error: expected unqualified-id before 'if'
Hello everybody, I'm trying to make a clock that also measures humidity and temperature using SparkFun DHT22 temp. and humidity sensor, DS3231 clock IC and a 16x2 LCD. I threw these three programs together (still a little new to programming). Now, the clock IC program is working with 1 second delay, the DHT22 is using 3 second delay. I honestly don't know millis() and I don't think it would be much reliable too. "This number will overflow (go back to zero), after approximately 50 days." I set up a little if() that executes the DHT22 part if count is 3 (and sets count to zero), else it adds one to count and does not execute the DHT22 part. I keep on getting this error right at the if(count == 3) part. Here is the code:
#include <Wire.h>
#define DS3231_I2C_ADDRESS 104
#define DHT11_PIN 0      // ADC0
byte seconds, minutes, hours, day, date, month, year;
int count;
char weekDay[4];
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.clear();
  Wire.begin();
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  get3231Date();
  watchConsole();
  lcd.setCursor(0, 4);
  lcd.print(hours, DEC);
  lcd.print(":");
  lcd.print(minutes, DEC);
  lcd.print(":");
  lcd.print(seconds, DEC);
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
void watchConsole()
  if (Serial.available()) {      // Look for char in serial queue and process if found
    if (Serial.read() == 84) {      //If command = "T" Set Date
      set3231Date();
      get3231Date();
      Serial.println(" ");
void set3231Date()
  //T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year)
  //T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99)
  //Example: 02-Feb-09 @ 19:57:11 for the 3rd day of the week -> T1157193020209
  seconds = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
  minutes = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  hours   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  day     = (byte) (Serial.read() - 48);
  date    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  month   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  year    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  Wire.beginTransmission(DS3231_I2C_ADDRESS);
  Wire.send(0x00);
  Wire.send(decToBcd(seconds));
  Wire.send(decToBcd(minutes));
  Wire.send(decToBcd(hours));
  Wire.send(decToBcd(day));
  Wire.send(decToBcd(date));
  Wire.send(decToBcd(month));
  Wire.send(decToBcd(year));
  Wire.endTransmission();
void get3231Date()
  // send request to receive data starting at register 0
  Wire.beginTransmission(DS3231_I2C_ADDRESS); // 104 is DS3231 device address
  Wire.send(0x00); // start at register 0
  Wire.requestFrom(DS3231_I2C_ADDRESS, 7); // request seven bytes
  if(Wire.available()) {
    seconds = Wire.receive(); // get seconds
    minutes = Wire.receive(); // get minutes
    hours   = Wire.receive();   // get hours
    day     = Wire.receive();
    date    = Wire.receive();
    month   = Wire.receive(); //temp month
    year    = Wire.receive();
    seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111)); // convert BCD to decimal
    minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111)); // convert BCD to decimal
    hours   = (((hours & B00110000)>>4)*10 + (hours & B00001111)); // convert BCD to decimal (assume 24 hour mode)
    day     = (day & B00000111); // 1-7
    date    = (((date & B00110000)>>4)*10 + (date & B00001111)); // 1-31
    month   = (((month & B00010000)>>4)*10 + (month & B00001111)); //msb7 is century overflow
    year    = (((year & B11110000)>>4)*10 + (year & B00001111));
  else {
    //oh noes, no data!
