i am recieving an error expected unqualified-id before while at this point.
float turn;
float t = turn;
while (t < -180) t += 360;
while (t > 180) t -= 360;
could someone please give some directions on how to go about it.
float turn;
float t = turn;
Start by posting your complete program.
My guess is that you have a missing { or } in the program before the lines that you posted. Auto formatting the code in the IDE can help to show up such problems as can putting each { and } alone on its own line
UKHeliBob:
Start by posting your complete program.My guess is that you have a missing { or } in the program before the lines that you posted. Auto formatting the code in the IDE can help to show up such problems as can putting each { and } alone on its own line
// Imports
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
#include <Servo.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
// Pin variables
#define GPS_TX_PIN 6
#define GPS_RX_PIN 3
#define BLUETOOTH_TX_PIN 10
#define BLUETOOTH_RX_PIN 11
// Bluetooth GPS input
#define SOP '<'
#define EOP '>'
// You must then add your 'Declination Angle' to the compass, which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Mine is: 23° 4' E (Positive),
#define DECLINATION_ANGLE +0.34f
#define COMPASS_OFFSET 0.35f
#define GPS_UPDATE_INTERVAL 1000
#define GPS_WAYPOINT_TIMEOUT 25
// Struct to combine our coordinates into one struct for ease of use
struct GeoLoc {
float lat;
float lon;
// GPS
TinyGPSPlus gps;
#define GPS_BAUD 9600
// Motors
Servo myservo;
// Master Enable
bool enabled = true;
// Bluetooth input
bool started = false;
bool ended = false;
char inData[80]; // creates an 80 character array called "inData"
byte index; //creates a variable type=byte called "index"
double Long; //variable for longitude coordinate
double Lat; //variable for latitude coordinate
// Serial components
SoftwareSerial bluetoothSerial(BLUETOOTH_TX_PIN, BLUETOOTH_RX_PIN);
SoftwareSerial gpsSerial(GPS_RX_PIN, GPS_TX_PIN); // TXD to digital pin 6
/* Compass */
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
GeoLoc checkGPS() {
Serial.println("Reading onboard GPS: ");
unsigned long start = millis();
while (millis() - start < GPS_UPDATE_INTERVAL) {
// If we recieved new location then take the coordinates and pack them into a struct
if (feedgps())
return gpsdump();
GeoLoc robotLoc;
robotLoc.lat = 0.0;
robotLoc.lon = 0.0;
return robotLoc;
// Get and process GPS data
GeoLoc gpsdump() {
GeoLoc robotLoc;
robotLoc.lat = gps.location.lat();
robotLoc.lon = gps.location.lng();
Serial.print(robotLoc.lat, 7); Serial.print(", "); Serial.println(robotLoc.lon, 7);
return robotLoc;
// Feed data as it becomes available
bool feedgps() {
while (gpsSerial.available() > 0) {
if (gps.encode(gpsSerial.read()))
return true;
return false;
void displayCompassDetails(void)
sensor_t sensor;
mag.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
#ifndef DEGTORAD
#define DEGTORAD 0.0174532925199432957f
#define RADTODEG 57.295779513082320876f
#endif
float geoBearing(struct GeoLoc &a, struct GeoLoc &b) {
float y = sin(b.lon-a.lon) * cos(b.lat);
float x = cos(a.lat)*sin(b.lat) - sin(a.lat)*cos(b.lat)*cos(b.lon-a.lon);
return atan2(y, x) * RADTODEG;
float geoDistance(struct GeoLoc &a, struct GeoLoc &b) {
const float R = 6371000; // radius of earth in metres
float p1 = a.lat * DEGTORAD;
float p2 = b.lat * DEGTORAD;
float dp = (b.lat-a.lat) * DEGTORAD;
float dl = (b.lon-a.lon) * DEGTORAD;
float x = sin(dp/2) * sin(dp/2) + cos(p1) * cos(p2) * sin(dl/2) * sin(dl/2);
float y = 2 * atan2(sqrt(x), sqrt(1-x));
// returns distance in meters
