"error: expected unqualified-id before ... " after upgrading Arduino IDE
I just upgraded from Arduino 1.6.8 to 1.8.8 after not using it for like 2 years. I tried to compile a sketch that is using a downloaded library (PalatisSoftPWM) and it fails with the error message:
error: expected unqualified-id before ')' token
That library is installed in my sketch folder, and the IDE seems to recognize it (it's listed in the libraries menu). The sketch worked before, I didn't change any code. So i tried to compile a sample sketch that is delivered with the library and it breaks with the same error. After that I re-installed 1.6.8 - and it compiled again, the sample sketch and my own sketch using the library.
Sketches that use other libraries are compiling fine (with 1.6.8 and 1.8.8 ), but I can't get this specific library to work. I re-downloaded it and replaced the old copy in my sketchbook libraries folder, but still no luck.
The code of the example sketch is as follows:
/* Demonstrates usage of the PalatisSoftPWM library.
   Fades Arduino pin 13 from PWM value 0 to the highest level and back to 0 again.
#include <PalatisSoftPWM.h>
SOFTPWM_DEFINE_PIN13_CHANNEL(0);  //Configure Arduino pin 13 as PWM channel 0
SOFTPWM_DEFINE_OBJECT(1);
const unsigned int fadeDuration = 1000;  // (ms)The length of time for to go from PWM value 0 to the highest level and back to 0 again. The maximum allowed value is 8388.
  PalatisSoftPWM.begin(60);  // begin with 60 Hz PWM frequency
  // fade from PWM value 0 to the highest value
  for (byte value = 0; value < PalatisSoftPWM.PWMlevels() - 1; value++) {
    delayMicroseconds(fadeDuration * 1000UL / PalatisSoftPWM.PWMlevels() / 2);
    PalatisSoftPWM.set(0, value);
  // fade back to PWM value 0
  for (int value = PalatisSoftPWM.PWMlevels() - 1; value >= 0; value--) {
Exact error message when compiling this sketch:
PalatisSoftPWM_example:7:1: error: expected unqualified-id before ')' token
exit status 1
I can reproduce this by switching between 1.6.8 and 1.8.8 - everytime I try to compile with 1.6.8 it compiles correctly, and it never does with 1.8.8.
What am I missing here? What did I forget while not using Arduino for 2 years? :slight_smile:
Thanks for any help!
Hi. There is an incompatibility between the new avr-gcc compiler version used by Arduino IDE 1.8.8 and old versions of the PalatisSoftPWM library. I have already fixed that issue some time ago. Please update to the 2.0.1 release of the library:
If you need assistance with the library update process, let me know and I'll provide instructions.
pert:
Releases · per1234/PalatisSoftPWM · GitHub
Hi pert,
Version 2.0.1 works in Arduino 1.8.8 and 1.6.8.
Thank you very much, you saved my day :smiley:
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
