i need some help with my code. The error show
sketch.ino: In function 'void loop()':
sketch.ino:32:16: error: expected primary-expression before '.' token
int chk = DHT.read11(DHT11PIN);
sketch.ino:33:18: error: expected primary-expression before ',' token
lcd.setCursor( , 0);
sketch.ino:35:16: error: expected primary-expression before '.' token
lcd.print(DHT.temperature);
sketch.ino:40:16: error: expected primary-expression before '.' token
lcd.print(DHT.humidity);
Error during build: exit status 1
This is my full code
#include <DHT.h>
#include <DHT_U.h>
#define DHT11PIN 4
int dht11 = DHT11;
#include <LiquidCrystal.h>
LiquidCrystal lcd (12, 13, 4, 5, 6, 7);
// masukkan code setup di sini, VoidSetup berjalan sekali sahaja
pinMode (2, INPUT_PULLUP);
pinMode (3, INPUT_PULLUP);
lcd.setCursor (0, 0);
lcd.print ("COUNTER MACHINE ");
Serial.begin(9600);//serial monitor
pinMode(4, OUTPUT); //pin ENA, untuk PWM
pinMode(5, OUTPUT); //pin IN1, digital
pinMode(6, OUTPUT); //pin IN2, digital
//offkan semua pin pada peringkat awal
//dengan meletakkan LOW
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
}//END VOID SETUP
void loop(){
lcd.print("Temp: ");
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Humidity: ");
lcd.print("%");
delay(2000); //Delay 2 sec between temperature/humidity check.
//Forward-kan Motor selamat 3 saat
forward();
delay(3000);
//Brake-kan Motor selamat 1 saat
brake();
//Reverse-kan Motor selamat 5 saat
brake();
delay(5000);
brake();
}//END VOID LOOP
void forward() {
digitalWrite(4, LOW); //IN2
digitalWrite(5, HIGH); //IN1
analogWrite(6, 255); //ENA - PWM (255 Speed Max, 0 Speed Min)
}//END FORWARD
void reverse() {
digitalWrite(4, HIGH); //IN2
digitalWrite(5, LOW); //IN1
}//END REVERSE
void brake() {
digitalWrite(6, HIGH); //ENA - PWM (255 Speed Max, 0 Speed Min)
}//END BRAKE
