMOut = map(analogVal, 0, 1023, 0, 255)
analogWrite(ledPin, PWMOut)
u8x8.clear(); // Clear the display
u8x8.setFont(u8x8_font_amstrad_cpc_extended_f); // Set the font
u8x8.setCursor(0, 0); // Set cursor position
u8x8.print("Input: ");
u8x8.print(analogVal);
u8x8.setCursor(0, 33); // Set cursor to new line (uses a system similar to coordinates)
u8x8.print("PWM: ");
u8x8.print(PWMOut);
squareWave = digitalRead(ledPin);
Serial.println(squareWave);
Error Messages:
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino Uno"
LED_PWM:5:15: error: expected initializer before numeric constant
LED_PWM:6:12: error: expected initializer before numeric constant
int PWMOut 0;
LED_PWM:8:12: error: expected initializer before numeric constant
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino: In function 'void setup()':
LED_PWM:3:17: error: expected ')' before ';' token
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:12:11: note: in expansion of macro 'ledPin'
LED_PWM:12:17: error: expected primary-expression before ',' token
LED_PWM:4:19: error: expected ')' before ';' token
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:13:11: note: in expansion of macro 'analogIn'
LED_PWM:13:19: error: expected primary-expression before ',' token
LED_PWM:15:3: error: expected ';' before 'Serial'
LED_PWM:14:8: error: statement cannot resolve address of overloaded function
LED_PWM:16:15: error: expected primary-expression before '=' token
if(breakout = 0){
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino: In function 'void loop()':
LED_PWM:24:3: error: 'analogVal' was not declared in this scope
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:24:3: note: suggested alternative: 'analogRead'
analogRead
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:24:26: note: in expansion of macro 'analogIn'
LED_PWM:24:34: error: expected primary-expression before ')' token
LED_PWM:25:3: error: 'PWMOut' was not declared in this scope
LED_PWM:26:21: error: expected primary-expression before ',' token
LED_PWM:35:3: error: 'squareWave' was not declared in this scope
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:35:3: note: suggested alternative: 'square'
square
C:\Users\antoi\Documents\Arduino\Sketches\Grove Beginner Kit\LED_PWM\LED_PWM.ino:35:28: note: in expansion of macro 'ledPin'
LED_PWM:35:34: error: expected primary-expression before ')' token
exit status 1
option enabled in File -> Preferences.
