Hello, I installed the new IDE version 2.0.3 in my mac OS Catalina, but doesn´t works, when i open it, the IDE starts but always show the arduino icon jumping on the screen and not more.
Please help me.
Thanks.
this is video link
Please help me.
Thanks.
this is video link
Hi @vadosemantis. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to run Arduino IDE from the command line, then share the output.
Please do this:
"/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
icon on the post composer toolbar.```
) to your reply to make sure the output is correctly formatted.Please let me know if you have any questions or problems while following those instructions.
Last login: Tue Feb 14 21:10:48 on ttys001
You have new mail.
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
localhost:~ oscarjulian$ The specified command ("completion") is invalid. For a list of available options,
run "ng help".
Did you mean "analytics"?
localhost:~ oscarjulian$ "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.0.3
Starting backend process. PID: 67628
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/oscarjulian/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-02-16T03:10:15.070Z root INFO Backend Object.initialize: 6.6 ms [Finished 1.985 s after backend start]
2023-02-16T03:10:15.071Z root INFO Backend Object.configure: 5.4 ms [Finished 1.985 s after backend start]
2023-02-16T03:10:15.071Z root INFO Backend MessagingContribution.onStart: 3.2 ms [Finished 1.985 s after backend start]
2023-02-16T03:10:15.072Z root INFO Backend OSBackendApplicationContribution.configure: 0.7 ms [Finished 2.061 s after backend start]
2023-02-16T03:10:15.073Z root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 2.061 s after backend start]
2023-02-16T03:10:15.074Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 2.061 s after backend start]
2023-02-16T03:10:15.075Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 75.4 ms [Finished 2.062 s after backend start]
2023-02-16T03:10:15.075Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 2.062 s after backend start]
2023-02-16T03:10:15.077Z root INFO Backend ElectronTokenBackendContribution.configure: 1.3 ms [Finished 2.063 s after backend start]
2023-02-16T03:10:15.078Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 2.063 s after backend start]
2023-02-16T03:10:15.078Z root INFO Backend ConfigServiceImpl.onStart: 1.2 ms [Finished 2.064 s after backend start]
2023-02-16T03:10:15.080Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.6 ms [Finished 2.066 s after backend start]
2023-02-16T03:10:15.080Z root INFO Backend ArduinoDaemonImpl.onStart: 1.4 ms [Finished 2.067 s after backend start]
2023-02-16T03:10:15.080Z root INFO Backend NodeFileUploadService.configure: 2.6 ms [Finished 2.067 s after backend start]
2023-02-16T03:10:15.080Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/build/arduino-cli...
2023-02-16T03:10:15.080Z discovery-log INFO start
2023-02-16T03:10:15.081Z discovery-log INFO start new deferred
2023-02-16T03:10:15.081Z root INFO Backend HostedPluginLocalizationService.initialize: 0.7 ms [Finished 2.068 s after backend start]
2023-02-16T03:10:15.081Z root INFO Backend BoardDiscovery.onStart: 1.3 ms [Finished 2.069 s after backend start]
2023-02-16T03:10:15.081Z root INFO Backend FileDownloadEndpoint.configure: 1.0 ms [Finished 2.069 s after backend start]
2023-02-16T03:10:15.081Z root INFO Backend AuthenticationServiceImpl.onStart: 0.5 ms [Finished 2.071 s after backend start]
2023-02-16T03:10:15.081Z root INFO Backend PluginApiContribution.configure: 0.6 ms [Finished 2.071 s after backend start]
2023-02-16T03:10:15.084Z root INFO Backend HostedPluginReader.configure: 0.6 ms [Finished 2.072 s after backend start]
2023-02-16T03:10:15.084Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 2.073 s after backend start]
2023-02-16T03:10:15.084Z root INFO Backend PlotterBackendContribution.configure: 2.6 ms [Finished 2.076 s after backend start]
2023-02-16T03:10:15.088Z root INFO Theia app listening on http://localhost:59890.
2023-02-16T03:10:15.089Z root INFO Finished starting backend application: 7.9 ms [Finished 2.080 s after backend start]
2023-02-16T03:10:15.090Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoIDE/plugins does not exist.
