error: expected primary-expression before ',' token
Hello, I am getting this error:
screenTouch:36:27: error: expected primary-expression before ',' token
exit status 1
My Code:
  //        2.8" TOUCH SCREEN DEMO            //
//           http://www.educ8s.tv           //
#include <Adafruit_TFTLCD.h>
#include <Adafruit_GFX.h>
#include <TouchScreen.h>
#define LCD_CS
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
boolean buttonEnabled = true;
  Serial.print("Starting...");
  tft.reset();
  tft.begin(0x9325);
  tft.setRotation(1);
  tft.fillScreen(BLACK);
  //Draw white frame
  tft.drawRect(0,0,319,240,WHITE);
  //Print "Hello" Text
  tft.setCursor(100,30);
  tft.setTextColor(WHITE);
  tft.setTextSize(4);
  tft.print("Hello");
  //Print "YouTube!" text
  tft.setCursor(80,100);
  tft.setTextColor(RED);
  tft.setTextSize(4);
  tft.print("YouTube!");
  //Create Red Button
  tft.fillRect(60,180, 200, 40, RED);
  tft.drawRect(60,180,200,40,WHITE);
  tft.setCursor(80,188);
  tft.setTextSize(3);
  tft.print("Subscribe!");
  TSPoint p = ts.getPoint();  //Get touch point
  if (p.z > ts.pressureThreshhold) {
   Serial.print("X = "); Serial.print(p.x);
   Serial.print("\tY = "); Serial.print(p.y);
   Serial.print("\n");
   p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
   p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
   if(p.x>60 && p.x<260 && p.y>180 && p.y<220 && buttonEnabled)// The user has pressed inside the red rectangle
    buttonEnabled = false; //Disable button
    //This is important, because the libraries are sharing pins
   pinMode(XM, OUTPUT);
   pinMode(YP, OUTPUT);
    //Erase the screen
    //Draw frame
    tft.setCursor(50,50);
    tft.setTextSize(3);
    tft.print("Thank you for\n\n   subscribing!");
   delay(10);
Thanks.
You didn't put the pin # for the LCD_CS define.
#define LCD_CS
you seem to have forgetten to put the pin number to use for this one...
