Hi, I'm having trouble with an error message regarding the 2261st line of code here, which reads "Compilation error: expected initializer before '.' token." The code is taken from Larason 2's MIDI organ project, and I modified it to fit my needs.
Here is the code.
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// Name: Arduino Mega Midi Controller Mega side.
// Created: May 10, 2021
// Last Edited: Mar 26, 2022
// Author: Larason2
// Acknowledgements: Bald Engineer, Amanda Ghassaei, jeffb42, GrumpyMike, John Main, Ghost, RIP Tutorial, Arduino tutorials.
// Includes Midi Through, wiring for pistons, improved debounce.
//Setup Key Data Arrays
byte keysA[16][8];
byte keysB[16][2];
byte keysC[7][6];
byte keysE[6][6];
//Setup Key Press Arrays
byte lastA[16][8];
byte lastB[16][2];
byte lastC[7][6];
byte lastE[6][6];
//Setup midi channel values
int noteOn1 = 144;
int noteOff1 = 128;
int noteOn2 = 145;
int noteOff2 = 129;
int noteOn3 = 146;
int noteOff3 = 130;
int noteOn4 = 147;
int noteOff4 = 131;
//Setup volume control channels
int CCchan6 = 181;
int CCchan7 = 182;
//Setup midi variables
int velocity = 100;
int Exp = 11;
//Setup Pot Monitoring variables
int LastPot6 = 1;
int LastPot7 = 1;
//Setup variable to debounce pots. increase to decrease bounce on the pots (units of analog signal variation)
int PotT = 10;
//Setup variables for Midi Thru
boolean byteReady;
unsigned char midiByte;
//Setup variables for key debounce on
unsigned long BounceAOn[16][8];
unsigned long BounceAOff[16][8];
//Setup variable for adjusting key debounce
//Increase to decrease bounce on the keys (units of milliseconds)
unsigned long Delay = 50;
// Start Serial
Serial.begin(31250);
//Initialize Row Pins Keyboard A
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
//Initialize Column Pins Keyboard A
pinMode(10, INPUT);
pinMode(11, INPUT);
pinMode(12, INPUT);
pinMode(14, INPUT);
pinMode(15, INPUT);
pinMode(16, INPUT);
pinMode(17, INPUT);
pinMode(18, INPUT);
pinMode(19, INPUT);
pinMode(20, INPUT);
pinMode(21, INPUT);
pinMode(22, INPUT);
pinMode(23, INPUT);
pinMode(24, INPUT);
pinMode(25, INPUT);
pinMode(26, INPUT);
//Pot Pins
pinMode(A13, INPUT);
pinMode(A14, INPUT);
//Initialize Midi Thru
byteReady = false;
midiByte = 0;
// Read Keyboard A
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, OUTPUT);
digitalWrite(10, LOW);
keysA[0][0] = digitalRead(3);
keysA[0][1] = digitalRead(2);
pinMode(10, INPUT);
pinMode(11, OUTPUT);
digitalWrite(11, LOW);
keysA[1][0] = digitalRead(3);
keysA[1][1] = digitalRead(4);
keysA[1][2] = digitalRead(5);
keysA[1][3] = digitalRead(6);
keysA[1][4] = digitalRead(7);
keysA[1][5] = digitalRead(8);
keysA[1][6] = digitalRead(9);
keysA[1][7] = digitalRead(2);
pinMode(11, INPUT);
pinMode(12, OUTPUT);
digitalWrite(12, LOW);
keysA[2][0] = digitalRead(3);
keysA[2][1] = digitalRead(4);
keysA[2][2] = digitalRead(5);
keysA[2][3] = digitalRead(6);
keysA[2][4] = digitalRead(7);
keysA[2][5] = digitalRead(8);
keysA[2][6] = digitalRead(9);
keysA[2][7] = digitalRead(2);
pinMode(12, INPUT);
pinMode(14, OUTPUT);
digitalWrite(14, LOW);
keysA[3][0] = digitalRead(3);
keysA[3][1] = digitalRead(4);
keysA[3][2] = digitalRead(5);
keysA[3][3] = digitalRead(6);
keysA[3][4] = digitalRead(7);
keysA[3][5] = digitalRead(8);
keysA[3][6] = digitalRead(9);
keysA[3][7] = digitalRead(2);
pinMode(14, INPUT);
pinMode(15, OUTPUT);
digitalWrite(15, LOW);
keysA[4][0] = digitalRead(3);
keysA[4][1] = digitalRead(4);
keysA[4][2] = digitalRead(5);
keysA[4][3] = digitalRead(6);
keysA[4][4] = digitalRead(7);
keysA[4][5] = digitalRead(8);
keysA[4][6] = digitalRead(9);
keysA[4][7] = digitalRead(2);
pinMode(15, INPUT);
pinMode(16, OUTPUT);
digitalWrite(16, LOW);
keysA[5][0] = digitalRead(3);
keysA[5][1] = digitalRead(4);
keysA[5][2] = digitalRead(5);
keysA[5][3] = digitalRead(6);
keysA[5][4] = digitalRead(7);
keysA[5][5] = digitalRead(8);
keysA[5][6] = digitalRead(9);
keysA[5][7] = digitalRead(2);
pinMode(16, INPUT);
pinMode(17, OUTPUT);
digitalWrite(17, LOW);
keysA[6][0] = digitalRead(3);
keysA[6][1] = digitalRead(4);
keysA[6][2] = digitalRead(5);
keysA[6][3] = digitalRead(6);
keysA[6][4] = digitalRead(7);
keysA[6][5] = digitalRead(8);
keysA[6][6] = digitalRead(9);
keysA[6][7] = digitalRead(2);
pinMode(17, INPUT);
pinMode(18, OUTPUT);
digitalWrite(18, LOW);
keysA[7][0] = digitalRead(3);
keysA[7][1] = digitalRead(4);
keysA[7][2] = digitalRead(5);
keysA[7][3] = digitalRead(6);
keysA[7][4] = digitalRead(7);
keysA[7][5] = digitalRead(8);
keysA[7][6] = digitalRead(9);
keysA[7][7] = digitalRead(2);
pinMode(18, INPUT);
pinMode(19, OUTPUT);
digitalWrite(19, LOW);
keysA[8][0] = digitalRead(3);
keysA[8][1] = digitalRead(4);
keysA[8][2] = digitalRead(5);
keysA[8][3] = digitalRead(6);
keysA[8][4] = digitalRead(7);
keysA[8][5] = digitalRead(8);
keysA[8][6] = digitalRead(9);
keysA[8][7] = digitalRead(2);
pinMode(19, INPUT);
pinMode(20, OUTPUT);
digitalWrite(20, LOW);
keysA[9][0] = digitalRead(3);
keysA[9][1] = digitalRead(4);
keysA[9][2] = digitalRead(5);
keysA[9][3] = digitalRead(6);
keysA[9][4] = digitalRead(7);
keysA[9][5] = digitalRead(8);
keysA[9][6] = digitalRead(9);
keysA[9][7] = digitalRead(2);
pinMode(20, INPUT);
pinMode(21, OUTPUT);
digitalWrite(21, LOW);
keysA[10][0] = digitalRead(3);
keysA[10][1] = digitalRead(4);
keysA[10][2] = digitalRead(5);
keysA[10][3] = digitalRead(6);
keysA[10][4] = digitalRead(7);
keysA[10][5] = digitalRead(8);
keysA[10][6] = digitalRead(9);
keysA[10][7] = digitalRead(2);
pinMode(21, INPUT);
pinMode(22, OUTPUT);
digitalWrite(22, LOW);
keysA[11][0] = digitalRead(3);
keysA[11][1] = digitalRead(4);
keysA[11][2] = digitalRead(5);
keysA[11][3] = digitalRead(6);
keysA[11][4] = digitalRead(7);
keysA[11][5] = digitalRead(8);
keysA[11][6] = digitalRead(9);
keysA[11][7] = digitalRead(2);
pinMode(22, INPUT);
pinMode(23, OUTPUT);
digitalWrite(23, LOW);
keysA[12][0] = digitalRead(3);
keysA[12][1] = digitalRead(4);
keysA[12][2] = digitalRead(5);
keysA[12][3] = digitalRead(6);
keysA[12][4] = digitalRead(7);
keysA[12][5] = digitalRead(8);
keysA[12][6] = digitalRead(9);
keysA[12][7] = digitalRead(2);
pinMode(23, INPUT);
pinMode(24, OUTPUT);
digitalWrite(24, LOW);
keysA[13][0] = digitalRead(3);
keysA[13][1] = digitalRead(4);
keysA[13][2] = digitalRead(5);
keysA[13][3] = digitalRead(6);
keysA[13][4] = digitalRead(7);
keysA[13][5] = digitalRead(8);
keysA[13][6] = digitalRead(9);
keysA[13][7] = digitalRead(2);
pinMode(24, INPUT);
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
keysA[14][0] = digitalRead(3);
keysA[14][1] = digitalRead(4);
keysA[14][2] = digitalRead(5);
keysA[14][3] = digitalRead(6);
keysA[14][4] = digitalRead(7);
keysA[14][5] = digitalRead(8);
keysA[14][6] = digitalRead(9);
keysA[14][7] = digitalRead(2);
pinMode(25, INPUT);
pinMode(26, OUTPUT);
digitalWrite(26, LOW);
keysA[15][0] = digitalRead(3);
keysA[15][1] = digitalRead(4);
keysA[15][2] = digitalRead(5);
keysA[15][3] = digitalRead(6);
keysA[15][4] = digitalRead(7);
keysA[15][5] = digitalRead(8);
keysA[15][6] = digitalRead(9);
keysA[15][7] = digitalRead(2);
pinMode(26, INPUT);
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
//Write Keyboard A
