My Setup
- MacOS
- Board: Arduino Uno
- Arduino IDE Version : 1.8.10
Hello everyone,
I am fairly new to C++ compiling processes and I am trying to run a project but Arduino can not compile it. I get an error saying that the arduino builder can't find library cstdarg.
I am a bit suprised I could not find a clear answer about this since it seems quite simple. I must be missing something.
Minimum Working Example
mwe.ino
#include <cstdarg>
Detailed response (Arduino IDE verbose mode)
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/arnauda/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10810 -build-path /var/folders/lx/t7n0s66x22g_f__4nlwghmzr0000gn/T/arduino_build_932281 -warnings=none -build-cache /var/folders/lx/t7n0s66x22g_f__4nlwghmzr0000gn/T/arduino_cache_932193 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/arnauda/Documents/Arduino/sketch_nov20a/sketch_nov20a.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/arnauda/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10810 -build-path /var/folders/lx/t7n0s66x22g_f__4nlwghmzr0000gn/T/arduino_build_932281 -warnings=none -build-cache /var/folders/lx/t7n0s66x22g_f__4nlwghmzr0000gn/T/arduino_cache_932193 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/arnauda/Documents/Arduino/sketch_nov20a/sketch_nov20a.ino
Using board 'uno' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/lx/t7n0s66x22g_f__4nlwghmzr0000gn/T/arduino_build_932281/sketch/sketch_nov20a.ino.cpp -o /dev/null
Alternatives for cstdarg: []
sketch_nov20a:1:10: error: cstdarg: No such file or directory
ResolveLibrary(cstdarg)
#include <cstdarg>
-> candidates: []
compilation terminated.
exit status 1
However, I see that this library is present in several locations on my computer:
- /usr/include/c++/4.2.1/tr1/cstdarg
- /usr/include/c++/4.2.1/cstdarg
- /usr/local/Cellar/gcc/9.1.0/include/c++/9.1.0/tr1/cstdarg
- /usr/local/Cellar/gcc/9.1.0/include/c++/9.1.0/cstdarg
- /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/c++/4.2.1/tr1/cstdarg
- /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/c++/4.2.1/cstdarg
My questions
- What compiler is Arduino using?
- How can I add a path to the locations the compiler is looking for the libraries?
- Can anyone explain the steps in the logs a bit more in details or provide me a resource about these commands?
Thanks a lot for your time !
