Error: expected unqualified-id before 'if'
Well i am new to programming in C. But I am trying to learn as much as i can. What i am trying to do is run a ping distance sensor to judge distance to nearest object and if the distance is < 40 cm, output to servos. the actual servo values are bogus and just used in a testing rig to watch for movement. here's the code
 /* Ping))) Sensor
    This sketch reads a PING))) ultrasonic rangefinder and returns the
    distance to the closest object in range. To do this, it sends a pulse
    to the sensor to initiate a reading, then listens for a pulse
    to return.  The length of the returning pulse is proportional to
    the distance of the object from the sensor.
    The circuit:
       * +V connection of the PING))) attached to +5V
       * GND connection of the PING))) attached to ground
       * SIG connection of the PING))) attached to digital pin 7
    created 3 Nov 2008
    by David A. Mellis
    modified 30 Jun 2009
    by Tom Igoe
 // this constant won't change.  It's the pin number
 // of the sensor's output:
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
Servo myservo3;  // create servo object to control a servo
const int pingPin = 53;
   // initialize serial communication:
 {myservo1.attach(31);
 myservo2.attach(32);
 myservo3.attach(33);
   // establish variables for duration of the ping,
   // and the distance result in inches and centimeters:
   long duration, inches, cm;
   // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
   // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
   pinMode(pingPin, OUTPUT);
   digitalWrite(pingPin, LOW);
   delayMicroseconds(2);
   digitalWrite(pingPin, HIGH);
   delayMicroseconds(5);
   // The same pin is used to read the signal from the PING))): a HIGH
   // pulse whose duration is the time (in microseconds) from the sending
   // of the ping to the reception of its echo off of an object.
   pinMode(pingPin, INPUT);
   duration = pulseIn(pingPin, HIGH);
   // convert the time into a distance
   inches = microsecondsToInches(duration);
   cm = microsecondsToCentimeters(duration);
   Serial.print(inches);
   Serial.print("in, ");
   Serial.print(cm);
   Serial.print("cm");
 long microsecondsToInches(long microseconds)
   // According to Parallax's datasheet for the PING))), there are
   // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
   // second).  This gives the distance travelled by the ping, outbound
   // and return, so we divide by 2 to get the distance of the obstacle.
   return microseconds / 74 / 2;
 long microsecondsToCentimeters(long microseconds)
   // The speed of sound is 340 m/s or 29 microseconds per centimeter.
   // The ping travels out and back, so to find the distance of the
   // object we take half of the distance travelled.
   return microseconds / 29 / 2;
if (cm > 15 && cm < 40 )
   myservo3.write(90);
   myservo2.write(90);
   myservo1.write(90);
   myservo3.write(190);
   myservo2.write(175);
   myservo1.write(175);
   myservo3.write(10);
   myservo2.write(5);
   myservo1.write(5);
  myservo3.write(90);
   myservo2.write(90);
   myservo1.write(90);
Any suggestions would be greatly appriciated :-?
Hello!
Try using thw [#] button when posting code.
It looks like you’re trying to have two loop()s, that won’t work.
Please edit your post, highlight all code and press [#]. :slight_smile:
thanks for that catch, any suggestion on what to do?
 /* Ping))) Sensor
    The circuit:
    created 3 Nov 2008
    by David A. Mellis
    by Tom Igoe
#include <Servo.h>
   Serial.print(cm);
   Serial.print("cm");
   delay(1000);if (cm > 15 && cm < 40 )
   myservo3.write(90);
   myservo2.write(90);
   myservo1.write(90);
   myservo3.write(10);
   myservo2.write(5);
   myservo1.write(5);
  myservo3.write(90);
   myservo2.write(90);
   myservo1.write(90);
You can try this. :slight_smile:
What I did:
Copy all code from the below loop, paste it in at the bottom of the above loop.
well i tried the code you posted and it gave the error that there was no if before else. after removing the else statement. code compiled. but i would like to use the else statement later on. any help?
you need an explicit if() before all your {} for it to work like you expext
it is no compile error to omit them (if you have no else) but since you had an else you need something like:
if(){
} else if(){
not
if(){
}else{
:slight_smile:
you are a lifesaver.........pineapple flavor haha. code is working fine, and i have a better understanding of how the code works. thank you . any other suggestions you may have. lay them on
how can i impliment a counter so that the sensor will scan say, 250 times in between the servo movement. the code has developed a little bit so here it is
 /* Ping))) Sensor
    The circuit:
    http://www.arduino.cc/en/Tutorial/Ping
    created 3 Nov 2008
    by David A. Mellis
    by Tom Igoe
  #include <Servo.h>
Servo myservo3;
    myservo3.write(10);
   Serial.print(cm);
   Serial.print("cm");
   delay(10);
   Serial.print(cm);
   Serial.print("cm");
   delay(10);
     myservo3.write(90);
   Serial.print(cm);
   Serial.print("cm");
   delay(10);
  if (cm < 40){
   myservo2.write(90);
   myservo1.write(90);
   myservo2.write(50);
   myservo1.write(50);
   // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
here it is
can you do an if inside of an if?
yes.
you can do a for() inside a for() or if(). You can use any number of control structure commands inside of each other as you need. Just be sure to have the syntax correct. Remember you need the colosing curly bracket for each one you start.
Thank you very much, im pluging along and now i have a working code that needs a few tweaks. here is the code i am working on right now
  #include <Servo.h>
Servo myservo3;
   long duration, inches, cm, inches1, cm1, inches2, cm2, inches3, cm3;
   myservo3.write(90);
   Serial.print(cm);
   Serial.print("cm");
   delay(10);
  if (cm < 40){
   myservo3.write(10);
   inches1 = microsecondsToInches(duration);
   cm1 = microsecondsToCentimeters(duration);
   Serial.print(inches1);
   Serial.print(cm1);
   Serial.print("cm");
   delay(10);
   myservo3.write(180);
   inches2 = microsecondsToInches(duration);
   cm2 = microsecondsToCentimeters(duration);
   Serial.print(inches2);
   Serial.print(cm2);
   Serial.print("cm");
   delay(10);
   myservo.write(90);
   delay(500)
   inches3 = microsecondsToInches(duration);
   cm3 = microsecondsToCentimeters(duration);
   Serial.print(inches3);
   Serial.print(cm3);
   Serial.print("cm");
   delay(10);
   if (cm1<cm2) {
   myservo2.write(10);
   if (cm1>cm2){
   myservo2.write(10);
   myservo1.write(10);
