Error for function-definition is not allowed here before '{' token
I'm getting this message for each of my void functions. Code below
#include <Arduino.h>
#define IN1 7
#define IN2 8
#define ENA 10
#define Bttn 2
#define Sfty 1
volatile int button=0;
volatile int safety=0;
volatile int PWMspeed=0;
int accel_time=1000;
int const_time=3000;
int open_time=5000;
int maxspeed=255;
int minspeed=50;
int steps=20;
int interval=accel_time/steps;
int increment=(maxspeed-minspeed)/steps;
unsigned long t0=0;
int debounce=50;
void motorcontrol();
void CW();
void CCW();
void OFF();
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(Bttn,INPUT_PULLUP);
pinMode(Sfty,INPUT_PULLUP);
motorcontrol();
void motorcontrol() {
enum states {
  IDLE,
  CONSTANT
states state;
 button=digitalRead(Bttn);
 safety=digitalRead(Sfty);
    switch (state) {
    case IDLE:
      Serial.println("IDLE ");
      unsigned static long t1=millis();
      if(button==HIGH) {
        state=CONSTANT;
    case CONSTANT:
      Serial.println("CONSTANT ");
      CW();
      analogWrite(ENA,maxspeed);
      if(millis()-t1<=const_time) {
        Serial.println(millis()-t1);
        if (safety==HIGH) {
          OFF();
          state=IDLE;
      }else{
        OFF();
        state=IDLE;
      default:
        Serial.println("Default Case Not Reached");
void CW() {
  digitalWrite(IN1,HIGH);
  digitalWrite(IN2,LOW);
void CCW() {
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
void OFF() {
  analogWrite(ENA,0);
It compiles fine for me.
There are some problems though.
state is not initialised here.
You are comparing a signed integer with an unsigned integer.
It would be a good idea to properly format your code...
In IDE press ctrl-t.
Why are the above declared with the volatile keyword?
On many Arduino boards (including UNO and Nano) pins 0 and 1 are used for the serial interface. You should probably not use them.
Change:
int const_time = 3000;
to:
unsigned const_time = 3000;
Change:
states state;
to:
static states state = IDLE;
Thanks for the help. I'm still very new to Arduino programming. However, I'm still getting the same error.
Post your latest code.
updated code
#define IN1 7
#define IN2 8
#define ENA 10
#define Bttn 3
#define Sfty 2
int button = 0;
int safety = 0;
int PWMspeed = 0;
unsigned accel_time = 1000;
unsigned open_time = 5000;
int maxspeed = 255;
int minspeed = 50;
int steps = 20;
unsigned interval = accel_time / steps;
int increment = (maxspeed - minspeed) / steps;
unsigned debounce = 50;
void CW();
void CCW();
void OFF();
enum states {
  IDLE,
  ACCEL_CW,
  CONSTANT_CW,
  DECEL_CW,
  OPEN
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(ENA, OUTPUT);
  pinMode(Bttn, INPUT_PULLUP);
  pinMode(Sfty, INPUT_PULLUP);
  motorcontrol();
  button = digitalRead(Bttn);
  safety = digitalRead(Sfty);
  switch (state) {
    case IDLE:
      if (button == HIGH) {
        state = ACCEL_CW;
    case ACCEL_CW:
      Serial.println("ACCEL ") unsigned static long t2 = millis();
      if (millis() - t2 = accel_time) {
        CW();
        unsigned static long t0 = millis();
        if (millis() - t0 <= interval) {
          PWMspeed += increment;
          if (safety == HIGH) {
            OFF();
            state = IDLE;
        state = CONSTANT_CW;
    case CONSTANT_CW:
      unsigned static long t1 = millis();
      CW();
      analogWrite(ENA, maxspeed);
      if (millis() - t1 <= const_time) {
          OFF();
          state = IDLE;
        state = DECEL_CW;
    case DECEL_CW:
      Serial.println("DECEL ") unsigned static long t3 = millis();
      if (millis() - t3 = accel_time) {
        CW();
        unsigned static long t4 = millis();
        if (millis() - t4 <= interval) {
          PWMspeed -= increment;
            OFF();
            state = IDLE;
        state = OPEN;
    case OPEN:
      unsigned static long t5 = millis();
      if (millis() - t5 <= open_time) {
        OFF();
      state = IDLE;
    default:
void CW() {
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
void CCW() {
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, HIGH);
void OFF() {
  analogWrite(ENA, 0);
You need to add a ; after ACCEL")
Please add the full error message. It gives a line number and character number where the error occurred.
Usually your problem is before that.
Often the complaint about function definition not allowed before { token is caused by a missing or extraneous} in your code before that. But I cannot find that here.
Tip: if in IDE you hover over a }, the matching { will light up. This can make it easier to find a mismatch.
check for = vs == also
and a ; after DECEL")
if (millis() - t2 = accel_time) {  // = or ==?
