Error I can't figure out with Attiny261A
I am trying to program an Attiny261A, and at first it was getting the correct signature, but was having trouble writing the bootloader for some reason. I kept trying, but I never got the bootloader to write correctly. Now though, it isn't even recognizing the signature of the ATTINY261A. I'm wondering if I damaged the chip, since I'm almost certain everything is connected properly.
Here is the output:
Arduino: 1.8.13 (Linux), Board: "ATtiny261/461/861(a), Enabled, CPU (CPU frequency), ATtiny261(a), 8 MHz (internal), EEPROM retained, B.O.D. Disabled (saves power), Enabled, Port A (pins 0~2, 10~14)"
/home/poduck/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/poduck/.arduino15/packages/ATTinyCore/hardware/avr/1.4.1/avrdude.conf -v -pattiny261 -cstk500v1 -P/dev/ttyACM0 -b19200 -e -Uefuse:w:0xFF:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0xE2:m -Uflash:w:/home/poduck/.arduino15/packages/ATTinyCore/hardware/avr/1.4.1/bootloaders/empty/empty_all.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/poduck/.arduino15/packages/ATTinyCore/hardware/avr/1.4.1/avrdude.conf"
         User configuration file is "/home/poduck/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 5.0
         AVR Part                      : ATtiny261
         Chip Erase delay              : 15000 us
         PAGEL                         : PB3
         BS2                           : PB2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     4    0 no        128    4     32  4000  4000 0xff 0xff
           flash         65     6    32    0 yes      2048   32     64  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xff0000
avrdude: Expected signature for ATtiny261 is 1E 91 0C
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
I no matter what I do, this error keeps recurring. The Device signature seems to change slightly each time though.
(deleted)
Wires are connected wrong, there is a loose wire, or the chip is damaged