2023-02-16T03:10:15.091Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoIDE/extensions does not exist.
2023-02-16T03:10:15.091Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoProIDE/plugins does not exist.
Restoring workspace roots: /Users/oscarjulian/Desktop/Electronica/Firmware/esp32/WIFI.ino
isTempSketch: false. Input was /Users/oscarjulian/Desktop/Electronica/Firmware/esp32/WIFI.ino
2023-02-16T03:10:15.136Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:10:15.136Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-02-16T03:10:15.136Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2023-02-16T03:10:15.136Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-02-16T03:10:15.136Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-02-16T03:10:15.137Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-02-16T03:10:15.137Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-02-16T03:10:15.138Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-02-16T03:10:15.138Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-02-16T03:10:15.139Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-02-16T03:10:15.139Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:10:15.139Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-02-16T03:10:15.139Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-02-16T03:10:15.139Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-02-16T03:10:15.139Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-02-16T03:10:15.163Z root INFO Resolve plugins list: 84.5 ms [Finished 2.154 s after backend start]
2023-02-16T03:10:15.172Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js": 8.1 ms [Finished 2.163 s after backend start]
2023-02-16T03:10:15.185Z daemon INFO INFO[0000] Using config file: /Users/oscarjulian/.arduinoIDE/arduino-cli.yaml
INFO[0000] arduino-cli version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"59891"}
2023-02-16T03:10:15.185Z daemon INFO Daemon is running.
2023-02-16T03:10:15.195Z root ERROR Uncaught Exception:
2023-02-16T03:10:15.195Z root ERROR Error: 14 UNAVAILABLE: No connection established
at Object.callErrorFromStatus (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/call.js:31:19)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/client.js:190:52)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/client-interceptors.js:365:141)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/client-interceptors.js:328:181)
at /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/call-stream.js:187:78
at processTicksAndRejections (node:internal/process/task_queues:78:11)
for call at
at ServiceClientImpl.makeUnaryRequest (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/client.js:160:30)
at ServiceClientImpl.create (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/make-client.js:105:19)
at instance (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/core-client-provider.js:143:20)
at new Promise (<anonymous>)
at CoreClientProvider.createClient (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/core-client-provider.js:142:32)
at CoreClientProvider.create (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/core-client-provider.js:82:35)
at /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/core-client-provider.js:46:52
at /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/core/lib/common/event.js:103:69
at CallbackList.invoke (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/core/lib/common/event.js:109:26)
at Emitter.fire (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/core/lib/common/event.js:224:29)
2023-02-16T03:10:15.201Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle": 28.7 ms [Finished 2.192 s after backend start]
2023-02-16T03:10:15.216Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-cpp/extension": 15.6 ms [Finished 2.208 s after backend start]
2023-02-16T03:10:15.219Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json/extension": 2.9 ms [Finished 2.210 s after backend start]
2023-02-16T03:10:15.221Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain": 1.3 ms [Finished 2.212 s after backend start]
2023-02-16T03:10:15.343Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-bg/extension": 122.3 ms [Finished 2.335 s after backend start]
2023-02-16T03:10:15.491Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-cs/extension": 148.2 ms [Finished 2.483 s after backend start]
2023-02-16T03:10:15.630Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-de/extension": 138.7 ms [Finished 2.622 s after backend start]
2023-02-16T03:10:15.756Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-es/extension": 126.1 ms [Finished 2.748 s after backend start]
2023-02-16T03:10:15.845Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-fr/extension": 88.1 ms [Finished 2.836 s after backend start]
2023-02-16T03:10:15.915Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-hu/extension": 70.1 ms [Finished 2.906 s after backend start]
2023-02-16T03:10:16.017Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-it/extension": 101.7 ms [Finished 3.008 s after backend start]
2023-02-16T03:10:16.105Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ja/extension": 88.8 ms [Finished 3.097 s after backend start]
2023-02-16T03:10:16.192Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ko/extension": 86.1 ms [Finished 3.183 s after backend start]
2023-02-16T03:10:16.229Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-nl/extension": 37.0 ms [Finished 3.220 s after backend start]
2023-02-16T03:10:16.309Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pl/extension": 80.6 ms [Finished 3.301 s after backend start]
2023-02-16T03:10:16.396Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pt-BR/extension": 87.0 ms [Finished 3.388 s after backend start]
2023-02-16T03:10:16.490Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ru/extension": 93.9 ms [Finished 3.482 s after backend start]
2023-02-16T03:10:16.576Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-tr/extension": 85.7 ms [Finished 3.567 s after backend start]
2023-02-16T03:10:16.636Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-uk/extension": 60.2 ms [Finished 3.628 s after backend start]
2023-02-16T03:10:16.727Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-zh-hans/extension": 84.4 ms [Finished 3.712 s after backend start]
2023-02-16T03:10:16.728Z root INFO Deploy plugins list: 84.5 ms [Finished 3.719 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-02-16T03:10:17.425Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 294.9 ms [Finished 2.218 s after frontend start]
2023-02-16T03:10:17.570Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 102.4 ms [Finished 2.358 s after frontend start]
Thanks. I see a problem here:
Unfortunately it doesn't give any indication of what caused the error. I'm going to ask you to post the logs produced by Arduino IDE when some additional debugging output is enabled. This information that might help us to identify the problem.