//A36
if (lastA[0][0] == 7) {
BounceAOn[0][0] = millis();
if ((keysA[0][0] == 0) and (lastA[0][0] == 0) and ((millis() - BounceAOn[0][0]) > Delay)) {
MIDI.sendNoteOn(1, 36, velocity);
lastA[0][0] = 7;
if (lastA[0][0] == 0) {
BounceAOff[0][0] = millis();
if ((keysA[0][0] == 1) and (lastA[0][0] == 7) and ((millis() - BounceAOff[0][0]) > Delay)) {
MIDI.sendNoteOff(1, 36, velocity);
lastA[0][0] = 0;
//A37
if (lastA[0][1] == 7) {
BounceAOn[0][1] = millis();
if ((keysA[0][1] == 0) and (lastA[0][1] == 0) and ((millis() - BounceAOn[0][1]) > Delay)) {
MIDI.sendNoteOn(1, 37, velocity);
lastA[0][1] = 7;
if (lastA[0][1] == 0) {
BounceAOff[0][1] = millis();
if ((keysA[0][1] == 1) and (lastA[0][1] == 7) and ((millis() - BounceAOff[0][1]) > Delay)) {
MIDI.sendNoteOff(1, 37, velocity);
lastA[0][1] = 0;
//A38
if (lastA[1][0] == 7) {
BounceAOn[1][0] = millis();
if ((keysA[1][0] == 0) and (lastA[1][0] == 0) and ((millis() - BounceAOn[1][0]) > Delay)) {
MIDI.sendNoteOn(1, 38, velocity);
lastA[1][0] = 7;
if (lastA[1][0] == 0) {
BounceAOff[1][0] = millis();
if ((keysA[1][0] == 1) and (lastA[1][0] == 7) and ((millis() - BounceAOff[1][0]) > Delay)) {
MIDI.sendNoteOff(1, 38, velocity);
lastA[1][0] = 0;
//A39
if (lastA[1][1] == 7) {
BounceAOn[1][1] = millis();
if ((keysA[1][1] == 0) and (lastA[1][1] == 0) and ((millis() - BounceAOn[1][1]) > Delay)) {
MIDI.sendNoteOn(1, 39, velocity);
lastA[1][1] = 7;
if (lastA[1][1] == 0) {
BounceAOff[1][1] = millis();
if ((keysA[1][1] == 1) and (lastA[1][1] == 7) and ((millis() - BounceAOff[1][1]) > Delay)) {
MIDI.sendNoteOff(1, 39, velocity);
lastA[1][1] = 0;
//A40
if (lastA[1][2] == 7) {
BounceAOn[1][2] = millis();
if ((keysA[1][2] == 0) and (lastA[1][2] == 0) and ((millis() - BounceAOn[1][2]) > Delay)) {
MIDI.sendNoteOn(1, 40, velocity);
lastA[1][2] = 7;
if (lastA[1][2] == 0) {
BounceAOff[1][2] = millis();
if ((keysA[1][2] == 1) and (lastA[1][2] == 7) and ((millis() - BounceAOff[1][2]) > Delay)) {
MIDI.sendNoteOff(1, 40, velocity);
lastA[1][2] = 0;
//A41
if (lastA[1][3] == 7) {
BounceAOn[1][3] = millis();
if ((keysA[1][3] == 0) and (lastA[1][3] == 0) and ((millis() - BounceAOn[1][3]) > Delay)) {
MIDI.sendNoteOn(1, 41, velocity);
lastA[1][3] = 7;
if (lastA[1][3] == 0) {
BounceAOff[1][3] = millis();
if ((keysA[1][3] == 1) and (lastA[1][3] == 7) and ((millis() - BounceAOff[1][3]) > Delay)) {
MIDI.sendNoteOff(1, 41, velocity);
lastA[1][3] = 0;
//A42
if (lastA[1][4] == 7) {
BounceAOn[1][4] = millis();
if ((keysA[1][4] == 0) and (lastA[1][4] == 0) and ((millis() - BounceAOn[1][4]) > Delay)) {
MIDI.sendNoteOn(1, 42, velocity);
lastA[1][4] = 7;
if (lastA[1][4] == 0) {
BounceAOff[1][4] = millis();
if ((keysA[1][4] == 1) and (lastA[1][4] == 7) and ((millis() - BounceAOff[1][4]) > Delay)) {
MIDI.sendNoteOff(1, 42, velocity);
lastA[1][4] = 0;
//A43
if (lastA[1][5] == 7) {
BounceAOn[1][5] = millis();
if ((keysA[1][5] == 0) and (lastA[1][5] == 0) and ((millis() - BounceAOn[1][5]) > Delay)) {
MIDI.sendNoteOn(1, 43, velocity);
lastA[1][5] = 7;
if (lastA[1][5] == 0) {
BounceAOff[1][5] = millis();
if ((keysA[1][5] == 1) and (lastA[1][5] == 7) and ((millis() - BounceAOff[1][5]) > Delay)) {
MIDI.sendNoteOff(1, 43, velocity);
lastA[1][5] = 0;
//A44
if (lastA[1][6] == 7) {
BounceAOn[1][6] = millis();
if ((keysA[1][6] == 0) and (lastA[1][6] == 0) and ((millis() - BounceAOn[1][6]) > Delay)) {
MIDI.sendNoteOn(1, 44, velocity);
lastA[1][6] = 7;
if (lastA[1][6] == 0) {
BounceAOff[1][6] = millis();
if ((keysA[1][6] == 1) and (lastA[1][6] == 7) and ((millis() - BounceAOff[1][6]) > Delay)) {
MIDI.sendNoteOff(1, 44, velocity);
lastA[1][6] = 0;
//A45
if (lastA[1][7] == 7) {
BounceAOn[1][7] = millis();
if ((keysA[1][7] == 0) and (lastA[1][7] == 0) and ((millis() - BounceAOn[1][7]) > Delay)) {
MIDI.sendNoteOn(1, 45, velocity);
lastA[1][7] = 7;
if (lastA[1][7] == 0) {
BounceAOff[1][7] = millis();
if ((keysA[1][7] == 1) and (lastA[1][7] == 7) and ((millis() - BounceAOff[1][7]) > Delay)) {
MIDI.sendNoteOff(1, 45, velocity);
lastA[1][7] = 0;
//A46
if (lastA[2][0] == 7) {
BounceAOn[2][0] = millis();
if ((keysA[2][0] == 0) and (lastA[2][0] == 0) and ((millis() - BounceAOn[2][0]) > Delay)) {
MIDI.sendNoteOn(1, 46, velocity);
lastA[2][0] = 7;
if (lastA[2][0] == 0) {
BounceAOff[2][0] = millis();
if ((keysA[2][0] == 1) and (lastA[2][0] == 7) and ((millis() - BounceAOff[2][0]) > Delay)) {
MIDI.sendNoteOff(1, 46, velocity);
lastA[2][0] = 0;
//A47
if (lastA[2][1] == 7) {
BounceAOn[2][1] = millis();
if ((keysA[2][1] == 0) and (lastA[2][1] == 0) and ((millis() - BounceAOn[2][1]) > Delay)) {
MIDI.sendNoteOn(1, 47, velocity);
lastA[2][1] = 7;
if (lastA[2][1] == 0) {
BounceAOff[2][1] = millis();
if ((keysA[2][1] == 1) and (lastA[2][1] == 7) and ((millis() - BounceAOff[2][1]) > Delay)) {
MIDI.sendNoteOff(1, 47, velocity);
lastA[2][1] = 0;
//A48
if (lastA[2][2] == 7) {
BounceAOn[2][2] = millis();
if ((keysA[2][2] == 0) and (lastA[2][2] == 0) and ((millis() - BounceAOn[2][2]) > Delay)) {
MIDI.sendNoteOn(1, 48, velocity);
lastA[2][2] = 7;
if (lastA[2][2] == 0) {
BounceAOff[2][2] = millis();
if ((keysA[2][2] == 1) and (lastA[2][2] == 7) and ((millis() - BounceAOff[2][2]) > Delay)) {
MIDI.sendNoteOff(1, 48, velocity);
lastA[2][2] = 0;
//A49
if (lastA[2][3] == 7) {
BounceAOn[2][3] = millis();
if ((keysA[2][3] == 0) and (lastA[2][3] == 0) and ((millis() - BounceAOn[2][3]) > Delay)) {
MIDI.sendNoteOn(1, 49, velocity);
lastA[2][3] = 7;
if (lastA[2][3] == 0) {
BounceAOff[2][3] = millis();
if ((keysA[2][3] == 1) and (lastA[2][3] == 7) and ((millis() - BounceAOff[2][3]) > Delay)) {
MIDI.sendNoteOff(1, 49, velocity);
lastA[2][3] = 0;
//A50
if (lastA[2][4] == 7) {
BounceAOn[2][4] = millis();
if ((keysA[2][4] == 0) and (lastA[2][4] == 0) and ((millis() - BounceAOn[2][4]) > Delay)) {
MIDI.sendNoteOn(1, 50, velocity);
lastA[2][4] = 7;
if (lastA[2][4] == 0) {
BounceAOff[2][4] = millis();
if ((keysA[2][4] == 1) and (lastA[2][4] == 7) and ((millis() - BounceAOff[2][4]) > Delay)) {
MIDI.sendNoteOff(1, 50, velocity);
lastA[2][4] = 0;
//A51
if (lastA[2][5] == 7) {
BounceAOn[2][5] = millis();
if ((keysA[2][5] == 0) and (lastA[2][5] == 0) and ((millis() - BounceAOn[2][5]) > Delay)) {
MIDI.sendNoteOn(1, 51, velocity);
lastA[2][5] = 7;
if (lastA[2][5] == 0) {
BounceAOff[2][5] = millis();
if ((keysA[2][5] == 1) and (lastA[2][5] == 7) and ((millis() - BounceAOff[2][5]) > Delay)) {
MIDI.sendNoteOff(1, 51, velocity);
lastA[2][5] = 0;
//A52
if (lastA[2][6] == 7) {
BounceAOn[2][6] = millis();
if ((keysA[2][6] == 0) and (lastA[2][6] == 0) and ((millis() - BounceAOn[2][6]) > Delay)) {
MIDI.sendNoteOn(1, 52, velocity);
lastA[2][6] = 7;
if (lastA[2][6] == 0) {
BounceAOff[2][6] = millis();
if ((keysA[2][6] == 1) and (lastA[2][6] == 7) and ((millis() - BounceAOff[2][6]) > Delay)) {
MIDI.sendNoteOff(1, 52, velocity);
lastA[2][6] = 0;
//A53
if (lastA[2][7] == 7) {
BounceAOn[2][7] = millis();
if ((keysA[2][7] == 0) and (lastA[2][7] == 0) and ((millis() - BounceAOn[2][7]) > Delay)) {
MIDI.sendNoteOn(1, 53, velocity);
lastA[2][7] = 7;
if (lastA[2][7] == 0) {
BounceAOff[2][7] = millis();
if ((keysA[2][7] == 1) and (lastA[2][7] == 7) and ((millis() - BounceAOff[2][7]) > Delay)) {
