Hello, Does someone know where is GPIO_REG_READ macro #defined?
blh64
2
What board are you using? Is this error coming from your code, a library or some core module? What sketch are you trying to compile.
More info please.
I'm trying to read GPIO values directly from registers. I found sample code here:
and I'm trying to compile it now.
Currently I'm working with ESP32 Dev Module but I'm looking for a solution that would work on every ESP32 board.
Basically, what I want to do is read GPIOs regardless of how they are configured (as INPUT as OUTPUT or PWM), without changing the configuration.
WIth IDF 4.x the following did it:
PIN_INPUT_ENABLE (GPIO_PIN_MUX_REG [gpio_pin]);
digitalRead (gpio_pin);
But this doesn't seem to work with IDF 5.x any more.
First, instead of using GPIO_REG_READ we can use READ_PERI_REG, which is not really important for the original question.
And the answer to the original question: the reading of OUTPUT and PWM GPIOs is solved here:
system
Closed
7