Please do this:
export GRPC_VERBOSITY=DEBUG
export GRPC_TRACE=all
) to your reply to make sure the error messages are correctly formatted.Please let me know if you have any questions or problems while following those instructions.
Last login: Wed Feb 15 22:09:27 on ttys000
You have new mail.
run "ng help".
localhost:~ oscarjulian$ clear
localhost:~ oscarjulian$ export GRPC_VERBOSITY=DEBUG
localhost:~ oscarjulian$ export GRPC_TRACE=all
D 2023-02-16T03:22:11.418Z | index | Loading @grpc/grpc-js version 1.6.8
Arduino IDE 2.0.3
Starting backend process. PID: 67921
D 2023-02-16T03:22:12.978Z | index | Loading @grpc/grpc-js version 1.6.8
2023-02-16T03:22:13.240Z root INFO Backend Object.initialize: 6.1 ms [Finished 1.644 s after backend start]
2023-02-16T03:22:13.240Z root INFO Backend Object.configure: 4.6 ms [Finished 1.644 s after backend start]
2023-02-16T03:22:13.240Z root INFO Backend MessagingContribution.onStart: 2.4 ms [Finished 1.644 s after backend start]
2023-02-16T03:22:13.241Z root INFO Backend OSBackendApplicationContribution.configure: 0.6 ms [Finished 1.692 s after backend start]
2023-02-16T03:22:13.242Z root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 1.692 s after backend start]
2023-02-16T03:22:13.244Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 1.692 s after backend start]
2023-02-16T03:22:13.245Z root INFO Backend PluginLocalizationBackendContribution.initialize: 47.9 ms [Finished 1.692 s after backend start]
2023-02-16T03:22:13.245Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 1.692 s after backend start]
2023-02-16T03:22:13.246Z root INFO Backend ElectronTokenBackendContribution.configure: 1.2 ms [Finished 1.694 s after backend start]
2023-02-16T03:22:13.247Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 1.694 s after backend start]
2023-02-16T03:22:13.247Z root INFO Backend ConfigServiceImpl.onStart: 1.1 ms [Finished 1.695 s after backend start]
2023-02-16T03:22:13.249Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.6 ms [Finished 1.696 s after backend start]
2023-02-16T03:22:13.249Z root INFO Backend ArduinoDaemonImpl.onStart: 1.3 ms [Finished 1.697 s after backend start]
2023-02-16T03:22:13.249Z root INFO Backend NodeFileUploadService.configure: 2.7 ms [Finished 1.698 s after backend start]
2023-02-16T03:22:13.249Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/build/arduino-cli...
