error: expected primary-expression before '=' token
Code:
This sketch uses example for Adafruit Monochrome OLEDs based on SSD1306 drivers
 Pick one up today in the adafruit shop!
 ------> http://www.adafruit.com/category/63_98
This example is for a 128x32 size display using I2C to communicate
3 pins are required to interface (2 I2C and one reset)
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
// Button Pin Setup
const int l_up_button = 2; //Left player up button pin
const int l_down_button = 9; //Left player down button pin
const int r_up_button = 3; //Right player up button pin
const int r_down_button = 5; //Right player down button pin
//Screen Size Parameters
int x_pixels = 128;
int y_pixels = 32;
//Paddle Parameters
int paddle_height = 10;
int paddle_width = 3;
int speakerPin = 8;
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
// Ball velocities:
int x_vel = 1;
int y_vel = 1;
// Ball position:
int x_pos = 5;
int y_pos = 32;
// Paddle positions:
int l_pos = 0;
int r_pos = 0;
// Player scores
int l_score = 0;
int r_score = 0;
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
 B00000001, B11000000,
 B00000011, B11100000,
 B11110011, B11100000,
 B11111110, B11111000,
 B01111110, B11111111,
 B00110011, B10011111,
 B00011111, B11111100,
 B00001101, B01110000,
 B00011011, B10100000,
 B00111111, B11100000,
 B00111111, B11110000,
 B01111100, B11110000,
 B01110000, B01110000,
 B00000000, B00110000 };
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
void setup()   {
 pinMode(l_up_button, INPUT);
 pinMode(l_down_button, INPUT);
 pinMode(r_up_button, INPUT);
 pinMode(r_down_button, INPUT);
 randomSeed(analogRead(0));
 // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
 display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
 // init done
 // Show image buffer on the display hardware.
 // Since the buffer is intialized with an Adafruit splashscreen
 // internally, this will display the splashscreen.
 display.display();
 // Clear the buffer.
 display.clearDisplay();
 // Display Arduino Pong splashscreen
 display.setTextSize(1);
 display.setTextColor(WHITE);
 display.setCursor(display.width()/2-20,0);
 display.println("Arduino");
 display.setCursor(display.width()/2-20/2,8);
 display.println("Pong");
 display.display();
 delay(2000);
 // Update position of left paddle:
 if (digitalRead(l_up_button) && l_pos < (y_pixels - paddle_height)){l_pos += 1;}
 else if (digitalRead(l_down_button) && l_pos > 0){l_pos -= 1;}
 // Update position of right paddle:
 if (digitalRead(r_up_button) && r_pos < (y_pixels - paddle_height)){r_pos += 1;}
 else if (digitalRead(r_down_button) && r_pos > 0){r_pos -= 1;}
 // Check for ball hitting a wall:
 if (x_pos > x_pixels-1){
   ball_reset(false);
   l_score += 1;
   tone(speakerPin, 50, 100);
   delay(50);
 else if(x_pos < 0){
   ball_reset(true);
   r_score +=1;
   delay(50);
 // Check for ball bouncing off ceiling:
 if (y_pos > y_pixels-1 || y_pos < 0){y_vel = -y_vel;}
 // Check for ball bouncing off paddle:
 // Update ball position:
 x_pos+=x_vel;
 y_pos+=y_vel;
 // Draw pong elements to display:
 display.drawPixel(x_pos, y_pos, WHITE);
 display.fillRect(0, l_pos, paddle_width, paddle_height, WHITE);
 display.fillRect(x_pixels-paddle_width ,r_pos, paddle_width, paddle_height, WHITE);
 // Display scores
 display.setCursor(display.width()/4,0);
 display.println(l_score);
 display.setCursor(display.width()*3/4,0);
 display.println(r_score);
  [i][/i][color=red]//Winner plate
 if (l_score) = 10;
 display.println("You Win");[/color]
 // Display all elements
 display.display();
  // Check for ball bouncing off paddles:
 if (ball_on_right_paddle()){
   x_vel = -x_vel;
   tone(speakerPin, 300, 100);
 else if (ball_on_left_paddle()){
   x_vel = -x_vel;
   tone(speakerPin, 250, 100);
bool ball_on_right_paddle(){
// If ball is heading towards paddle and is at the surface of paddle between the top and bottom of the paddle, then it's a hit
return(x_pos == x_pixels-paddle_width-1 && y_pos >= r_pos && y_pos <= (r_pos + paddle_height) && x_vel == 1);
bool ball_on_left_paddle(){
return(x_pos == paddle_width-1 && y_pos >= l_pos && y_pos <= (l_pos + paddle_height) && x_vel == -1);
void ball_reset(bool left){
//If left is true, then ball should launch from the left, otherwise launch from the right
//Ball should launch at a random Y location and at a random Y velocity
 y_pos = random(display.height());
 if (random(2)>0){
   y_vel = 1;
 else{
   y_vel = -1;
 if (left){
 x_vel = 1;
 x_pos = paddle_width-1;
 else{
 x_vel = -1;
 x_pos = display.width()-paddle_width;
Error message:
if (l_score) = 10;
exit status 1
I’m new to arduino and I tried to modifie the code from here:
Please help!
Thanks even if won’t get the answer!
Arduino_Pong.ino (5.59 KB)
 if (l_score == 10)
Please remember to use code tags when posting code
It didn’t work and sorry for not marking the code
It didn't work
{blood pressure rises}
D0V15:
It didn't work and sorry for not marking the code
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What didn't work?
Tom... :slight_smile:
Yeah sorry for not understanding how stuff works and for being stupid I'm new to Arduino.
And didn't work
if (l_score == 10)
Please, for the sake of my blood pressure POST YOUR CODE and tell us what *didn't work" means.
D0V15:
And didn't work
if (l_score == 10)
Of course it does. Your error message is gone. On the other hand you probably want to add brackets around the block of winning text to prevent it from being printed every iteration of loop.
//Winner plate
if (l_score == 10)
