Error expected primary-expression before token
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11, 5, 4, 3, 2);
int ss=0;
int mm=32;
int hh=16;
void setup(){
lcd.begin(16, 2);
for (ss=0; <60; ss++){ //los segs van de 0 a 60 y otra vez, y durante este período:
lcd.clear();
lcd.setCursor(3,0);
lcd:print("Hsr");
lcd.setCursor(4,1);
lcd.print(hh);
lcd.setCursor(6,1);
lcd.print(":")
lcd.setCursor(7,0)
lcd.print("Min")
lcd.setCursor(7,1)
lcd.print(mm);
lcd.setCursor(9,1);
lcd.print(":");
lcd.setCursor(11,0);
lcd.print("seg");
lcd.setCursor(12,1);
lcd.print(ss);
if( ss > 59){
ss=00;
mm=mm+1;}
if( ss > 59){
ss=00;
hh=hh+1;}
if( hh>=24){
hh = 00;
mm = 00;
ss = 00;
There are quite a lot of mistakes that you can identify quite easily once the code is auto formatted with a ctrl-T:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int ss = 0;
int mm = 32;
int hh = 16;
  lcd.begin(16, 2);
  for (ss = 0; < 60; ss++) { //los segs van de 0 a 60 y otra vez, y durante este período:
    lcd.clear();
    lcd.setCursor(3, 0);
lcd: print("Hsr");
    lcd.setCursor(4, 1);
    lcd.print(hh);
    lcd.setCursor(6, 1);
    lcd.print(":")
    lcd.setCursor(7, 0)
    lcd.print("Min")
    lcd.setCursor(7, 1)
    lcd.print(mm);
    lcd.setCursor(9, 1);
    lcd.print(":");
    lcd.setCursor(11, 0);
    lcd.print("seg");
    lcd.setCursor(12, 1);
    lcd.print(ss);
  if ( ss > 59) {
    ss = 00;
    mm = mm + 1;
  if ( ss > 59) {
    ss = 00;
    hh = hh + 1;
  if ( hh >= 24) {
    hh = 00;
    mm = 00;
    ss = 00;
While what is less than 60?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
