Error: "has not been declared"
In short, I'm trying to write a program to control a cell phone to start my car. It works well so I wanted to try and put it into a library. I have been successful clearing error messages, but this one I cant seem to get passed. I believe it is because I am trying to pass multiple parameters in the constructor. However, I can't figure out why I keep getting an error message. The message is "hangUpPin has not been declared".
Here is my header file:
  CarPhone.cpp - Library using a blackberry to end and start calls
  Created by Mitchell W. Duncan, February 10, 2013.
  Released into the public domain.
#ifndef CarPhone_h
#define CarPhone_h
#include "Arduino.h"
#include <inttypes.h>
class CarPhone
  public:
	CarPhone(int vibratePin, int hangUpPin, int callBackPin, int carStartPin);
	void hangUp();
	void startStopCar(boolean onOff);
	void checkForStart();
	void callReturn();
	int isVib();
  private:
	int _vibratePin;
	int _hangUpPin;
	int _callBackPin;
	int _carStartPin;
#endif
and here is the exerpt of my .cpp file
#include "CarPhone.h"
CarPhone::CarPhone(int vibratePin, int hangUpPin, int callBackPin, int carStartPin)
        pinMode(vibratePin, INPUT);
	_vibratePin = vibratePin;
	pinMode(hangUpPin, OUTPUT);
	_hangUpPin = hangUpPin;
	pinMode(callBackPin, OUTPUT);
	_callBackPin = callBackPin;
	pinMode(carStartPin, OUTPUT);
	_carStartPin = carStartPin;
I just included the constructor of my .cpp file because I don't want to bomb ya with code.
Also, here is how I initialized the object in my .ino file
#include <CarPhone.h>
  CarPhone blackberry (A0, 2, 3, 7);
My error messages are:
In file included from CarStarter_WL.ino:1:
CarPhone.h:16: error: 'hangUpPin' has not been declared
CarPhone.h:16: error: 'callBackPin' has not been declared
CarPhone.h:16: error: 'carStartPin' has not been declared
Again, any help will be well appreciated! Thanks!
-Mitch
Strangely, if I put them all in one file it compiles just fine:
class CarPhone
public:
  void hangUp();
  void callReturn();
  int isVib();
private:
  int _vibratePin;
  int _hangUpPin;
  int _callBackPin;
  int _carStartPin;
void loop() {}
Do you have any idea when your constructor will be called, relative to when init() is called to set up the hardware?
If you can not answer definitively that the constructor will be called after init() (and you can't because it isn't), then you should not be diddling with the hardware (via the pinMode() calls) in the constructor.
Translation : put a begin (or any other suitably named) function in your class then call it in setup() in your program in the same way that Serial.begin() is called. This ensures that it will be called after the hidden init() function is called and it will be safe to diddle with the hardware.
Any idea about the original question though?
I'd be interested in investigating further, if only you had posted ALL of your code.
UKHeliBob:
Thank you so much! My error was that I was using pinMode() before void setup(). I'm still new to arduino (this is my first project actually, I'm just taking what I know from C and Java, but I haven't written classes in C.) Also my other error was since I was working with my files in tabs, they were all in the same project folder (instead of the library folder like it probably should), so instead of including it like "#include <class.h>" I needed to use "#include "class.h". Once I got through some of my other general error messages, the program worked perfectly!
PaulS:
Ill post the code that I have right now(so if other people had the same issue), but it is still somewhat of a mess(ran out of time), so It has work to be redone
Header: CarPhone.h
  CarPhone.ch - Header using a blackberry to end and start calls to start and stop a car's engine from afar
#ifndef CarPhone_h
#define CarPhone_h
#include "inttypes.h"
class CarPhone
  public:
        void begin();
	void hangUp();
	void callReturn();
	int isVib();
  private:
	int _vibratePin;
	int _hangUpPin;
	int _callReturnPin;
	int _carStartPin;
#endif
C++ file: CarStarter.cpp
CarPhone::CarPhone(int vibratePin, int hangUpPin, int callReturnPin, int carStartPin)
	_callReturnPin = callReturnPin;
void CarPhone::begin()
  pinMode(_vibratePin, INPUT);
  pinMode(_hangUpPin, OUTPUT);
  pinMode(_callReturnPin, OUTPUT);
  pinMode(_carStartPin, OUTPUT);
void CarPhone::hangUp() //code to hang up phone call
  Serial.println("HANGUP");                // tells serial console / debugger that the arduino has gotten the hangup code
  delay(800);                              // waits for second vibrate to finish, not necessary, but I like it.