  switch (day) {
  case 1:
    strcpy(weekDay, "Sun");
  case 2:
    strcpy(weekDay, "Mon");
  case 3:
    strcpy(weekDay, "Tue");
  case 4:
    strcpy(weekDay, "Wed");
  case 5:
    strcpy(weekDay, "Thu");
  case 6:
    strcpy(weekDay, "Fri");
  case 7:
    strcpy(weekDay, "Sat");
[glow]if (count == 3) {[/glow]
  count = 0;
  byte read_dht11_dat()
    byte i = 0;
    byte result=0;
    for(i=0; i< 8; i++){
      while(!(PINC & _BV(DHT11_PIN)));  // wait 50us finish
      delayMicroseconds(30);
      if(PINC & _BV(DHT11_PIN))
        result |=(1<<(7-i));
      while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
    return result;
  //Serial.println("A");
  byte dht11_dat[5];
  byte dht11_in;
  byte i;
  // start condition
  // 1. pull-down i/o pin from 18ms
  PORTC &= ~_BV(DHT11_PIN);
  //delay(18);  //DHT11 must >=18ms
  delay(5);  //DHT22 must 1~10ms
  PORTC |= _BV(DHT11_PIN);  // pull-up 20-40us
  delayMicroseconds(40);
  DDRC &= ~_BV(DHT11_PIN);
  dht11_in = PINC & _BV(DHT11_PIN);
  //Serial.println("B"); //miss first 2 bits on DHT22
  if(dht11_in){
    Serial.println("dht11 start condition 1 not met");
    return;
  delayMicroseconds(80);
  if(!dht11_in){
    Serial.println("dht11 start condition 2 not met");
    return;
  // now ready for data reception
  for (i=0; i<5; i++)
    dht11_dat[i] = read_dht11_dat();
  DDRC |= _BV(DHT11_PIN);
  byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
  // check check_sum
  if(dht11_dat[4] != dht11_check_sum)
    Serial.println("DHT11 checksum error");
  //debug
  for (i=0; i<5; i++) {
    Serial.print(dht11_dat[i], HEX);
    Serial.print(' ');
  Serial.print("check_sum=");
  Serial.print(dht11_check_sum, HEX);
  Serial.println(' ');
  //end of debug
  int HighByte, LowByte, TReading, SignBit, Whole, Fract;   //DHT22
  HighByte = dht11_dat[0];   //DHT22
  LowByte = dht11_dat[1];   //DHT22
  TReading = (HighByte << 8) + LowByte;   //DHT22
  Whole = TReading / 10;   //DHT22
  Fract = TReading % 10;   //DHT22
  lcd.setCursor(1,3);
  //      Serial.print(dht11_dat[0], DEC);  //DHT11
  //      Serial.print(".");  //DHT11
  //      Serial.print(dht11_dat[1], DEC);  //DHT11
  lcd.print(Whole);  //DHT22
  lcd.print("%  ");   //DHT22
  HighByte = dht11_dat[2];
  LowByte = dht11_dat[3];
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1;
  lcd.setCursor(1,10);
  //      Serial.print(dht11_dat[2], DEC);  //DHT11
  //      Serial.print(dht11_dat[3], DEC);  //DHT11
  if (SignBit) // If its negative
    lcd.print("-");
  Serial.println("C");  //DHT22
  //delay(2000);  //DHT11
  delay(3000);  //DHT22
  delayMicroseconds(810);
else{
  count++;
  delay(1);
delay(999);
Yes I already read all the topics about this and similar errors, I couldn't find anything useful. Either I'm blind or this is caused by something else. Does anyone see anything incorrect in the code? I might edit the code to omit functions like weekday etc. because I'm not going to be using them. Only hours, minutes, seconds and temperature + humidity will be used.
I've never been able to read code effectively in the forum code boxes, but is that if statement in a method? seems like it's just chilling out there.
Bingo. And I nearly broke my keyboard with my head. I also moved other bytes and voids out of the void loop. And it compiled. Thanks. A lot.
#include <Wire.h>
int count;
char weekDay[4];
  lcd.begin(16, 2);
  lcd.clear();
  Wire.begin();
  get3231Date();
  watchConsole();
  lcd.print(":");
  lcd.print(":");
  if (count == 3) {
    count = 0;
    byte dht11_dat[5];
    byte dht11_in;
    byte i;
    // start condition
    if(dht11_in){
      return;
    if(!dht11_in){
      return;
    for (i=0; i<5; i++)
    // check check_sum
    //debug
      Serial.print(' ');
    //end of debug
    lcd.setCursor(1,3);
      lcd.print("-");
  else{
    count++;
    delay(1);
  delay(999);
void watchConsole()
      set3231Date();
      get3231Date();
void set3231Date()
  Wire.send(0x00);
void get3231Date()
  else {
    //oh noes, no data!
  switch (day) {
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  case 6:
  case 7:
  byte i = 0;
  byte result=0;
  return result;
