Error: fht_lin_out was not declared in this scope
So I am trying to implement a fast hartley transform
that I found online for the Arduino. I am trying to call an array from the library in my code directly below, from the program from the website. I am getting an out of scope error. It was working before, and I could have sworn that I didn't change anything, but for some reason it has trouble finding the scope of the variable now. I am programming using the Arduino uno.
It cannot find the scope for the array fht_lin_out. I tried to copy the code for FHT that I downloaded from the website onto here, but it is too many characters to fit.
Note: That A-weighting table is not being used right now so you can ignore that.
#include <FHT.h>
    fht_adc.pde
    guest openmusiclabs.com 9.5.12
    example sketch for testing the fht library.
    it takes in data on ADC0 (Analog0) and processes them
    with the fht. the data is sent out over the serial
    port at 115.2kb.  there is a pure data patch for
    visualizing the data.
   #define LIN_OUT 1 // use the log output function
   #define FHT_N 256 // set to 256 point fht
   // this is the A-Weighting Table for 8 Hz resolution and 256 samples.
   long weightTable[128] = {};
   // array that will output A-weighted values
   long weightedValues[128];
   // sets up the serial port
     Serial.begin(9600); // use the serial port
     while(1)
       // reduces jitter
       int sum = 0;
       // UDRE interrupt slows this way down on arduino1.0
       cli();
       // save 256 samples
       for (int i = 0 ; i < FHT_N ; i++)
         delay(.00048828);
         int k = analogRead(A0);
         sum = sum + k;
         fht_input[i] = k;
       // calculates DC bias
       int average = sum / 256;
       // subtract DC bias from each bin
       for ( int j = 0; j < FHT_N ; j++)
         int k = fht_input[j];
         fht_input[j] = k - average;
       // FHT Functions
       fht_window(); // window the data for better frequency response
       fht_reorder(); // reorder the data before doing the fht
       fht_run(); // process the data in the fht
       fht_mag_lin(); // take the output of the fht
       sei();
       // show me da values
       for( int j = 2 ; j < 128 ; j++)
         //send out the data
         Serial.println(fht_lin_out[j]);
       // stops the program after first aqusition (basically)
      delay(10000000000);
         delay(.00048828);
What a waste. delay() takes an integer value. delay(0) is silly.
#ifndef LIN_OUT // wether using the linear output function or not
  #define LIN_OUT 0
#endif
So, by default, LIN_OUT is set to 0.
#if (LIN_OUT == 1)
  extern const uint8_t _lin_table[] PROGMEM = {
    #include <sqrtlookup16.inc>
  uint16_t fht_lin_out[(FHT_N/2)]; // FHT linear output magintude buffer
#endif
So, by default, the array is not defined.
If you expect to use the array, you need to make sure that it is defined.
PaulS:
         delay(.00048828);
#define LIN_OUT 0
#endif
#if (LIN_OUT == 1)
#endif
Hi thank you for your response. At the top of my code, I define.
It worked perfectly before. I just recopied the actual programs reference code that worked perfectly before (and SHOULD work perfectly) into my arduino and I am getting the same error. This is very odd.
So I went into the actual FHT program itself and changed the LIN_OUT variable to 1 and tried to run it.
This is the error I got:
Arduino: 1.6.3 (Mac OS X), Board: "Arduino Uno"
FHT_Coming_Together.cpp.o: In function `fht_mag_lin':
/Users/hongjiang/Documents/Arduino/libraries/FHT/FHT.h:1014: undefined reference to `fht_lin_out'
/Users/hongjiang/Documents/Arduino/libraries/FHT/FHT.h:1014: undefined reference to `_lin_table'
FHT_Coming_Together.cpp.o: In function `loop':
/Users/hongjiang/FHT_Coming_Together.ino:74: undefined reference to `fht_lin_out'
/Users/hongjiang/FHT_Coming_Together.ino:92: undefined reference to `fht_lin_out'
/Users/hongjiang/FHT_Coming_Together.ino:95: undefined reference to `fht_lin_out'
FHT_Coming_Together.cpp.o:/Users/hongjiang/FHT_Coming_Together.ino:95: more undefined references to `fht_lin_out' follow
collect2: error: ld returned 1 exit status
Error compiling.
  enabled in File > Preferences.
Additionally, how can I delay by only milliseconds?
That's what delay() does. 0.00048828 milliseconds is 0.488828 microseconds. Even the delayMicroseconds() function doesn't support delays that short.
You'll need to resort to assembly language to get delays of less than a microsecond.
Ok thanks. Additionally I completely deleted and reinstalled my libraries folder, put the FHT library back in, tried to run the reference code and it is still giving me an error of accessing a variable in the FHT program.
Test_Reference.ino: In function 'void loop()':
Test_Reference.ino:45:18: error: 'fht_log_out' was not declared in this scope
Error compiling.
Have you defined LOG_OUT, too?
1 uS is 16 clock cycles at 16 MHz.
Have to do something that executes a few instructions that the compiler won't optimize away?
Ok so I kind of figured out the issue. I am not very familiar with Arduino, I'm a newbie, but building the code from the ground up, it all works out fine until I introduce the weight table that I put in my code that has like 128 longs. This is too much information for the Arudino to store and I'm assuming that interferes with my ability to use the FHT library.
Issue is that even after I delete the array, it still doesn't recognize the variable. Weird. Is it some offhand effect of overloading the memory of the Arduino?
Since you are not able to compile, and are, therefore, not able to upload, this seems highly unlikely.
Then it again, it seems to be an issue with the compiler, because even when I don't have the arduino plugged in, it still doesn't recognize the variable.