MIDI.sendNoteOff(1, 53, velocity);
lastA[2][7] = 0;
//A54
if (lastA[3][0] == 7) {
BounceAOn[3][0] = millis();
if ((keysA[3][0] == 0) and (lastA[3][0] == 0) and ((millis() - BounceAOn[3][0]) > Delay)) {
MIDI.sendNoteOn(1, 54, velocity);
lastA[3][0] = 7;
if (lastA[3][0] == 0) {
BounceAOff[3][0] = millis();
if ((keysA[3][0] == 1) and (lastA[3][0] == 7) and ((millis() - BounceAOff[3][0]) > Delay)) {
MIDI.sendNoteOff(1, 54, velocity);
lastA[3][0] = 0;
//A55
if (lastA[3][1] == 7) {
BounceAOn[3][1] = millis();
if ((keysA[3][1] == 0) and (lastA[3][1] == 0) and ((millis() - BounceAOn[3][1]) > Delay)) {
MIDI.sendNoteOn(1, 55, velocity);
lastA[3][1] = 7;
if (lastA[3][1] == 0) {
BounceAOff[3][1] = millis();
if ((keysA[3][1] == 1) and (lastA[3][1] == 7) and ((millis() - BounceAOff[3][1]) > Delay)) {
MIDI.sendNoteOff(1, 55, velocity);
lastA[3][1] = 0;
//A56
if (lastA[3][2] == 7) {
BounceAOn[3][2] = millis();
if ((keysA[3][2] == 0) and (lastA[3][2] == 0) and ((millis() - BounceAOn[3][2]) > Delay)) {
MIDI.sendNoteOn(1, 56, velocity);
lastA[3][2] = 7;
if (lastA[3][2] == 0) {
BounceAOff[3][2] = millis();
if ((keysA[3][2] == 1) and (lastA[3][2] == 7) and ((millis() - BounceAOff[3][2]) > Delay)) {
MIDI.sendNoteOff(1, 56, velocity);
lastA[3][2] = 0;
//A57
if (lastA[3][3] == 7) {
BounceAOn[3][3] = millis();
if ((keysA[3][3] == 0) and (lastA[3][3] == 0) and ((millis() - BounceAOn[3][3]) > Delay)) {
MIDI.sendNoteOn(1, 57, velocity);
lastA[3][3] = 7;
if (lastA[3][3] == 0) {
BounceAOff[3][3] = millis();
if ((keysA[3][3] == 1) and (lastA[3][3] == 7) and ((millis() - BounceAOff[3][3]) > Delay)) {
MIDI.sendNoteOff(1, 57, velocity);
lastA[3][3] = 0;
//A58
if (lastA[3][4] == 7) {
BounceAOn[3][4] = millis();
if ((keysA[3][4] == 0) and (lastA[3][4] == 0) and ((millis() - BounceAOn[3][4]) > Delay)) {
MIDI.sendNoteOn(1, 58, velocity);
lastA[3][4] = 7;
if (lastA[3][4] == 0) {
BounceAOff[3][4] = millis();
if ((keysA[3][4] == 1) and (lastA[3][4] == 7) and ((millis() - BounceAOff[3][4]) > Delay)) {
MIDI.sendNoteOff(1, 58, velocity);
lastA[3][4] = 0;
//A59
if (lastA[3][5] == 7) {
BounceAOn[3][5] = millis();
if ((keysA[3][5] == 0) and (lastA[3][5] == 0) and ((millis() - BounceAOn[3][5]) > Delay)) {
MIDI.sendNoteOn(1, 59, velocity);
lastA[3][5] = 7;
if (lastA[3][5] == 0) {
BounceAOff[3][5] = millis();
if ((keysA[3][5] == 1) and (lastA[3][5] == 7) and ((millis() - BounceAOff[3][5]) > Delay)) {
MIDI.sendNoteOff(1, 59, velocity);
lastA[3][5] = 0;
//A60
if (lastA[3][6] == 7) {
BounceAOn[3][6] = millis();
if ((keysA[3][6] == 0) and (lastA[3][6] == 0) and ((millis() - BounceAOn[3][6]) > Delay)) {
MIDI.sendNoteOn(1, 60, velocity);
lastA[3][6] = 7;
if (lastA[3][6] == 0) {
BounceAOff[3][6] = millis();
if ((keysA[3][6] == 1) and (lastA[3][6] == 7) and ((millis() - BounceAOff[3][6]) > Delay)) {
MIDI.sendNoteOff(1, 60, velocity);
lastA[3][6] = 0;
//A61
if (lastA[3][7] == 7) {
BounceAOn[3][7] = millis();
if ((keysA[3][7] == 0) and (lastA[3][7] == 0) and ((millis() - BounceAOn[3][7]) > Delay)) {
MIDI.sendNoteOn(1, 61, velocity);
lastA[3][7] = 7;
if (lastA[3][7] == 0) {
BounceAOff[3][7] = millis();
if ((keysA[3][7] == 1) and (lastA[3][7] == 7) and ((millis() - BounceAOff[3][7]) > Delay)) {
MIDI.sendNoteOff(1, 61, velocity);
lastA[3][7] = 0;
//A62
if (lastA[4][0] == 7) {
BounceAOn[4][0] = millis();
if ((keysA[4][0] == 0) and (lastA[4][0] == 0) and ((millis() - BounceAOn[4][0]) > Delay)) {
MIDI.sendNoteOn(1, 62, velocity);
lastA[4][0] = 7;
if (lastA[4][0] == 0) {
BounceAOff[4][0] = millis();
if ((keysA[4][0] == 1) and (lastA[4][0] == 7) and ((millis() - BounceAOff[4][0]) > Delay)) {
MIDI.sendNoteOff(1, 62, velocity);
lastA[4][0] = 0;
//A63
if (lastA[4][1] == 7) {
BounceAOn[4][1] = millis();
if ((keysA[4][1] == 0) and (lastA[4][1] == 0) and ((millis() - BounceAOn[4][1]) > Delay)) {
MIDI.sendNoteOn(1, 63, velocity);
lastA[4][1] = 7;
if (lastA[4][1] == 0) {
BounceAOff[4][1] = millis();
if ((keysA[4][1] == 1) and (lastA[4][1] == 7) and ((millis() - BounceAOff[4][1]) > Delay)) {
MIDI.sendNoteOff(1, 63, velocity);
lastA[4][1] = 0;
//A64
if (lastA[4][2] == 7) {
BounceAOn[4][2] = millis();
if ((keysA[4][2] == 0) and (lastA[4][2] == 0) and ((millis() - BounceAOn[4][2]) > Delay)) {
MIDI.sendNoteOn(1, 64, velocity);
lastA[4][2] = 7;
if (lastA[4][2] == 0) {
BounceAOff[4][2] = millis();
if ((keysA[4][2] == 1) and (lastA[4][2] == 7) and ((millis() - BounceAOff[4][2]) > Delay)) {
MIDI.sendNoteOff(1, 64, velocity);
lastA[4][2] = 0;
//A65
if (lastA[4][3] == 7) {
BounceAOn[4][3] = millis();
if ((keysA[4][3] == 0) and (lastA[4][3] == 0) and ((millis() - BounceAOn[4][3]) > Delay)) {
MIDI.sendNoteOn(1, 65, velocity);
lastA[4][3] = 7;
if (lastA[4][3] == 0) {
BounceAOff[4][3] = millis();
if ((keysA[4][3] == 1) and (lastA[4][3] == 7) and ((millis() - BounceAOff[4][3]) > Delay)) {
MIDI.sendNoteOff(1, 65, velocity);
lastA[4][3] = 0;
//66
if (lastA[4][4] == 7) {
BounceAOn[4][4] = millis();
if ((keysA[4][4] == 0) and (lastA[4][4] == 0) and ((millis() - BounceAOn[4][4]) > Delay)) {
MIDI.sendNoteOn(1, 66, velocity);
lastA[4][4] = 7;
if (lastA[4][4] == 0) {
BounceAOff[4][4] = millis();
if ((keysA[4][4] == 1) and (lastA[4][4] == 7) and ((millis() - BounceAOff[4][4]) > Delay)) {
MIDI.sendNoteOff(1, 66, velocity);
lastA[4][4] = 0;
//A67
if (lastA[4][5] == 7) {
BounceAOn[4][5] = millis();
if ((keysA[4][5] == 0) and (lastA[4][5] == 0) and ((millis() - BounceAOn[4][5]) > Delay)) {
MIDI.sendNoteOn(1, 67, velocity);
lastA[4][5] = 7;
if (lastA[4][5] == 0) {
BounceAOff[4][5] = millis();
if ((keysA[4][5] == 1) and (lastA[4][5] == 7) and ((millis() - BounceAOff[4][5]) > Delay)) {
MIDI.sendNoteOff(1, 67, velocity);
lastA[4][5] = 0;
//A68
if (lastA[4][6] == 7) {
BounceAOn[4][6] = millis();
if ((keysA[4][6] == 0) and (lastA[4][6] == 0) and ((millis() - BounceAOn[4][6]) > Delay)) {
MIDI.sendNoteOn(1, 68, velocity);
lastA[4][6] = 7;
if (lastA[4][6] == 0) {
BounceAOff[4][6] = millis();
if ((keysA[4][6] == 1) and (lastA[4][6] == 7) and ((millis() - BounceAOff[4][6]) > Delay)) {
MIDI.sendNoteOff(1, 68, velocity);
lastA[4][6] = 0;
//A69
if (lastA[4][7] == 7) {
BounceAOn[4][7] = millis();
if ((keysA[4][7] == 0) and (lastA[4][7] == 0) and ((millis() - BounceAOn[4][7]) > Delay)) {
MIDI.sendNoteOn(1, 69, velocity);
lastA[4][7] = 7;
if (lastA[4][7] == 0) {
BounceAOff[4][7] = millis();
if ((keysA[4][7] == 1) and (lastA[4][7] == 7) and ((millis() - BounceAOff[4][7]) > Delay)) {
MIDI.sendNoteOff(1, 69, velocity);
lastA[4][7] = 0;
//A70
if (lastA[5][0] == 7) {
BounceAOn[5][0] = millis();
if ((keysA[5][0] == 0) and (lastA[5][0] == 0) and ((millis() - BounceAOn[5][0]) > Delay)) {
MIDI.sendNoteOn(1, 70, velocity);
lastA[5][0] = 7;
if (lastA[5][0] == 0) {
BounceAOff[5][0] = millis();
if ((keysA[5][0] == 1) and (lastA[5][0] == 7) and ((millis() - BounceAOff[5][0]) > Delay)) {
MIDI.sendNoteOff(1, 70, velocity);
lastA[5][0] = 0;
//A71
if (lastA[5][1] == 7) {
BounceAOn[5][1] = millis();
if ((keysA[5][1] == 0) and (lastA[5][1] == 0) and ((millis() - BounceAOn[5][1]) > Delay)) {
MIDI.sendNoteOn(1, 71, velocity);
lastA[5][1] = 7;
if (lastA[5][1] == 0) {
BounceAOff[5][1] = millis();