return R * y;
float geoHeading() {
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
float heading = atan2(event.magnetic.y, event.magnetic.x);
// Offset
heading -= DECLINATION_ANGLE;
heading -= COMPASS_OFFSET;
if(heading < 0)
heading += 2*PI;
if(heading > 2PI)
heading -= 2PI;
float headingDegrees = heading * 180/M_PI;
// Map to -180 - 180
while (headingDegrees < -180) headingDegrees += 360;
while (headingDegrees > 180) headingDegrees -= 360;
return headingDegrees;
float turn;
float t = turn;
Serial.print("turn: ");
Serial.println(t);
Serial.print("original: ");
Serial.println(turn);
float t_modifier = (180.0 - abs(t)) / 180.0;
float autoSteerA = 1;
float autoSteerB = 1;
if (t < 0) {
autoSteerB = t_modifier;
} else if (t > 0){
autoSteerA = t_modifier;
Serial.print("steerA: "); Serial.println(autoSteerA);
Serial.print("steerB: "); Serial.println(autoSteerB);
void driveTo(struct GeoLoc &loc, int timeout) {
gpsSerial.listen();
GeoLoc robotLoc = checkGPS();
bluetoothSerial.listen();
if (robotLoc.lat != 0 && robotLoc.lon != 0 && enabled) {
float distance = 0;
//Start move loop here
do {
gpsSerial.listen();
distance = geoDistance(robotLoc, loc);
float bearing = geoBearing(robotLoc, loc) - geoHeading();
Serial.print("Distance: ");
Serial.println(distance);
Serial.print("Bearing: ");
Serial.println(geoBearing(robotLoc, loc));
Serial.print("Heading: ");
Serial.println(geoHeading());
drive(distance, bearing);
timeout -= 1;
} while (distance > 1.0 && enabled && timeout>0);
stop();
void setupCompass() {
/* Initialise the compass /
if(!mag.begin())
/ There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while(1);
/* Display some basic information on this sensor */
displayCompassDetails();
// Attaching servo
myservo.attach(13)
//Debugging via serial
// Compass
setupCompass();
//GPS
gpsSerial.begin(GPS_BAUD);
//Bluetooth
bluetoothSerial.begin(9600);
// Testing
void testDriveNorth() {
float heading = geoHeading();
int testDist = 5;
Serial.println(heading);
while(!(heading < 5 && heading > -5)) {
drive(testDist, heading);
stop();
while (bluetoothSerial.available() > 0)
char inChar = ((byte)bluetoothSerial.read());
if (inChar == SOP)
index = 0;
inData[index] = '\0';
started = true;
ended = false;
else if (inChar == EOP)
ended = true;
if (index < 79)
inData[index] = inChar;
index++;
if (started && ended)
char *token = strtok(inData, ",");
boolean first = true;
while (token)
double val = atof(token);
token = strtok(NULL, ",");
if (first){
Lat = val;
}else{
Long = val;
first = false;
started = false;
ended = false;
index = 0;
GeoLoc waypointLoc;
waypointLoc.lat = Lat;
waypointLoc.lon = Long;
Serial.print(waypointLoc.lat, 7); Serial.print(", "); Serial.println(waypointLoc.lon, 7);
driveTo(waypointLoc, GPS_WAYPOINT_TIMEOUT);
You have code not in a function after the geoHeading() function. Where should the function end ?
Did you try the advice in reply #1 about formatting the code ?
UKHeliBob:
You have code not in a function after the geoHeading() function. Where should the function end ?Did you try the advice in reply #1 about formatting the code ?
i have but ends with the errors highlighted here
float turn;
float t = turn;
Serial.println(t);
if (t < 0) {
} else if (t > 0) {
float geoHeading()
// Offset
if (heading < 0)
heading += 2 * PI;
if (heading > 2 * PI)
heading -= 2 * PI;
float headingDegrees = heading * 180 / M_PI;
} //<<<< end of the geoHeading() function
float turn;
float t = turn;
while (t < -180) t += 360; //<<<<<< code not in a function
Please note the use of code tags and use them in future when you post code