  digitalWrite(_hangUpPin, HIGH);           // Essentially pushes the hang up button
  delay(500);                              // holds it for a half second for good measure (like human finger)
  digitalWrite(_hangUpPin, LOW);            // releases hang up button on phone
void CarPhone::startStopCar(boolean onOff)         //code to start or stop the car - TRUE= on, FALSE = off
  int numToPressFob = 2;                // number to push buttons is default to turn it on
  if(!onOff)                           //if the car needs to be tuned off, press the fob 3 times
    numToPressFob = 3;
    Serial.println("THE CAR IS SHUTTING DOWN");
     Serial.println("THE CAR IS TURNING ON");
  for(int s = 0; s < numToPressFob; s++)             //runs the chunk of code twice
   digitalWrite(_carStartPin, HIGH);      //pushes the starter pin
   delay(900);                           //waits 9 tenths of a second
   digitalWrite(_carStartPin, LOW);       //stops pushing the starter pin
   delay(1200);                          //waits a second before it runs again
void CarPhone::checkForStart() //code that checks for +5V on the phone for more than X seconds to be sure that the car successfully started
void CarPhone::callReturn()   // code that pushes the #2 button on the cell phone to speed dial my number back
  Serial.println("CALLING BACK");      //calling back in serial console for debugging purposes
  delay (1000);                        //waits a second for good measure
  for(int i = 0; i < 2; i++)           //runs this twice
  digitalWrite(_hangUpPin, HIGH);       //pushes the hang up button (to quit any programs)
  delay(300);                          //holds it pushed for 3 tenths of a seconnd
  digitalWrite(_hangUpPin, LOW);        //releases the button
  digitalWrite(_callReturnPin, HIGH);     //pushes the call back button
  delay(1000);                         //waits speed dial push time
  digitalWrite(_callReturnPin, LOW);      //stops pushing the button
  delay(17000);                        //waits 17 seconds (really annoying since there is a message about low funds in account)
  hangUp();
int CarPhone::isVib()
   int currentV = analogRead(_vibratePin);           //sets the current voltage to whatever the vibrator is doing
   if ((currentV >= 31) && (currentV <= 38))        //if the vibrate pin is vibrating
     return 1;                                      // return 1
   else if ((currentV <=31) && (currentV >= 38))    //if the vibration is stopping
     return -1;                                     // return -1
   else                                             // otherwise
    return 0;                                       //return 0
CarStarter_With_Library.ino
CarPhone blackberry(A0, 2, 3, 7);               //creates the phone object (I'm using a blackberry, so I called it blackberry)
void setup()                                    //sets everything up
  Serial.begin(9600);                           //gets the serial monitor ready for debugging sequences
  blackberry.begin();                           //sets the input & output pins for the arduino
 Serial.println("THE PROGRAM HAS BEGUN!");
  int timesVib = 0;                                //counter for times it has vibrated
  long beginTime = 0;                              //int used for later to test to see for a timeout
  long timeOutTime = 3000;                         //how long you want the timeout to be
  long shutOffTime = (10 * 60000);                  //how long between the first call and second call you want to shut off the car, replace 8 for X minutes
  if (blackberry.isVib() == 1)          //if the vibrate pin is vibrating
    beginTime = millis();                            //record the beginning time
    timesVib++;                                      //tell the counter that it has vibrated once
    delay(2300);                                     //wait for it to finish vibrating
    do{
    }while(blackberry.isVib() == -1);                            //update the current voltage to currentV until it is in the acceptable range to continue (saying it is vibrating again)
    if (timesVib = 1 && ((millis() - beginTime) < timeOutTime))         //if it has vibrated twice AND it hasn't timed out yet, go ahead and start the car
       blackberry.hangUp();                                                       //calls the hang up method
       blackberry.startStopCar(1);                                                //calls the start car method
       delay(5000);                                                               // waits 5 seconds to let the user get off the phone and to let the cellular circuits to clear
       //check for run
       blackberry.callReturn();                                                   //calls my number back
     Serial.println("Waiting to see if the user wants to Shut off car");
     while((millis() - beginTime) < shutOffTime)
        if(blackberry.isVib() == 1)
        blackberry.startStopCar(0);
        delay(5000);
        delay(2000);
    Serial.println("EOL \n");
Thank you again for all your help! The community is great! Once I completely finish my project, I'll be sure to post it in the projects sub forum. I'm building a GSM remote start for my car using the existing remote starting system. However, I didn't want to pay for another service, so I'm using prepaid and it'll cost ~ $0.33 a month to keep the number active. It doesn't use minutes since the phone is never accepting a call. I'll talk about it more when I post the actual project though. Thanks again for all the help!
-Mitch
johncc:
PaulS:
I'm not the OP.
Is there a forum setting that automatically removes the author when quoted? --Or do you do that explicitly each time you reply.
And you never will. Classes are a feature of C++.
If you are talking to me, I only copy and paste the part I want to quote. I don't often use the quote option, because that needs to be invoked before starting to type a reply. I sometimes like to respond in a different order, too.
Or quote stuff somewhat out of context. 8)
PaulS:
If you scroll down through previous replies while writing a reply you will see a little red "Insert Quote" link at the top right of each previous reply. Clicking on that link will insert the quote at the current cursor position in your reply.