if ((keysA[5][1] == 1) and (lastA[5][1] == 7) and ((millis() - BounceAOff[5][1]) > Delay)) {
MIDI.sendNoteOff(1, 71, velocity);
lastA[5][1] = 0;
//A72
if (lastA[5][2] == 7) {
BounceAOn[5][2] = millis();
if ((keysA[5][2] == 0) and (lastA[5][2] == 0) and ((millis() - BounceAOn[5][2]) > Delay)) {
MIDI.sendNoteOn(1, 72, velocity);
lastA[5][2] = 7;
if (lastA[5][2] == 0) {
BounceAOff[5][2] = millis();
if ((keysA[5][2] == 1) and (lastA[5][2] == 7) and ((millis() - BounceAOff[5][2]) > Delay)) {
MIDI.sendNoteOff(1, 72, velocity);
lastA[5][2] = 0;
//A73
if (lastA[5][3] == 7) {
BounceAOn[5][3] = millis();
if ((keysA[5][3] == 0) and (lastA[5][3] == 0) and ((millis() - BounceAOn[5][3]) > Delay)) {
MIDI.sendNoteOn(1, 73, velocity);
lastA[5][3] = 7;
if (lastA[5][3] == 0) {
BounceAOff[5][3] = millis();
if ((keysA[5][3] == 1) and (lastA[5][3] == 7) and ((millis() - BounceAOff[5][3]) > Delay)) {
MIDI.sendNoteOff(1, 73, velocity);
lastA[5][3] = 0;
//A74
if (lastA[5][4] == 7) {
BounceAOn[5][4] = millis();
if ((keysA[5][4] == 0) and (lastA[5][4] == 0) and ((millis() - BounceAOn[5][4]) > Delay)) {
MIDI.sendNoteOn(1, 74, velocity);
lastA[5][4] = 7;
if (lastA[5][4] == 0) {
BounceAOff[5][4] = millis();
if ((keysA[5][4] == 1) and (lastA[5][4] == 7) and ((millis() - BounceAOff[5][4]) > Delay)) {
MIDI.sendNoteOff(1, 74, velocity);
lastA[5][4] = 0;
//A75
if (lastA[5][5] == 7) {
BounceAOn[5][5] = millis();
if ((keysA[5][5] == 0) and (lastA[5][5] == 0) and ((millis() - BounceAOn[5][5]) > Delay)) {
MIDI.sendNoteOn(1, 75, velocity);
lastA[5][5] = 7;
if (lastA[5][5] == 0) {
BounceAOff[5][5] = millis();
if ((keysA[5][5] == 1) and (lastA[5][5] == 7) and ((millis() - BounceAOff[5][5]) > Delay)) {
MIDI.sendNoteOff(1, 75, velocity);
lastA[5][5] = 0;
//A76
if (lastA[5][6] == 7) {
BounceAOn[5][6] = millis();
if ((keysA[5][6] == 0) and (lastA[5][6] == 0) and ((millis() - BounceAOn[5][6]) > Delay)) {
MIDI.sendNoteOn(1, 76, velocity);
lastA[5][6] = 7;
if (lastA[5][6] == 0) {
BounceAOff[5][6] = millis();
if ((keysA[5][6] == 1) and (lastA[5][6] == 7) and ((millis() - BounceAOff[5][6]) > Delay)) {
MIDI.sendNoteOff(1, 76, velocity);
lastA[5][6] = 0;
//A77
if (lastA[5][7] == 7) {
BounceAOn[5][7] = millis();
if ((keysA[5][7] == 0) and (lastA[5][7] == 0) and ((millis() - BounceAOn[5][7]) > Delay)) {
MIDI.sendNoteOn(1, 77, velocity);
lastA[5][7] = 7;
if (lastA[5][7] == 0) {
BounceAOff[5][7] = millis();
if ((keysA[5][7] == 1) and (lastA[5][7] == 7) and ((millis() - BounceAOff[5][7]) > Delay)) {
MIDI.sendNoteOff(1, 77, velocity);
lastA[5][7] = 0;
//A78
if (lastA[6][0] == 7) {
BounceAOn[6][0] = millis();
if ((keysA[6][0] == 0) and (lastA[6][0] == 0) and ((millis() - BounceAOn[6][0]) > Delay)) {
MIDI.sendNoteOn(1, 78, velocity);
lastA[6][0] = 7;
if (lastA[6][0] == 0) {
BounceAOff[6][0] = millis();
if ((keysA[6][0] == 1) and (lastA[6][0] == 7) and ((millis() - BounceAOff[6][0]) > Delay)) {
MIDI.sendNoteOff(1, 78, velocity);
lastA[6][0] = 0;
//A79
if (lastA[6][1] == 7) {
BounceAOn[6][1] = millis();
if ((keysA[6][1] == 0) and (lastA[6][1] == 0) and ((millis() - BounceAOn[6][1]) > Delay)) {
MIDI.sendNoteOn(1, 79, velocity);
lastA[6][1] = 7;
if (lastA[6][1] == 0) {
BounceAOff[6][1] = millis();
if ((keysA[6][1] == 1) and (lastA[6][1] == 7) and ((millis() - BounceAOff[6][1]) > Delay)) {
MIDI.sendNoteOff(1, 79, velocity);
lastA[6][1] = 0;
//A80
if (lastA[6][2] == 7) {
BounceAOn[6][2] = millis();
if ((keysA[6][2] == 0) and (lastA[6][2] == 0) and ((millis() - BounceAOn[6][2]) > Delay)) {
MIDI.sendNoteOn(1, 80, velocity);
lastA[6][2] = 7;
if (lastA[6][2] == 0) {
BounceAOff[6][2] = millis();
if ((keysA[6][2] == 1) and (lastA[6][2] == 7) and ((millis() - BounceAOff[6][2]) > Delay)) {
MIDI.sendNoteOff(1, 80, velocity);
lastA[6][2] = 0;
//A81
if (lastA[6][3] == 7) {
BounceAOn[6][3] = millis();
if ((keysA[6][3] == 0) and (lastA[6][3] == 0) and ((millis() - BounceAOn[6][3]) > Delay)) {
MIDI.sendNoteOn(1, 81, velocity);
lastA[6][3] = 7;
if (lastA[6][3] == 0) {
BounceAOff[6][3] = millis();
if ((keysA[6][3] == 1) and (lastA[6][3] == 7) and ((millis() - BounceAOff[6][3]) > Delay)) {
MIDI.sendNoteOff(1, 81, velocity);
lastA[6][3] = 0;
//A82
if (lastA[6][4] == 7) {
BounceAOn[6][4] = millis();
if ((keysA[6][4] == 0) and (lastA[6][4] == 0) and ((millis() - BounceAOn[6][4]) > Delay)) {
MIDI.sendNoteOn(1, 82, velocity);
lastA[6][4] = 7;
if (lastA[6][4] == 0) {
BounceAOff[6][4] = millis();
if ((keysA[6][4] == 1) and (lastA[6][4] == 7) and ((millis() - BounceAOff[6][4]) > Delay)) {
MIDI.sendNoteOff(1, 82, velocity);
lastA[6][4] = 0;
//A83
if (lastA[6][5] == 7) {
BounceAOn[6][5] = millis();
if ((keysA[6][5] == 0) and (lastA[6][5] == 0) and ((millis() - BounceAOn[6][5]) > Delay)) {
MIDI.sendNoteOn(1, 83, velocity);
lastA[6][5] = 7;
if (lastA[6][5] == 0) {
BounceAOff[6][5] = millis();
if ((keysA[6][5] == 1) and (lastA[6][5] == 7) and ((millis() - BounceAOff[6][5]) > Delay)) {
MIDI.sendNoteOff(1, 83, velocity);
lastA[6][5] = 0;
//A84
if (lastA[6][6] == 7) {
BounceAOn[6][6] = millis();
if ((keysA[6][6] == 0) and (lastA[6][6] == 0) and ((millis() - BounceAOn[6][6]) > Delay)) {
MIDI.sendNoteOn(1, 84, velocity);
lastA[6][6] = 7;
if (lastA[6][6] == 0) {
BounceAOff[6][6] = millis();
if ((keysA[6][6] == 1) and (lastA[6][6] == 7) and ((millis() - BounceAOff[6][6]) > Delay)) {
MIDI.sendNoteOff(1, 84, velocity);
lastA[6][6] = 0;
//A85
if (lastA[6][7] == 7) {
BounceAOn[6][7] = millis();
if ((keysA[6][7] == 0) and (lastA[6][7] == 0) and ((millis() - BounceAOn[6][7]) > Delay)) {
MIDI.sendNoteOn(1, 85, velocity);
lastA[6][7] = 7;
if (lastA[6][7] == 0) {
BounceAOff[6][7] = millis();
if ((keysA[6][7] == 1) and (lastA[6][7] == 7) and ((millis() - BounceAOff[6][7]) > Delay)) {
MIDI.sendNoteOff(1, 85, velocity);
lastA[6][7] = 0;
//A86
if (lastA[7][0] == 7) {
BounceAOn[7][0] = millis();
if ((keysA[7][0] == 0) and (lastA[7][0] == 0) and ((millis() - BounceAOn[7][0]) > Delay)) {
MIDI.sendNoteOn(1, 86, velocity);
lastA[7][0] = 7;
if (lastA[7][0] == 0) {
BounceAOff[7][0] = millis();
if ((keysA[7][0] == 1) and (lastA[7][0] == 7) and ((millis() - BounceAOff[7][0]) > Delay)) {
MIDI.sendNoteOff(1, 86, velocity);
lastA[7][0] = 0;
//A87
if (lastA[7][1] == 7) {
BounceAOn[7][1] = millis();
if ((keysA[7][1] == 0) and (lastA[7][1] == 0) and ((millis() - BounceAOn[7][1]) > Delay)) {
MIDI.sendNoteOn(1, 87, velocity);
lastA[7][1] = 7;
if (lastA[7][1] == 0) {
BounceAOff[7][1] = millis();
if ((keysA[7][1] == 1) and (lastA[7][1] == 7) and ((millis() - BounceAOff[7][1]) > Delay)) {
MIDI.sendNoteOff(1, 87, velocity);
lastA[7][1] = 0;
//A88
if (lastA[7][2] == 7) {
BounceAOn[7][2] = millis();
if ((keysA[7][2] == 0) and (lastA[7][2] == 0) and ((millis() - BounceAOn[7][2]) > Delay)) {
MIDI.sendNoteOn(1, 88, velocity);
lastA[7][2] = 7;
if (lastA[7][2] == 0) {
BounceAOff[7][2] = millis();
if ((keysA[7][2] == 1) and (lastA[7][2] == 7) and ((millis() - BounceAOff[7][2]) > Delay)) {
MIDI.sendNoteOff(1, 88, velocity);
lastA[7][2] = 0;
//A89
if (lastA[7][3] == 7) {
BounceAOn[7][3] = millis();
if ((keysA[7][3] == 0) and (lastA[7][3] == 0) and ((millis() - BounceAOn[7][3]) > Delay)) {
MIDI.sendNoteOn(1, 89, velocity);
