So I made a digital tach that's supposed to simultaneously read and display two variables. However, in my display protocol, I ran into this error.
"too few arguments to function 'void displayRPM(int, int)' "
//initialize LCD
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
//initialize hallSensor1 and its LED
const int hallSensor1=6; //hallSensor1
const int ledStat1=5; //ledStat1
int rpmMax1=0;
//intialize hallSensor2 and its LED
const int hallSensor2=4; //hallSensor2
const int ledStat2=3; //ledStat2
int rpmMax2=0;
//intialize common variables
const unsigned long initTime=1000; //initializ sampling time
const int maxRPM=1260; //arbitrary max rpm to be updated
//first system
pinMode(hallSensor1,INPUT_PULLUP); // hallSensor1 input_pullup
pinMode(ledStat1,OUTPUT); //output LED 1
//second system
pinMode(hallSensor2,INPUT_PULLUP); // hallSensor2 input_pullup
pinMode(ledStat2,OUTPUT); //output LED 2
//initialize LCD
lcd.begin(16,2);
//initialize Serial
Serial.begin(9600); //start with small baud
//hallSensor1 RPM calculations
int getRPM1()
int count1=0;
boolean countFlag1=LOW; //initialize countFlag for On/Off
unsigned long countingTime1=0; //initialize countingTime to be zero
unsigned long beginTime1=millis(); //initialize beginTime;
while (countingTime1 <= initTime) //begin monitoring
if (digitalRead(hallSensor1)==HIGH) //if hallSensor1 is unswitched
digitalWrite(ledStat1,LOW); //LED is off
countFlag1=HIGH; //countFlag is on
if (digitalRead(hallSensor1)==LOW &&countFlag1==HIGH) //if hallSensor1 is switched
digitalWrite(ledStat1,HIGH); //LED is on
count1++; //update count
countFlag1=LOW; //countFlag is off
countingTime1=millis()-beginTime1;
int countRPM1= int(60000/float(initTime))*count1;
return countRPM1;
//hallSensor2 RPM calculations
int getRPM2()
int count2=0;
boolean countFlag2=LOW; //initialize countFlag for On/Off
unsigned long countingTime2=0; //initialize countingTime to be zero
unsigned long beginTime2=millis(); //initialize beginTime;
while (countingTime2 <= initTime) //begin monitoring
if (digitalRead(hallSensor2)==HIGH) //if hallSensor1 is unswitched
digitalWrite(ledStat2,LOW); //LED is off
countFlag2=HIGH; //countFlag is on
if (digitalRead(hallSensor2)==LOW &&countFlag2==HIGH) //if hallSensor1 is switched
digitalWrite(ledStat2,HIGH); //LED is on
count2++; //update count
countFlag2=LOW; //countFlag is off
countingTime2=millis()-beginTime2;
int countRPM2= int(60000/float(initTime))*count2;
return countRPM2;
// display RPM1
int RPM1=getRPM1(); //rename updated variable to ease calculation
if (RPM1>rpmMax1)
rpmMax1=RPM1; //update RPM1 max
lcd.clear();
displayRPM(RPM1); //display RPM1
//fill in here
//display RPM2
int RPM2=getRPM2();
if (RPM2>rpmMax2)
displayRPM(RPM2); //dispay RPM2
void displayRPM(int RPM1, int RPM2)
I would've done separate displays like voidRPM1 and voidRPM2 but there's a delay whereas I need it simultaneously. I can take care of the code in the void later.
