error: expected primary-expression before '.' token
I am getting the following error in my code. Why this error is happening?
C:\Users\NOWFEL\Documents\Arduino\cse323_prac\cse323_prac.ino: In function 'void Write_PlxDaq()':
cse323_prac:70:21: error: expected primary-expression before '.' token
     Serial.print(DHT.temperature); //Store date on Excel
cse323_prac:73:21: error: expected primary-expression before '.' token
     Serial.print(DHT.humidity); //Store date on Excel
C:\Users\NOWFEL\Documents\Arduino\cse323_prac\cse323_prac.ino: In function 'void Write_SDcard()':
cse323_prac:99:23: error: expected primary-expression before '.' token
     dataFile.print(DHT.temperature); //Store date on SD card
cse323_prac:102:23: error: expected primary-expression before '.' token
     dataFile.print(DHT.humidity); //Store date on SD card
C:\Users\NOWFEL\Documents\Arduino\cse323_prac\cse323_prac.ino: In function 'void Read_DHT11()':
cse323_prac:145:14: error: expected primary-expression before '.' token
 int chk = DHT.read11(DHT11_PIN);
exit status 1
My full code is as follows
#include <DS3231.h> //Library for RTC module (Download from Link in article)
#include <SPI.h> //Library for SPI communication (Pre-Loaded into Arduino)
#include <SD.h> //Library for SD card (Pre-Loaded into Arduino)
#include <DHT.h> //Library for dht11 Temperature and Humidity sensor (Download from Link in article)
#define DHT11_PIN 7 //Sensor output pin is connected to pin 7
DHT dht;
const int chipSelect = 4; //SD card CS pin connected to pin 4 of Arduino
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
  // Setup Serial connection
  Initialize_SDcard();
  Initialize_RTC();
  Initialize_PlxDaq();
  Read_DHT11();
  Write_SDcard();
  Write_PlxDaq();
  delay(5000); //Wait for 5 seconds before writing the next data
void Write_PlxDaq()
    Serial.print("DATA"); //always write "DATA" to Indicate the following as Data
    Serial.print(","); //Move to next column using a ","
    Serial.print("DATE"); //Store date on Excel
    Serial.print("TIME"); //Store date on Excel
    Serial.println(); //End of Row move to next row
void Initialize_PlxDaq()
Serial.println("CLEARDATA"); //clears up any data left from previous projects
Serial.println("LABEL,Date,Time,Temperature,Humidity"); //always write LABEL, to indicate it as first line
void Write_SDcard()
    // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("LoggerCD.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.print(rtc.getDateStr()); //Store date on SD card
    dataFile.print(","); //Move to next column using a ","
    dataFile.print(rtc.getTimeStr()); //Store date on SD card
    dataFile.println(); //End of Row move to next row
    dataFile.close(); //Close the file
  Serial.println("OOPS!! SD card writing failed");
void Initialize_SDcard()
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  if (dataFile) {
    dataFile.println("Date,Time,Temperature,Humidity"); //Write the first row of the excel file
    dataFile.close();
void Initialize_RTC()
   // Initialize the rtc object
  rtc.begin();
//#### The following lines can be uncommented to set the date and time for the first time###
rtc.setDOW(FRIDAY);     // Set Day-of-Week to SUNDAY
rtc.setTime(18, 46, 45);     // Set the time to 12:00:00 (24hr format)
rtc.setDate(6, 30, 2017);   // Set the date to January 1st, 2014
void Read_DHT11()
dht is the name of the object, DHT is the name of the class
DHT dht; //Sensor object named as DHT
Despite the useless comment, the object is called dht. This is not the same as DHT.
Steve