2023-02-16T03:22:13.250Z discovery-log INFO start
2023-02-16T03:22:13.250Z discovery-log INFO start new deferred
2023-02-16T03:22:13.250Z root INFO Backend HostedPluginLocalizationService.initialize: 0.7 ms [Finished 1.699 s after backend start]
2023-02-16T03:22:13.250Z root INFO Backend BoardDiscovery.onStart: 1.2 ms [Finished 1.700 s after backend start]
2023-02-16T03:22:13.250Z root INFO Backend FileDownloadEndpoint.configure: 1.1 ms [Finished 1.700 s after backend start]
2023-02-16T03:22:13.251Z root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 1.702 s after backend start]
2023-02-16T03:22:13.251Z root INFO Backend PluginApiContribution.configure: 0.6 ms [Finished 1.702 s after backend start]
2023-02-16T03:22:13.252Z root INFO Backend HostedPluginReader.configure: 0.5 ms [Finished 1.703 s after backend start]
2023-02-16T03:22:13.252Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 1.703 s after backend start]
2023-02-16T03:22:13.252Z root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.704 s after backend start]
2023-02-16T03:22:13.256Z root INFO Theia app listening on http://localhost:60010.
2023-02-16T03:22:13.256Z root INFO Finished starting backend application: 6.0 ms [Finished 1.708 s after backend start]
2023-02-16T03:22:13.258Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoIDE/plugins does not exist.
2023-02-16T03:22:13.258Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoIDE/extensions does not exist.
2023-02-16T03:22:13.259Z root WARN The local plugin referenced by local-dir:/Users/oscarjulian/.arduinoProIDE/plugins does not exist.
2023-02-16T03:22:13.277Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:22:13.277Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-02-16T03:22:13.277Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2023-02-16T03:22:13.277Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-02-16T03:22:13.278Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-02-16T03:22:13.278Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-02-16T03:22:13.279Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-02-16T03:22:13.279Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-02-16T03:22:13.280Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-02-16T03:22:13.280Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-02-16T03:22:13.305Z root INFO Resolve plugins list: 56.9 ms [Finished 1.757 s after backend start]
2023-02-16T03:22:13.312Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js": 6.0 ms [Finished 1.764 s after backend start]
2023-02-16T03:22:13.326Z daemon INFO INFO[0000] Using config file: /Users/oscarjulian/.arduinoIDE/arduino-cli.yaml
{"IP":"127.0.0.1","Port":"60011"}
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.320Z | resolving_load_balancer | dns:localhost:60011 IDLE -> IDLE
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.320Z | connectivity_state | (1) dns:localhost:60011 IDLE -> IDLE
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.320Z | dns_resolver | Resolver constructed for target dns:localhost:60011
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.321Z | channel | (1) dns:localhost:60011 Channel constructed with options {
"grpc.max_send_message_length": 536870912,
"grpc.max_receive_message_length": 536870912,
"grpc.primary_user_agent": "arduino-ide/2.0.3"
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.321Z | channel_stacktrace | (1) Channel constructed
at new ChannelImplementation (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/channel.js:201:23)
at new Client (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/client.js:62:36)
at new ServiceClientImpl (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@grpc/grpc-js/build/src/make-client.js:58:5)
at CoreClientProvider.createClient (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/core-client-provider.js:141:24)
at ArduinoDaemonImpl.fireDaemonStarted (/Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/lib/node/arduino-daemon-impl.js:240:37)
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.322Z | channel | (1) dns:localhost:60011 createCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.324Z | call_stream | [0] Sending metadata
2023-02-16T03:22:13.327Z root ERROR D 2023-02-16T03:22:13.324Z | dns_resolver | Looking up DNS hostname localhost
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.325Z | resolving_load_balancer | dns:localhost:60011 IDLE -> CONNECTING
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.325Z | connectivity_state | (1) dns:localhost:60011 IDLE -> CONNECTING
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.325Z | channel | (1) dns:localhost:60011 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.326Z | call_stream | [0] write() called with message of length 0
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.326Z | call_stream | [0] end() called
2023-02-16T03:22:13.328Z daemon INFO Daemon is running.