lastA[7][3] = 7;
if (lastA[7][3] == 0) {
BounceAOff[7][3] = millis();
if ((keysA[7][3] == 1) and (lastA[7][3] == 7) and ((millis() - BounceAOff[7][3]) > Delay)) {
MIDI.sendNoteOff(1, 89, velocity);
lastA[7][3] = 0;
//A90
if (lastA[7][4] == 7) {
BounceAOn[7][4] = millis();
if ((keysA[7][4] == 0) and (lastA[7][4] == 0) and ((millis() - BounceAOn[7][4]) > Delay)) {
MIDI.sendNoteOn(1, 90, velocity);
lastA[7][4] = 7;
if (lastA[7][4] == 0) {
BounceAOff[7][4] = millis();
if ((keysA[7][4] == 1) and (lastA[7][4] == 7) and ((millis() - BounceAOff[7][4]) > Delay)) {
MIDI.sendNoteOff(1, 90, velocity);
lastA[7][4] = 0;
//A91
if (lastA[7][5] == 7) {
BounceAOn[7][5] = millis();
if ((keysA[7][5] == 0) and (lastA[7][5] == 0) and ((millis() - BounceAOn[7][5]) > Delay)) {
MIDI.sendNoteOn(1, 91, velocity);
lastA[7][5] = 7;
if (lastA[7][5] == 0) {
BounceAOff[7][5] = millis();
if ((keysA[7][5] == 1) and (lastA[7][5] == 7) and ((millis() - BounceAOff[7][5]) > Delay)) {
MIDI.sendNoteOff(1, 91, velocity);
lastA[7][5] = 0;
//A92
if (lastA[7][6] == 7) {
BounceAOn[7][6] = millis();
if ((keysA[7][6] == 0) and (lastA[7][6] == 0) and ((millis() - BounceAOn[7][6]) > Delay)) {
MIDI.sendNoteOn(1, 92, velocity);
lastA[7][6] = 7;
if (lastA[7][6] == 0) {
BounceAOff[7][6] = millis();
if ((keysA[7][6] == 1) and (lastA[7][6] == 7) and ((millis() - BounceAOff[7][6]) > Delay)) {
MIDI.sendNoteOff(1, 92, velocity);
lastA[7][6] = 0;
//A93
if (lastA[7][7] == 7) {
BounceAOn[7][7] = millis();
if ((keysA[7][7] == 0) and (lastA[7][7] == 0) and ((millis() - BounceAOn[7][7]) > Delay)) {
MIDI.sendNoteOn(1, 93, velocity);
lastA[7][7] = 7;
if (lastA[7][7] == 0) {
BounceAOff[7][7] = millis();
if ((keysA[7][7] == 1) and (lastA[7][7] == 7) and ((millis() - BounceAOff[7][7]) > Delay)) {
MIDI.sendNoteOff(1, 93, velocity);
lastA[7][7] = 0;
//A94
if (lastA[8][0] == 7) {
BounceAOn[8][0] = millis();
if ((keysA[8][0] == 0) and (lastA[8][0] == 0) and ((millis() - BounceAOn[8][0]) > Delay)) {
MIDI.sendNoteOn(1, 94, velocity);
lastA[8][0] = 7;
if (lastA[8][0] == 0) {
BounceAOff[8][0] = millis();
if ((keysA[8][0] == 1) and (lastA[8][0] == 7) and ((millis() - BounceAOff[8][0]) > Delay)) {
MIDI.sendNoteOff(1, 94, velocity);
lastA[8][0] = 0;
//A95
if (lastA[8][1] == 7) {
BounceAOn[8][1] = millis();
if ((keysA[8][1] == 0) and (lastA[8][1] == 0) and ((millis() - BounceAOn[8][1]) > Delay)) {
MIDI.sendNoteOn(1, 95, velocity);
lastA[8][1] = 7;
if (lastA[8][1] == 0) {
BounceAOff[8][1] = millis();
if ((keysA[8][1] == 1) and (lastA[8][1] == 7) and ((millis() - BounceAOff[8][1]) > Delay)) {
MIDI.sendNoteOff(1, 95, velocity);
lastA[8][1] = 0;
//A96
if (lastA[8][2] == 7) {
BounceAOn[8][2] = millis();
if ((keysA[8][2] == 0) and (lastA[8][2] == 0) and ((millis() - BounceAOn[8][2]) > Delay)) {
MIDI.sendNoteOn(1, 96, velocity);
lastA[8][2] = 7;
if (lastA[8][2] == 0) {
BounceAOff[8][2] = millis();
if ((keysA[8][2] == 1) and (lastA[8][2] == 7) and ((millis() - BounceAOff[8][2]) > Delay)) {
MIDI.sendNoteOff(1, 96, velocity);
lastA[8][2] = 0;
//A97
if (lastA[8][3] == 7) {
BounceAOn[8][3] = millis();
if ((keysA[8][3] == 0) and (lastA[8][3] == 0) and ((millis() - BounceAOn[8][3]) > Delay)) {
MIDI.sendNoteOn(1, 97, velocity);
lastA[8][3] = 7;
if (lastA[8][3] == 0) {
BounceAOff[8][3] = millis();
if ((keysA[8][3] == 1) and (lastA[8][3] == 7) and ((millis() - BounceAOff[8][3]) > Delay)) {
MIDI.sendNoteOff(1, 97, velocity);
lastA[8][3] = 0;
//A98
if (lastA[8][4] == 7) {
BounceAOn[8][4] = millis();
if ((keysA[8][4] == 0) and (lastA[8][4] == 0) and ((millis() - BounceAOn[8][4]) > Delay)) {
MIDI.sendNoteOn(1, 98, velocity);
lastA[8][4] = 7;
if (lastA[8][4] == 0) {
BounceAOff[8][4] = millis();
if ((keysA[8][4] == 1) and (lastA[8][4] == 7) and ((millis() - BounceAOff[8][4]) > Delay)) {
MIDI.sendNoteOff(1, 98, velocity);
lastA[8][4] = 0;
//A99
if (lastA[8][5] == 7) {
BounceAOn[8][5] = millis();
if ((keysA[8][5] == 0) and (lastA[8][5] == 0) and ((millis() - BounceAOn[8][5]) > Delay)) {
MIDI.sendNoteOn(1, 99, velocity);
lastA[8][5] = 7;
if (lastA[8][5] == 0) {
BounceAOff[8][5] = millis();
if ((keysA[8][5] == 1) and (lastA[8][5] == 7) and ((millis() - BounceAOff[8][5]) > Delay)) {
MIDI.sendNoteOff(1, 99, velocity);
lastA[8][5] = 0;
//A100
if (lastA[8][6] == 7) {
BounceAOn[8][6] = millis();
if ((keysA[8][6] == 0) and (lastA[8][6] == 0) and ((millis() - BounceAOn[8][6]) > Delay)) {
MIDI.sendNoteOn(1, 100, velocity);
lastA[8][6] = 7;
if (lastA[8][6] == 0) {
BounceAOff[8][6] = millis();
if ((keysA[8][6] == 1) and (lastA[8][6] == 7) and ((millis() - BounceAOff[8][6]) > Delay)) {
MIDI.sendNoteOff(1, 100, velocity);
lastA[8][6] = 0;
//A101
if (lastA[8][7] == 7) {
BounceAOn[8][7] = millis();
if ((keysA[8][7] == 0) and (lastA[8][7] == 0) and ((millis() - BounceAOn[8][7]) > Delay)) {
MIDI.sendNoteOn(1, 101, velocity);
lastA[8][7] = 7;
if (lastA[8][7] == 0) {
BounceAOff[8][7] = millis();
if ((keysA[8][7] == 1) and (lastA[8][7] == 7) and ((millis() - BounceAOff[8][7]) > Delay)) {
MIDI.sendNoteOff(1, 101, velocity);
lastA[8][7] = 0;
//A102
if (lastA[9][0] == 7) {
BounceAOn[9][0] = millis();
if ((keysA[9][0] == 0) and (lastA[9][0] == 0) and ((millis() - BounceAOn[9][0]) > Delay)) {
MIDI.sendNoteOn(1, 102, velocity);
lastA[9][0] = 7;
if (lastA[9][0] == 0) {
BounceAOff[9][0] = millis();
if ((keysA[9][0] == 1) and (lastA[9][0] == 7) and ((millis() - BounceAOff[9][0]) > Delay)) {
MIDI.sendNoteOff(1, 102, velocity);
lastA[9][0] = 0;
//A103
if (lastA[9][1] == 7) {
BounceAOn[9][1] = millis();
if ((keysA[9][1] == 0) and (lastA[9][1] == 0) and ((millis() - BounceAOn[9][1]) > Delay)) {
MIDI.sendNoteOn(1, 103, velocity);
lastA[9][1] = 7;
if (lastA[9][1] == 0) {
BounceAOff[9][1] = millis();
if ((keysA[9][1] == 1) and (lastA[9][1] == 7) and ((millis() - BounceAOff[9][1]) > Delay)) {
MIDI.sendNoteOff(1, 103, velocity);
lastA[9][1] = 0;
//A104
if (lastA[9][2] == 7) {
BounceAOn[9][2] = millis();
if ((keysA[9][2] == 0) and (lastA[9][2] == 0) and ((millis() - BounceAOn[9][2]) > Delay)) {
MIDI.sendNoteOn(1, 104, velocity);
lastA[9][2] = 7;
if (lastA[9][2] == 0) {
BounceAOff[9][2] = millis();
if ((keysA[9][2] == 1) and (lastA[9][2] == 7) and ((millis() - BounceAOff[9][2]) > Delay)) {
MIDI.sendNoteOff(1, 104, velocity);
lastA[9][2] = 0;
//A105
if (lastA[9][3] == 7) {
BounceAOn[9][3] = millis();
if ((keysA[9][3] == 0) and (lastA[9][3] == 0) and ((millis() - BounceAOn[9][3]) > Delay)) {
MIDI.sendNoteOn(1, 105, velocity);
lastA[9][3] = 7;
if (lastA[9][3] == 0) {
BounceAOff[9][3] = millis();
if ((keysA[9][3] == 1) and (lastA[9][3] == 7) and ((millis() - BounceAOff[9][3]) > Delay)) {
MIDI.sendNoteOff(1, 105, velocity);
lastA[9][3] = 0;
//A106
if (lastA[9][4] == 7) {
BounceAOn[9][4] = millis();
if ((keysA[9][4] == 0) and (lastA[9][4] == 0) and ((millis() - BounceAOn[9][4]) > Delay)) {
MIDI.sendNoteOn(1, 106, velocity);
lastA[9][4] = 7;
if (lastA[9][4] == 0) {
BounceAOff[9][4] = millis();
if ((keysA[9][4] == 1) and (lastA[9][4] == 7) and ((millis() - BounceAOff[9][4]) > Delay)) {
MIDI.sendNoteOff(1, 106, velocity);
lastA[9][4] = 0;
//A107
if (lastA[9][5] == 7) {
BounceAOn[9][5] = millis();
