error for sleep function
good day everyone
im trying to build a sunlogger following the guides from Data-Logger/Datalogger.ino at master · Make-Magazine/Data-Logger · GitHub
however, because i needed to take data of 10 separate sensors, i used mega2560 instead of uno. during compilation into uno things are fine, but not when im uploading into the mega, where it shows these errors:
Arduino: 1.6.5 (Windows 8), Board: “Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)”
sketch_jul01a.ino: In function ‘void sleepCPU_delay(long int)’:
sketch_jul01a:194: error: ‘PRR’ was not declared in this scope
sketch_jul01a.ino: In function ‘int doSleep(long int)’:
sketch_jul01a:221: error: ‘BODS’ was not declared in this scope
sketch_jul01a:221: error: ‘BODSE’ was not declared in this scope
here written sleep function (obtained from the link abv):
// Delay function
void sleepCPU_delay(long sleepTime) {
  ADCSRA &= ~(1<<ADEN);  // adc off
  PRR = 0xFF; // modules off
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  int trem = doSleep(sleepTime*calibv);
  timeSleep += (sleepTime-trem);
  PRR = 0x00; //modules on
  ADCSRA |= (1<<ADEN);  // adc on
// internal function.
int doSleep(long timeRem) {
  byte WDTps = 9;  // WDT Prescaler value, 9 = 8192ms
  isrcalled = 0;
  sleep_enable();
  while(timeRem > 0) {
    while ((0x10<<WDTps) > timeRem && WDTps > 0) {
      WDTps--;
    WDT_On((WDTps & 0x08 ? (1<<WDP3) : 0x00) | (WDTps & 0x07));
    isrcalled=0;
    while (isrcalled==0) {
      MCUCR |= (1<<BODS) | (1<<BODSE);
      MCUCR &= ~(1<<BODSE);  // must be done right before sleep
      sleep_cpu();  // sleep here
    timeRem -= (0x10<<WDTps);
  sleep_disable();
  return timeRem;
// wdt int service routine
ISR(WDT_vect) {
  WDT_Off();
  isrcalled=1;
i have no idea which part to modify for my arduino mega.
any help would be greatly appreciated. thank you =)
The m2560 does not have a single PRR register. The two registers are named PRR0 and PRR1.
I suggest using the power function instead…
http://www.nongnu.org/avr-libc/user-manual/group__avr__power.html
sketch_jul01a:221: error: 'BODS' was not declared in this scope
sketch_jul01a:221: error: 'BODSE' was not declared in this scope
The m2560 does not support disabling the Brown Out Detector. That code will have to removed.
so i can safely remove these functions from the code without affecting its ability to collect data? only with increase in current draw right?
// Calibrate watchdog timer with millis() timer(timer0)
// Delay function
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <SD.h>
#include <Time.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
long timeSleep = 0;  // total time due to sleep
float calibv = 0.93; // ratio of real clock with WDT clock
volatile byte isrcalled = 0;  // WDT vector flag
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
#define SAMPLEDELAY 300000  // Delay before making a sample
const int chipSelect = 53;
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    return;
  Serial.println("card initialized.");
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message");
  if(Serial.available() )
    processSyncMessage();
  if(timeStatus()!= timeNotSet)
    while(true)
      // Sample
      String dataString = "";
      for (int analogPin = 0; analogPin < 9; analogPin++) {
    int sensor = analogRead(analogPin);
      dataString += String(dayStr(weekday()));
      dataString += String(",");
      dataString += String(day());
      dataString += String(monthShortStr(month()));
      dataString += String(year());
      dataString += String(hour());
      dataString += String(":");
      dataString += String(minute());
      dataString += String(second());
      dataString += String(sensor);
    if (analogPin < 8) {
      dataString += "; ";
      // Write
      WriteValToCard(dataString);
      // Wait
      delay(SAMPLEDELAY);
void WriteValToCard(String val)
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (dataFile)
    dataFile.println(val);
    dataFile.close();
    Serial.println(val);
  else {
    Serial.println("Error opening datalog.txt");
void processSyncMessage() {
  while(Serial.available() >=  TIME_MSG_LEN ){
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
time_t requestSync()
  Serial.write(TIME_REQUEST);
  return 0; // the time will be sent later in response to serial mesg
// Internal function: Start watchdog timer
void WDT_On (byte psVal)
  byte ps = (psVal | (1<<WDIE)) & ~(1<<WDE);
  cli();
  wdt_reset();
  /* Clear WDRF in MCUSR */
  MCUSR &= ~(1<<WDRF);
  WDTCSR |= (1<<WDCE) | (1<<WDE);
  WDTCSR = ps;
  sei();
// Internal function.  Stop watchdog timer
void WDT_Off() {
  cli();
  wdt_reset();
  /* Write logical one to WDCE and WDE */
  /* Keep old prescaler setting to prevent unintentional time-out */
  /* Turn off WDT */
  WDTCSR = 0x00;
  sei();
void calibrate() {
  set_sleep_mode(SLEEP_MODE_IDLE);
  long tt1=millis();
  doSleep(256);
  long tt2=millis();
  calibv = 256.0/(tt2-tt1);
long estMillis() {
  return millis()+timeSleep;
// Delay function
  PRR0 = 0xFF; // modules off
  PRR0 = 0x00; //modules on
  isrcalled = 0;
  sleep_enable();
      WDTps--;
    isrcalled=0;
  sleep_disable();
  return timeRem;
ISR(WDT_vect) {
  WDT_Off();
  isrcalled=1;
tried removing these functions, and it seems that the logger would not log anything.
so there's no workaround for this issue?
