error: expected initializer before ‘void’ I know most of the time this error is a missing ;
Below is my code.
void GetRxCommands()
static int LastChannel7Command;
// We always check the channel 7
Channel7Command = GetChannel7Command();
while(Failsafe)
if (DEBUG) Serial.println("RX Disconnected!");
ToggleAllLights(); // If the receiver isn't connected, pause the program and flash all the lights
delay(50);
if (Channel7Present) { Channel7 = GetChannel7Command();}
else { Channel7 = Pos1; } // We set Channel 7 to Position 1 if not being used
if (GearPresent) { GearCommand = GetGearCommand(); }
else { GearCommand = 0; } // We set Gear to nothing if not being used
boolean CheckGear()
GearPulse = pulseIn(Gear_Pin, HIGH, ServoTimeout);
if (GearPulse == 0) { return false; }
else { return true; }
int GetChannel7Command()
int Channel7Command;
Channel7Pulse = pulseIn(Channel7_Pin, HIGH, ServoTimeout);
if (Channel7Pulse == 0)
{ // In this case, there was no signal found
// Channel7Present = false;
Channel7Command = Pos3; // If no Channel7, we always set the mode to 1
Channel7Present = true;
if (Channel7Reverse == false)
if (Channel7Pulse > Channel7PulseCenter + 100)
else if ((Channel7Pulse >= (Channel7PulseCenter - 100)) && (Channel7Pulse <= (Channel7PulseCenter + 100)))
Channel7Command = Pos2;
Channel7Command = Pos1;
return Command;
int GetGearCommand()
int GearCommand;
if (GearPulse == 0)
// GearPresent = false;
GearCommand = Pos1; // If no Gear, we always set the mode to 1
GearPresent = true;
if (GearReverse == false)
if (GearPulse > GearPulseCenter + 100)
GearCommand = Pos2;
else if ((GearPulse >= (GearPulseCenter - 100)) && (GearPulse <= (GearPulseCenter + 100)))
GearCommand = Pos1;
GearCommand = Pos1;
GearCommand = Pos2;
return GearCommand;