if ((keysA[9][5] == 0) and (lastA[9][5] == 0) and ((millis() - BounceAOn[9][5]) > Delay)) {
MIDI.sendNoteOn(1, 107, velocity);
lastA[9][5] = 7;
if (lastA[9][5] == 0) {
BounceAOff[9][5] = millis();
if ((keysA[9][5] == 1) and (lastA[9][5] == 7) and ((millis() - BounceAOff[9][5]) > Delay)) {
MIDI.sendNoteOff(1, 107, velocity);
lastA[9][5] = 0;
//A108
if (lastA[9][6] == 7) {
BounceAOn[9][6] = millis();
if ((keysA[9][6] == 0) and (lastA[9][6] == 0) and ((millis() - BounceAOn[9][6]) > Delay)) {
MIDI.sendNoteOn(1, 108, velocity);
lastA[9][6] = 7;
if (lastA[9][6] == 0) {
BounceAOff[9][6] = millis();
if ((keysA[9][6] == 1) and (lastA[9][6] == 7) and ((millis() - BounceAOff[9][6]) > Delay)) {
MIDI.sendNoteOff(1, 108, velocity);
lastA[9][6] = 0;
//A109
if (lastA[9][7] == 7) {
BounceAOn[9][7] = millis();
if ((keysA[9][7] == 0) and (lastA[9][7] == 0) and ((millis() - BounceAOn[9][7]) > Delay)) {
MIDI.sendNoteOn(1, 109, velocity);
lastA[9][7] = 7;
if (lastA[9][7] == 0) {
BounceAOff[9][7] = millis();
if ((keysA[9][7] == 1) and (lastA[9][7] == 7) and ((millis() - BounceAOff[9][7]) > Delay)) {
MIDI.sendNoteOff(1, 109, velocity);
lastA[9][7] = 0;
//A110 LEFT OFF HERE_____________________________________
if (lastA[10][0] == 7) {
BounceAOn[10][0] = millis();
if ((keysA[10][0] == 0) and (lastA[10][0] == 0) and ((millis() - BounceAOn[10][0]) > Delay)) {
MIDI.sendNoteOn(1, 110, velocity);
lastA[10][0] = 7;
if (lastA[10][0] == 0) {
BounceAOff[10][0] = millis();
if ((keysA[10][0] == 1) and (lastA[10][0] == 7) and ((millis() - BounceAOff[10][0]) > Delay)) {
MIDI.sendNoteOff(1, 110, velocity);
lastA[10][0] = 0;
//A111
if (lastA[10][1] == 7) {
BounceAOn[10][1] = millis();
if ((keysA[10][1] == 0) and (lastA[10][1] == 0) and ((millis() - BounceAOn[10][1]) > Delay)) {
MIDI.sendNoteOn(1, 111, velocity);
lastA[10][1] = 7;
if (lastA[10][1] == 0) {
BounceAOff[10][1] = millis();
if ((keysA[10][1] == 1) and (lastA[10][1] == 7) and ((millis() - BounceAOff[10][1]) > Delay)) {
MIDI.sendNoteOff(1, 111, velocity);
lastA[10][1] = 0;
//A112
if (lastA[10][2] == 7) {
BounceAOn[10][2] = millis();
if ((keysA[10][2] == 0) and (lastA[10][2] == 0) and ((millis() - BounceAOn[10][2]) > Delay)) {
MIDI.sendNoteOn(1, 112, velocity);
lastA[10][2] = 7;
if (lastA[10][2] == 0) {
BounceAOff[10][2] = millis();
if ((keysA[10][2] == 1) and (lastA[10][2] == 7) and ((millis() - BounceAOff[10][2]) > Delay)) {
MIDI.sendNoteOff(1, 112, velocity);
lastA[10][2] = 0;
//A113
if (lastA[10][3] == 7) {
BounceAOn[10][3] = millis();
if ((keysA[10][3] == 0) and (lastA[10][3] == 0) and ((millis() - BounceAOn[10][3]) > Delay)) {
MIDI.sendNoteOn(1, 113, velocity);
lastA[10][3] = 7;
if (lastA[10][3] == 0) {
BounceAOff[10][3] = millis();
if ((keysA[10][3] == 1) and (lastA[10][3] == 7) and ((millis() - BounceAOff[10][3]) > Delay)) {
MIDI.sendNoteOff(1, 113, velocity);
lastA[10][3] = 0;
//A114
if (lastA[10][4] == 7) {
BounceAOn[10][4] = millis();
if ((keysA[10][4] == 0) and (lastA[10][4] == 0) and ((millis() - BounceAOn[10][4]) > Delay)) {
MIDI.sendNoteOn(1, 114, velocity);
lastA[10][4] = 7;
if (lastA[10][4] == 0) {
BounceAOff[10][4] = millis();
if ((keysA[10][4] == 1) and (lastA[10][4] == 7) and ((millis() - BounceAOff[10][4]) > Delay)) {
MIDI.sendNoteOff(1, 114, velocity);
lastA[10][4] = 0;
//A115
if (lastA[10][5] == 7) {
BounceAOn[10][5] = millis();
if ((keysA[10][5] == 0) and (lastA[10][5] == 0) and ((millis() - BounceAOn[10][5]) > Delay)) {
MIDI.sendNoteOn(1, 115, velocity);
lastA[10][5] = 7;
if (lastA[10][5] == 0) {
BounceAOff[10][5] = millis();
if ((keysA[10][5] == 1) and (lastA[10][5] == 7) and ((millis() - BounceAOff[10][5]) > Delay)) {
MIDI.sendNoteOff(1, 115, velocity);
lastA[10][5] = 0;
//A116
if (lastA[10][6] == 7) {
BounceAOn[10][6] = millis();
if ((keysA[10][6] == 0) and (lastA[10][6] == 0) and ((millis() - BounceAOn[10][6]) > Delay)) {
MIDI.sendNoteOn(1, 116, velocity);
lastA[10][6] = 7;
if (lastA[10][6] == 0) {
BounceAOff[10][6] = millis();
if ((keysA[10][6] == 1) and (lastA[10][6] == 7) and ((millis() - BounceAOff[10][6]) > Delay)) {
MIDI.sendNoteOff(1, 116, velocity);
lastA[10][6] = 0;
//A117
if (lastA[10][7] == 7) {
BounceAOn[10][7] = millis();
if ((keysA[10][7] == 0) and (lastA[10][7] == 0) and ((millis() - BounceAOn[10][7]) > Delay)) {
MIDI.sendNoteOn(1, 117, velocity);
lastA[10][7] = 7;
if (lastA[10][7] == 0) {
BounceAOff[10][7] = millis();
if ((keysA[10][7] == 1) and (lastA[10][7] == 7) and ((millis() - BounceAOff[10][7]) > Delay)) {
MIDI.sendNoteOff(1, 117, velocity);
lastA[10][7] = 0;
//A118
if (lastA[11][0] == 7) {
BounceAOn[11][0] = millis();
if ((keysA[11][0] == 0) and (lastA[11][0] == 0) and ((millis() - BounceAOn[11][0]) > Delay)) {
MIDI.sendNoteOn(1, 118, velocity);
lastA[11][0] = 7;
if (lastA[11][0] == 0) {
BounceAOff[11][0] = millis();
if ((keysA[11][0] == 1) and (lastA[11][0] == 7) and ((millis() - BounceAOff[11][0]) > Delay)) {
MIDI.sendNoteOff(1, 118, velocity);
lastA[11][0] = 0;
//A119
if (lastA[11][1] == 7) {
BounceAOn[11][1] = millis();
if ((keysA[11][1] == 0) and (lastA[11][1] == 0) and ((millis() - BounceAOn[11][1]) > Delay)) {
MIDI.sendNoteOn(1, 119, velocity);
lastA[11][1] = 7;
if (lastA[11][1] == 0) {
BounceAOff[11][1] = millis();
if ((keysA[11][1] == 1) and (lastA[11][1] == 7) and ((millis() - BounceAOff[11][1]) > Delay)) {
MIDI.sendNoteOff(1, 119, velocity);
lastA[11][1] = 0;
//A120
if (lastA[11][2] == 7) {
BounceAOn[11][2] = millis();
if ((keysA[11][2] == 0) and (lastA[11][2] == 0) and ((millis() - BounceAOn[11][2]) > Delay)) {
MIDI.sendNoteOn(1, 120, velocity);
lastA[11][2] = 7;
if (lastA[11][2] == 0) {
BounceAOff[11][2] = millis();
if ((keysA[11][2] == 1) and (lastA[11][2] == 7) and ((millis() - BounceAOff[11][2]) > Delay)) {
MIDI.sendNoteOff(1, 120, velocity);
lastA[11][2] = 0;
//A121
if (lastA[11][3] == 7) {
BounceAOn[11][3] = millis();
if ((keysA[11][3] == 0) and (lastA[11][3] == 0) and ((millis() - BounceAOn[11][3]) > Delay)) {
MIDI.sendNoteOn(1, 121, velocity);
lastA[11][3] = 7;
if (lastA[11][3] == 0) {
BounceAOff[11][3] = millis();
if ((keysA[11][3] == 1) and (lastA[11][3] == 7) and ((millis() - BounceAOff[11][3]) > Delay)) {
MIDI.sendNoteOff(1, 121, velocity);
lastA[11][3] = 0;
//A122
if (lastA[11][4] == 7) {
BounceAOn[11][4] = millis();
if ((keysA[11][4] == 0) and (lastA[11][4] == 0) and ((millis() - BounceAOn[11][4]) > Delay)) {
MIDI.sendNoteOn(1, 122, velocity);
lastA[11][4] = 7;
if (lastA[11][4] == 0) {
BounceAOff[11][4] = millis();
if ((keysA[11][4] == 1) and (lastA[11][4] == 7) and ((millis() - BounceAOff[11][4]) > Delay)) {
MIDI.sendNoteOff(1, 122, velocity);
lastA[11][4] = 0;
//A123
if (lastA[11][5] == 7) {
BounceAOn[11][5] = millis();
if ((keysA[11][5] == 0) and (lastA[11][5] == 0) and ((millis() - BounceAOn[11][5]) > Delay)) {
MIDI.sendNoteOn(1, 123, velocity);
lastA[11][5] = 7;
if (lastA[11][5] == 0) {
BounceAOff[11][5] = millis();
if ((keysA[11][5] == 1) and (lastA[11][5] == 7) and ((millis() - BounceAOff[11][5]) > Delay)) {
MIDI.sendNoteOff(1, 123, velocity);
lastA[11][5] = 0;
//A124
if (lastA[11][6] == 7) {
BounceAOn[11][6] = millis();
if ((keysA[11][6] == 0) and (lastA[11][6] == 0) and ((millis() - BounceAOn[11][6]) > Delay)) {
