Hello guys, i need a little help here. Im new to LoRa technology. im using LoRa DRF1278DM.
I want to make a IoT device with LoRa as its communication system, but I found an error on my device node, the Arduino Pro Mini 3.3V.
My gateway device is raspberry pi 3 model B+.
Header messages received by the device node have an incorrect return value. this is some part of my code on the device node
void radio_listening() {
DEBUG_PRINTLN("radio listening...");
char Message[14];
char *pM = Message;
memset(pM, 0, sizeof(pM));
// Waiting instruction from gateway
digitalWrite(pin_enable, LOW);
serial_radio.listen();
while (serial_radio.available() < 10);
for (int i = 0; i < 14; i++) {
*(pM+i) = (serial_radio.read() & 0xFF) ;
Serial.print(*(pM+i)&0xFF,HEX); Serial.print("-");
serial_radio.flush();
Serial.flush();
serial_radio.end();
Serial.println("");
parsing_header(pM);
for( int j = 0; j < 14; ++j )
*(pM+j) = (char)0;
when parsing_header the message received has a return value of "unknown header"
#define MSG_HEADER "GMLEWS"
#define MSG_HEADER_LEN (sizeof(MSG_HEADER)-1)
void parsing_header(char *pMessage) {
char *pS=pMessage;
Serial.print("pS:");
Serial.println(pS);
if(strncmp(pS, "GMLEWS",MSG_HEADER_LEN) == 0){
DEBUG_PRINTLN("GMLEWS header OK");
if (get_checksum(pS,MSG_CMD_LEN-1)==*(pS+MSG_CMD_LEN-1)) {
DEBUG_PRINTLN("Checksum OK");
parsing_data(pS+MSG_HEADER_LEN+2);
DEBUG_PRINTLN("Checksum NG");
DEBUG_PRINTLN("unknown header");
char get_checksum(char *pS, int len) {
char checksum = 0;
for (int i=0;i< len; i++) {
checksum += *(pS+i);
checksum = -(checksum % 256) & 0xFF;
//Serial.println(checksum,HEX);
return checksum;
Here's the output
radio listening...
0-2-47-4D-4C-45-57-53-0-3-0-2-35-53-
pS:
unknown header
I have tried several ways by converting these bytes but i dont have any idea. the data received is still wrong. please help, thank you so much. i'll appriciated it
lora_node_Arduino_GMLEWS.zip (8.67 KB)