2023-02-16T03:22:13.328Z root ERROR D 2023-02-16T03:22:13.328Z | call_stream | [0] deferring writing data chunk of length 5
2023-02-16T03:22:13.331Z root ERROR D 2023-02-16T03:22:13.329Z | dns_resolver | Resolved addresses for target dns:localhost:60011: [::1:60011]
2023-02-16T03:22:13.331Z root ERROR D 2023-02-16T03:22:13.330Z | pick_first | Connect to address list ::1:60011
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | subchannel | (2) ::1:60011 Subchannel constructed with options {
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | subchannel_refcount | (2) ::1:60011 refcount 0 -> 1
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | subchannel_refcount | (2) ::1:60011 refcount 1 -> 2
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | pick_first | Start connecting to subchannel with address ::1:60011
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | pick_first | IDLE -> CONNECTING
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | resolving_load_balancer | dns:localhost:60011 CONNECTING -> CONNECTING
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | channel | (1) dns:localhost:60011 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2023-02-16T03:22:13.332Z root ERROR D 2023-02-16T03:22:13.331Z | connectivity_state | (1) dns:localhost:60011 CONNECTING -> CONNECTING
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.332Z | subchannel | (2) ::1:60011 IDLE -> CONNECTING
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.333Z | pick_first | CONNECTING -> CONNECTING
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.333Z | resolving_load_balancer | dns:localhost:60011 CONNECTING -> CONNECTING
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.333Z | connectivity_state | (1) dns:localhost:60011 CONNECTING -> CONNECTING
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.333Z | channel | (1) dns:localhost:60011 Pick result for call [0]: QUEUE subchannel: null status: undefined undefined
2023-02-16T03:22:13.336Z root ERROR D 2023-02-16T03:22:13.333Z | channel | (1) dns:localhost:60011 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2023-02-16T03:22:13.337Z root ERROR D 2023-02-16T03:22:13.334Z | subchannel | (2) ::1:60011 creating HTTP/2 session
2023-02-16T03:22:13.341Z root ERROR D 2023-02-16T03:22:13.339Z | subchannel | (2) ::1:60011 connection closed with error connect ECONNREFUSED ::1:60011
2023-02-16T03:22:13.341Z root ERROR D 2023-02-16T03:22:13.339Z | subchannel | (2) ::1:60011 CONNECTING -> TRANSIENT_FAILURE
2023-02-16T03:22:13.341Z root ERROR D 2023-02-16T03:22:13.339Z | pick_first | CONNECTING -> TRANSIENT_FAILURE
2023-02-16T03:22:13.341Z root ERROR D 2023-02-16T03:22:13.339Z | resolving_load_balancer | dns:localhost:60011 CONNECTING -> TRANSIENT_FAILURE
2023-02-16T03:22:13.342Z root ERROR D 2023-02-16T03:22:13.339Z | channel | (1) dns:localhost:60011 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2023-02-16T03:22:13.342Z root ERROR D 2023-02-16T03:22:13.339Z | channel | (1) dns:localhost:60011 Pick result for call [0]: TRANSIENT_FAILURE subchannel: null status: 14 No connection established
2023-02-16T03:22:13.342Z root ERROR D 2023-02-16T03:22:13.339Z | call_stream | [0] cancelWithStatus code: 14 details: "No connection established"
2023-02-16T03:22:13.342Z root ERROR D 2023-02-16T03:22:13.340Z | call_stream | [0] ended with status: code=14 details="No connection established"
2023-02-16T03:22:13.342Z root ERROR D 2023-02-16T03:22:13.340Z | connectivity_state | (1) dns:localhost:60011 CONNECTING -> TRANSIENT_FAILURE
2023-02-16T03:22:13.343Z root ERROR Uncaught Exception:
2023-02-16T03:22:13.343Z root ERROR Error: 14 UNAVAILABLE: No connection established
for call at
2023-02-16T03:22:13.346Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle": 34.9 ms [Finished 1.799 s after backend start]
2023-02-16T03:22:13.357Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-cpp/extension": 11.0 ms [Finished 1.810 s after backend start]
2023-02-16T03:22:13.360Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json/extension": 2.0 ms [Finished 1.812 s after backend start]
2023-02-16T03:22:13.361Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain": 1.1 ms [Finished 1.813 s after backend start]