MIDI.sendNoteOn(1, 124, velocity);
lastA[11][6] = 7;
if (lastA[11][6] == 0) {
BounceAOff[11][6] = millis();
if ((keysA[11][6] == 1) and (lastA[11][6] == 7) and ((millis() - BounceAOff[11][6]) > Delay)) {
MIDI.sendNoteOff(1, 124, velocity);
lastA[11][6] = 0;
//A125
if (lastA[11][7] == 7) {
BounceAOn[11][7] = millis();
if ((keysA[11][7] == 0) and (lastA[11][7] == 0) and ((millis() - BounceAOn[11][7]) > Delay)) {
MIDI.sendNoteOn(1, 125, velocity);
lastA[11][7] = 7;
if (lastA[11][7] == 0) {
BounceAOff[11][7] = millis();
if ((keysA[11][7] == 1) and (lastA[11][7] == 7) and ((millis() - BounceAOff[11][7]) > Delay)) {
MIDI.sendNoteOff(1, 125, velocity);
lastA[11][7] = 0;
//A126
if (lastA[12][0] == 7) {
BounceAOn[12][0] = millis();
if ((keysA[12][0] == 0) and (lastA[12][0] == 0) and ((millis() - BounceAOn[12][0]) > Delay)) {
MIDI.sendNoteOn(1, 126, velocity);
lastA[12][0] = 7;
if (lastA[12][0] == 0) {
BounceAOff[12][0] = millis();
if ((keysA[12][0] == 1) and (lastA[12][0] == 7) and ((millis() - BounceAOff[12][0]) > Delay)) {
MIDI.sendNoteOff(1, 126, velocity);
lastA[12][0] = 0;
//A127
if (lastA[12][1] == 7) {
BounceAOn[12][1] = millis();
if ((keysA[12][1] == 0) and (lastA[12][1] == 0) and ((millis() - BounceAOn[12][1]) > Delay)) {
MIDI.sendNoteOn(1, 127, velocity);
lastA[12][1] = 7;
if (lastA[12][1] == 0) {
BounceAOff[12][1] = millis();
if ((keysA[12][1] == 1) and (lastA[12][1] == 7) and ((millis() - BounceAOff[12][1]) > Delay)) {
MIDI.sendNoteOff(1, 127, velocity);
lastA[12][1] = 0;
//A128
if (lastA[12][2] == 7) {
BounceAOn[12][2] = millis();
if ((keysA[12][2] == 0) and (lastA[12][2] == 0) and ((millis() - BounceAOn[12][2]) > Delay)) {
MIDI.sendNoteOn(1, 128, velocity);
lastA[12][2] = 7;
if (lastA[12][2] == 0) {
BounceAOff[12][2] = millis();
if ((keysA[12][2] == 1) and (lastA[12][2] == 7) and ((millis() - BounceAOff[12][2]) > Delay)) {
MIDI.sendNoteOff(1, 128, velocity);
lastA[12][2] = 0;
//A129
if (lastA[12][3] == 7) {
BounceAOn[12][3] = millis();
if ((keysA[12][3] == 0) and (lastA[12][3] == 0) and ((millis() - BounceAOn[12][3]) > Delay)) {
MIDI.sendNoteOn(1, 129, velocity);
lastA[12][3] = 7;
if (lastA[12][3] == 0) {
BounceAOff[12][3] = millis();
if ((keysA[12][3] == 1) and (lastA[12][3] == 7) and ((millis() - BounceAOff[12][3]) > Delay)) {
MIDI.sendNoteOff(1, 129, velocity);
lastA[12][3] = 0;
//A130
if (lastA[12][4] == 7) {
BounceAOn[12][4] = millis();
if ((keysA[12][4] == 0) and (lastA[12][4] == 0) and ((millis() - BounceAOn[12][4]) > Delay)) {
MIDI.sendNoteOn(1, 130, velocity);
lastA[12][4] = 7;
if (lastA[12][4] == 0) {
BounceAOff[12][4] = millis();
if ((keysA[12][4] == 1) and (lastA[12][4] == 7) and ((millis() - BounceAOff[12][4]) > Delay)) {
MIDI.sendNoteOff(1, 130, velocity);
lastA[12][4] = 0;
//A131
if (lastA[12][5] == 7) {
BounceAOn[12][5] = millis();
if ((keysA[12][5] == 0) and (lastA[12][5] == 0) and ((millis() - BounceAOn[12][5]) > Delay)) {
MIDI.sendNoteOn(1, 131, velocity);
lastA[12][5] = 7;
if (lastA[12][5] == 0) {
BounceAOff[12][5] = millis();
if ((keysA[12][5] == 1) and (lastA[12][5] == 7) and ((millis() - BounceAOff[12][5]) > Delay)) {
MIDI.sendNoteOff(1, 131, velocity);
lastA[12][5] = 0;
//A132
if (lastA[12][6] == 7) {
BounceAOn[12][6] = millis();
if ((keysA[12][6] == 0) and (lastA[12][6] == 0) and ((millis() - BounceAOn[12][6]) > Delay)) {
MIDI.sendNoteOn(1, 132, velocity);
lastA[12][6] = 7;
if (lastA[12][6] == 0) {
BounceAOff[12][6] = millis();
if ((keysA[12][6] == 1) and (lastA[12][6] == 7) and ((millis() - BounceAOff[12][6]) > Delay)) {
MIDI.sendNoteOff(1, 132, velocity);
lastA[12][6] = 0;
//A133
if (lastA[12][7] == 7) {
BounceAOn[12][7] = millis();
if ((keysA[12][7] == 0) and (lastA[12][7] == 0) and ((millis() - BounceAOn[12][7]) > Delay)) {
MIDI.sendNoteOn(1, 133, velocity);
lastA[12][7] = 7;
if (lastA[12][7] == 0) {
BounceAOff[12][7] = millis();
if ((keysA[12][7] == 1) and (lastA[12][7] == 7) and ((millis() - BounceAOff[12][7]) > Delay)) {
MIDI.sendNoteOff(1, 133, velocity);
lastA[12][7] = 0;
//A134
if (lastA[13][0] == 7) {
BounceAOn[13][0] = millis();
if ((keysA[13][0] == 0) and (lastA[13][0] == 0) and ((millis() - BounceAOn[13][0]) > Delay)) {
MIDI.sendNoteOn(1, 134, velocity);
lastA[13][0] = 7;
if (lastA[13][0] == 0) {
BounceAOff[13][0] = millis();
if ((keysA[13][0] == 1) and (lastA[13][0] == 7) and ((millis() - BounceAOff[13][0]) > Delay)) {
MIDI.sendNoteOff(1, 134, velocity);
lastA[13][0] = 0;
//A135
if (lastA[13][1] == 7) {
BounceAOn[13][1] = millis();
if ((keysA[13][1] == 0) and (lastA[13][1] == 0) and ((millis() - BounceAOn[13][1]) > Delay)) {
MIDI.sendNoteOn(1, 135, velocity);
lastA[13][1] = 7;
if (lastA[13][1] == 0) {
BounceAOff[13][1] = millis();
if ((keysA[13][1] == 1) and (lastA[13][1] == 7) and ((millis() - BounceAOff[13][1]) > Delay)) {
MIDI.sendNoteOff(1, 135, velocity);
lastA[13][1] = 0;
//A136
if (lastA[13][2] == 7) {
BounceAOn[13][2] = millis();
if ((keysA[13][2] == 0) and (lastA[13][2] == 0) and ((millis() - BounceAOn[13][2]) > Delay)) {
MIDI.sendNoteOn(1, 136, velocity);
lastA[13][2] = 7;
if (lastA[13][2] == 0) {
BounceAOff[13][2] = millis();
if ((keysA[13][2] == 1) and (lastA[13][2] == 7) and ((millis() - BounceAOff[13][2]) > Delay)) {
MIDI.sendNoteOff(1, 136, velocity);
lastA[13][2] = 0;
//A137
if (lastA[13][3] == 7) {
BounceAOn[13][3] = millis();
if ((keysA[13][3] == 0) and (lastA[13][3] == 0) and ((millis() - BounceAOn[13][3]) > Delay)) {
MIDI.sendNoteOn(1, 137, velocity);
lastA[13][3] = 7;
if (lastA[13][3] == 0) {
BounceAOff[13][3] = millis();
if ((keysA[13][3] == 1) and (lastA[13][3] == 7) and ((millis() - BounceAOff[13][3]) > Delay)) {
MIDI.sendNoteOff(1, 137, velocity);
lastA[13][3] = 0;
//A138
if (lastA[13][4] == 7) {
BounceAOn[13][4] = millis();
if ((keysA[13][4] == 0) and (lastA[13][4] == 0) and ((millis() - BounceAOn[13][4]) > Delay)) {
MIDI.sendNoteOn(1, 138, velocity);
lastA[13][4] = 7;
if (lastA[13][4] == 0) {
BounceAOff[13][4] = millis();
if ((keysA[13][4] == 1) and (lastA[13][4] == 7) and ((millis() - BounceAOff[13][4]) > Delay)) {
MIDI.sendNoteOff(1, 138, velocity);
lastA[13][4] = 0;
//A139
if (lastA[13][5] == 7) {
BounceAOn[13][5] = millis();
if ((keysA[13][5] == 0) and (lastA[13][5] == 0) and ((millis() - BounceAOn[13][5]) > Delay)) {
MIDI.sendNoteOn(1, 139, velocity);
lastA[13][5] = 7;
if (lastA[13][5] == 0) {
BounceAOff[13][5] = millis();
if ((keysA[13][5] == 1) and (lastA[13][5] == 7) and ((millis() - BounceAOff[13][5]) > Delay)) {
MIDI.sendNoteOff(1, 139, velocity);
lastA[13][5] = 0;
//A140
if (lastA[13][6] == 7) {
BounceAOn[13][6] = millis();
if ((keysA[13][6] == 0) and (lastA[13][6] == 0) and ((millis() - BounceAOn[13][6]) > Delay)) {
MIDI.sendNoteOn(1, 140, velocity);
lastA[13][6] = 7;
if (lastA[13][6] == 0) {
BounceAOff[13][6] = millis();
if ((keysA[13][6] == 1) and (lastA[13][6] == 7) and ((millis() - BounceAOff[13][6]) > Delay)) {
MIDI.sendNoteOff(1, 140, velocity);
lastA[13][6] = 0;
//A141
if (lastA[13][7] == 7) {
BounceAOn[13][7] = millis();
if ((keysA[13][7] == 0) and (lastA[13][7] == 0) and ((millis() - BounceAOn[13][7]) > Delay)) {
MIDI.sendNoteOn(1, 141, velocity);
lastA[13][7] = 7;