2023-02-16T03:22:13.456Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-bg/extension": 95.4 ms [Finished 1.909 s after backend start]
2023-02-16T03:22:13.526Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-cs/extension": 70.0 ms [Finished 1.979 s after backend start]
2023-02-16T03:22:13.628Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-de/extension": 102.1 ms [Finished 2.081 s after backend start]
2023-02-16T03:22:13.720Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-es/extension": 91.5 ms [Finished 2.172 s after backend start]
2023-02-16T03:22:13.778Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-fr/extension": 57.6 ms [Finished 2.230 s after backend start]
2023-02-16T03:22:13.816Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-hu/extension": 37.9 ms [Finished 2.268 s after backend start]
2023-02-16T03:22:13.865Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-it/extension": 49.3 ms [Finished 2.318 s after backend start]
2023-02-16T03:22:13.923Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ja/extension": 57.8 ms [Finished 2.376 s after backend start]
2023-02-16T03:22:13.970Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ko/extension": 46.9 ms [Finished 2.423 s after backend start]
2023-02-16T03:22:13.993Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-nl/extension": 22.8 ms [Finished 2.445 s after backend start]
2023-02-16T03:22:14.042Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pl/extension": 48.9 ms [Finished 2.494 s after backend start]
2023-02-16T03:22:14.124Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pt-BR/extension": 81.8 ms [Finished 2.576 s after backend start]
2023-02-16T03:22:14.187Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ru/extension": 62.9 ms [Finished 2.639 s after backend start]
2023-02-16T03:22:14.234Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-tr/extension": 47.5 ms [Finished 2.687 s after backend start]
2023-02-16T03:22:14.273Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-uk/extension": 38.9 ms [Finished 2.726 s after backend start]
2023-02-16T03:22:14.330Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-zh-hans/extension": 44.6 ms [Finished 2.771 s after backend start]
2023-02-16T03:22:14.330Z root INFO Deploy plugins list: 56.9 ms [Finished 2.782 s after backend start]
2023-02-16T03:22:14.330Z root ERROR D 2023-02-16T03:22:14.330Z | resolving_load_balancer | dns:localhost:60011 TRANSIENT_FAILURE -> TRANSIENT_FAILURE
2023-02-16T03:22:14.330Z root ERROR D 2023-02-16T03:22:14.330Z | connectivity_state | (1) dns:localhost:60011 TRANSIENT_FAILURE -> TRANSIENT_FAILURE
2023-02-16T03:22:14.332Z root ERROR D 2023-02-16T03:22:14.332Z | subchannel | (2) ::1:60011 TRANSIENT_FAILURE -> IDLE
2023-02-16T03:22:14.332Z root ERROR D 2023-02-16T03:22:14.332Z | subchannel_refcount | (2) ::1:60011 refcount 2 -> 1
2023-02-16T03:22:14.332Z root ERROR D 2023-02-16T03:22:14.332Z | pick_first | TRANSIENT_FAILURE -> IDLE
2023-02-16T03:22:14.333Z root ERROR D 2023-02-16T03:22:14.332Z | resolving_load_balancer | dns:localhost:60011 TRANSIENT_FAILURE -> IDLE
2023-02-16T03:22:14.333Z root ERROR D 2023-02-16T03:22:14.332Z | connectivity_state | (1) dns:localhost:60011 TRANSIENT_FAILURE -> IDLE
2023-02-16T03:22:15.677Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 343.2 ms [Finished 2.228 s after frontend start]
2023-02-16T03:22:15.775Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 119.5 ms [Finished 2.392 s after frontend start]
Unfortunately I still didn't get a clue from that.
Arduino IDE communicates with some of its helper tools via an internal TCP/IP port in your computer on "localhost". This communication is failing somehow. These failures are usually found to be caused by "external" interference or misconfiguration. By "external", I mean that it is something separate from the Arduino IDE application, its helper tools, or their configuration. Examples would be your antivirus software, firewall, network configuration including the use of a proxy or VPN.
Is there anything notable about your system that might be relevant?
I understand, can i change the localhost by 127.0.0.1?
I resolved my problem, thank you.
You are welcome. I'm glad it is working now.
Regards,
Per