if (lastA[13][7] == 0) {
BounceAOff[13][7] = millis();
if ((keysA[13][7] == 1) and (lastA[13][7] == 7) and ((millis() - BounceAOff[13][7]) > Delay)) {
MIDI.sendNoteOff(1, 141, velocity);
lastA[13][7] = 0;
//A142
if (lastA[14][0] == 7) {
BounceAOn[14][0] = millis();
if ((keysA[14][0] == 0) and (lastA[14][0] == 0) and ((millis() - BounceAOn[14][0]) > Delay)) {
MIDI.sendNoteOn(1, 142, velocity);
lastA[14][0] = 7;
if (lastA[14][0] == 0) {
BounceAOff[14][0] = millis();
if ((keysA[14][0] == 1) and (lastA[14][0] == 7) and ((millis() - BounceAOff[14][0]) > Delay)) {
MIDI.sendNoteOff(1, 142, velocity);
lastA[14][0] = 0;
//A143
if (lastA[14][1] == 7) {
BounceAOn[14][1] = millis();
if ((keysA[14][1] == 0) and (lastA[14][1] == 0) and ((millis() - BounceAOn[14][1]) > Delay)) {
MIDI.sendNoteOn(1, 143, velocity);
lastA[14][1] = 7;
if (lastA[14][1] == 0) {
BounceAOff[14][1] = millis();
if ((keysA[14][1] == 1) and (lastA[14][1] == 7) and ((millis() - BounceAOff[14][1]) > Delay)) {
MIDI.sendNoteOff(1, 143, velocity);
lastA[14][1] = 0;
//A144
if (lastA[14][2] == 7) {
BounceAOn[14][2] = millis();
if ((keysA[14][2] == 0) and (lastA[14][2] == 0) and ((millis() - BounceAOn[14][2]) > Delay)) {
MIDI.sendNoteOn(1, 144, velocity);
lastA[14][2] = 7;
if (lastA[14][2] == 0) {
BounceAOff[14][2] = millis();
if ((keysA[14][2] == 1) and (lastA[14][2] == 7) and ((millis() - BounceAOff[14][2]) > Delay)) {
MIDI.sendNoteOff(1, 144, velocity);
lastA[14][2] = 0;
//A145
if (lastA[14][3] == 7) {
BounceAOn[14][3] = millis();
if ((keysA[14][3] == 0) and (lastA[14][3] == 0) and ((millis() - BounceAOn[14][3]) > Delay)) {
MIDI.sendNoteOn(1, 145, velocity);
lastA[14][3] = 7;
if (lastA[14][3] == 0) {
BounceAOff[14][3] = millis();
if ((keysA[14][3] == 1) and (lastA[14][3] == 7) and ((millis() - BounceAOff[14][3]) > Delay)) {
MIDI.sendNoteOff(1, 145, velocity);
lastA[14][3] = 0;
//A146
if (lastA[14][4] == 7) {
BounceAOn[14][4] = millis();
if ((keysA[14][4] == 0) and (lastA[14][4] == 0) and ((millis() - BounceAOn[14][4]) > Delay)) {
MIDI.sendNoteOn(1, 146, velocity);
lastA[14][4] = 7;
if (lastA[14][4] == 0) {
BounceAOff[14][4] = millis();
if ((keysA[14][4] == 1) and (lastA[14][4] == 7) and ((millis() - BounceAOff[14][4]) > Delay)) {
MIDI.sendNoteOff(1, 146, velocity);
lastA[14][4] = 0;
//A147
if (lastA[14][5] == 7) {
BounceAOn[14][5] = millis();
if ((keysA[14][5] == 0) and (lastA[14][5] == 0) and ((millis() - BounceAOn[14][5]) > Delay)) {
MIDI.sendNoteOn(1, 147, velocity);
lastA[14][5] = 7;
if (lastA[14][5] == 0) {
BounceAOff[14][5] = millis();
if ((keysA[14][5] == 1) and (lastA[14][5] == 7) and ((millis() - BounceAOff[14][5]) > Delay)) {
MIDI.sendNoteOff(1, 147, velocity);
lastA[14][5] = 0;
//A148
if (lastA[14][6] == 7) {
if ((keysA[14][6] == 0) and (lastA[14][6] == 0) and ((millis() - BounceAOn[14][6]) > Delay)) {
MIDI.sendNoteOn(1, 148, velocity);
lastA[14][6] = 7;
if (lastA[14][6] == 0) {
BounceAOff[14][6] = millis();
if ((keysA[14][6] == 1) and (lastA[14][6] == 7) and ((millis() - BounceAOff[14][6]) > Delay)) {
MIDI.sendNoteOff(1, 148, velocity);
lastA[14][6] = 0;
//A149
if (lastA[14][7] == 7) {
BounceAOn[14][7] = millis();
if ((keysA[14][7] == 0) and (lastA[14][7] == 0) and ((millis() - BounceAOn[14][7]) > Delay)) {
MIDI.sendNoteOn(1, 149, velocity);
lastA[14][7] = 7;
if (lastA[14][7] == 0) {
BounceAOff[14][7] = millis();
if ((keysA[14][7] == 1) and (lastA[14][7] == 7) and ((millis() - BounceAOff[14][7]) > Delay)) {
MIDI.sendNoteOff(1, 149, velocity);
lastA[14][7] = 0;
//A150
if (lastA[15][0] == 7) {
BounceAOn[15][0] = millis();
if ((keysA[15][0] == 0) and (lastA[15][0] == 0) and ((millis() - BounceAOn[15][0]) > Delay)) {
MIDI.sendNoteOn(1, 150, velocity);
lastA[15][0] = 7;
if (lastA[15][0] == 0) {
BounceAOff[15][0] = millis();
if ((keysA[15][0] == 1) and (lastA[15][0] == 7) and ((millis() - BounceAOff[15][0]) > Delay)) {
MIDI.sendNoteOff(1, 150, velocity);
lastA[15][0] = 0;
//A151
if (lastA[15][1] == 7) {
BounceAOn[15][1] = millis();
if ((keysA[15][1] == 0) and (lastA[15][1] == 0) and ((millis() - BounceAOn[15][1]) > Delay)) {
MIDI.sendNoteOn(1, 151, velocity);
lastA[15][1] = 7;
if (lastA[15][1] == 0) {
BounceAOff[15][1] = millis();
if ((keysA[15][1] == 1) and (lastA[15][1] == 7) and ((millis() - BounceAOff[15][1]) > Delay)) {
MIDI.sendNoteOff(1, 151, velocity);
lastA[15][1] = 0;
//A152
if (lastA[15][2] == 7) {
BounceAOn[15][2] = millis();
if ((keysA[15][2] == 0) and (lastA[15][2] == 0) and ((millis() - BounceAOn[15][2]) > Delay)) {
MIDI.sendNoteOn(1, 152, velocity);
lastA[15][2] = 7;
if (lastA[15][2] == 0) {
BounceAOff[15][2] = millis();
if ((keysA[15][2] == 1) and (lastA[15][2] == 7) and ((millis() - BounceAOff[15][2]) > Delay)) {
MIDI.sendNoteOff(1, 152, velocity);
lastA[15][2] = 0;
//A153
if (lastA[15][3] == 7) {
BounceAOn[15][3] = millis();
if ((keysA[15][3] == 0) and (lastA[15][3] == 0) and ((millis() - BounceAOn[15][3]) > Delay)) {
MIDI.sendNoteOff(1, 153, velocity);
lastA[15][3] = 7;
if (lastA[15][3] == 0) {
BounceAOff[15][3] = millis();
if ((keysA[15][3] == 1) and (lastA[15][3] == 7) and ((millis() - BounceAOff[15][3]) > Delay)) {
lastA[15][3] = 0;
//A154
if (lastA[15][4] == 7) {
BounceAOn[15][4] = millis();
if ((keysA[15][4] == 0) and (lastA[15][4] == 0) and ((millis() - BounceAOn[15][4]) > Delay)) {
MIDI.sendNoteOn(1, 154, velocity);
lastA[15][4] = 7;
if (lastA[15][4] == 0) {
BounceAOff[15][4] = millis();
if ((keysA[15][4] == 1) and (lastA[15][4] == 7) and ((millis() - BounceAOff[15][4]) > Delay)) {
MIDI.sendNoteOff(1, 154, velocity);
lastA[15][4] = 0;
//A155
if (lastA[15][5] == 7) {
BounceAOn[15][5] = millis();
if ((keysA[15][5] == 0) and (lastA[15][5] == 0) and ((millis() - BounceAOn[15][5]) > Delay)) {
MIDI.sendNoteOn(1, 155, velocity);
lastA[15][5] = 7;
if (lastA[15][5] == 0) {
BounceAOff[15][5] = millis();
if ((keysA[15][5] == 1) and (lastA[15][5] == 7) and ((millis() - BounceAOff[15][5]) > Delay)) {
MIDI.sendNoteOff(1, 155, velocity);
lastA[15][5] = 0;
//A156
if (lastA[15][6] == 7) {
BounceAOn[15][6] = millis();
if ((keysA[15][6] == 0) and (lastA[15][6] == 0) and ((millis() - BounceAOn[15][6]) > Delay)) {
MIDI.sendNoteOn(1, 156, velocity);
lastA[15][6] = 7;
if (lastA[15][6] == 0) {
BounceAOff[15][6] = millis();
if ((keysA[15][6] == 1) and (lastA[15][6] == 7) and ((millis() - BounceAOff[15][6]) > Delay)) {
MIDI.sendNoteOff(1, 156, velocity);
lastA[15][6] = 0;
//A157
if (lastA[15][7] == 7) {
BounceAOn[15][7] = millis();
if ((keysA[15][7] == 0) and (lastA[15][7] == 0) and ((millis() - BounceAOn[15][7]) > Delay)) {
MIDI.sendNoteOn(1, 157, velocity);
lastA[15][7] = 7;
if (lastA[15][7] == 0) {
BounceAOff[15][7] = millis();
if ((keysA[15][7] == 1) and (lastA[15][7] == 7) and ((millis() - BounceAOff[15][7]) > Delay)) {
MIDI.sendNoteOff(1, 157, velocity);
lastA[15][7] = 0;
//Midi Thru
if (byteReady) {
byteReady = false;
Serial.write(midiByte);
void MIDI.send(int one, int two, int three) {
Serial.write(one);
Serial.write(two);
Serial.write(three);
void serialEvent() {
if (Serial.available()) {
// get the new byte:
midiByte = (unsigned char)Serial.read();
byteReady = true;
all help is appreciated, thanks!
