Error in Arduino IDE
Hello, Im making an esp32cam with pir sensor that automatically captures when a motion is detected, but im blocked with this error
"A fatal error occurred: Packet content transfer stopped (received 8 bytes) Failed uploading: uploading error: exit status 2"
it stops right after this prompt
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Configuring flash size...
Erasing flash (this may take a while)...
It is recommended to post the entire verbose log in code tags. I don't recognize some of what you typed, use copy/paste.
Did you do the BOOT pin procedure?
Did you make sure there were no other copies of the IDE or Serial monitor running?
Sometimes I have to try a few times.
#define FILE_PHOTO "/data/photo.jpg"
RTC_DATA_ATTR int bootCount = 0;
// OV2640 camera module pins (CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
const int PIN_TO_SENSOR = 14;   // the pin that OUTPUT pin of sensor is connected
int pinStateCurrent   = LOW; // current state of pin
int pinStatePrevious  = LOW; // previous state of pin
boolean takeNewPhoto = true;
// Define Firebase Data objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig configF;
bool taskCompleted = false;
unsigned long lastMotionTime = 0;  // Store the time of the last motion event
const long MOTION_DETECTION_DELAY = 5000;  // 5 seconds delay before detecting motion again
// Check if photo capture was successful
bool checkPhoto(fs::FS &fs) {
  File f_pic = fs.open(FILE_PHOTO);
  unsigned int pic_sz = f_pic.size();
  return (pic_sz > 100);
// Declare function prototype for capturePhotoSaveSpiffs
void capturePhotoSaveSpiffs(void);  // Add this line
// Capture Photo and Save it to SPIFFS
void capturePhotoSaveSpiffs(void) {
  camera_fb_t *fb = NULL; // pointer
  bool ok = 0; // Boolean indicating if the picture has been taken correctly
  static int counter = 0; // To keep track of photo number
  char filename[13]; // To store the generated filename
  // Check if there's enough space in SPIFFS before saving
  if (SPIFFS.totalBytes() - SPIFFS.usedBytes() > 1024) {
    // Generate filename with the photo number
    if (counter >= 999) {
      counter = 0;  // Reset the counter after 999 photos
    sprintf(filename, "photo%03d.jpg", counter++);  // Increment counter and create a new filename
    Serial.println("Taking a photo...");
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      return;
    // Photo file name
    Serial.printf("Picture file name: %s\n", filename);
    // Save the photo to SPIFFS
    File file = SPIFFS.open("/" + String(filename), FILE_WRITE);
    if (!file) {
      Serial.println("Failed to open file in writing mode");
      return;
      file.write(fb->buf, fb->len); // payload (image), payload length
      Serial.print("The picture has been saved in ");
      Serial.print(filename);
      Serial.print(" - Size: ");
      Serial.print(file.size());
      Serial.println(" bytes");
    // Close the file
    file.close();
    esp_camera_fb_return(fb);
    // Check if file has been correctly saved in SPIFFS
    ok = checkPhoto(SPIFFS);
    Serial.println("SPIFFS is full!");
    return;
void initWiFi() {
  WiFi.begin(ssid, password);
  unsigned long startMillis = millis();
    Serial.print(".");
    if (millis() - startMillis > 30000) {  // Timeout after 30 seconds
      Serial.println("WiFi connection timed out!");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("Connected to WiFi!");
void initSPIFFS() {
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    ESP.restart();
    Serial.println("SPIFFS mounted successfully");
void initCamera() {
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  pinMode(PIN_TO_SENSOR, INPUT); // set arduino pin to input mode to read value from OUTPUT pin of sensor
  initWiFi();
  initSPIFFS();
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  initCamera();
  // Firebase
  configF.api_key = API_KEY;
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  configF.token_status_callback = tokenStatusCallback;
  Firebase.begin(&configF, &auth);
  Firebase.reconnectWiFi(true);
  pinStatePrevious = pinStateCurrent; // store old state
  pinStateCurrent = digitalRead(PIN_TO_SENSOR);   // read new state
  // Check if motion is detected and debounce it
  if (pinStatePrevious == LOW && pinStateCurrent == HIGH && (currentMillis - lastMotionTime) > MOTION_DETECTION_DELAY) {
    Serial.println("Motion detected!");
    takePic();
    lastMotionTime = currentMillis; // Update last motion time
  } else if (pinStatePrevious == HIGH && pinStateCurrent == LOW) {   // motion stopped
    Serial.println("Motion stopped!");
void takePic() {
  if (takeNewPhoto) {
    capturePhotoSaveSpiffs();
    delay(2000);
    if (Firebase.ready() && !taskCompleted) {
      taskCompleted = true;
      Serial.print("Uploading picture... ");
      if (Firebase.Storage.upload(&fbdo, STORAGE_BUCKET_ID, FILE_PHOTO, mem_storage_type_flash, FILE_PHOTO, "image/jpeg")) {
        Serial.printf("\nDownload URL: %s\n", fbdo.downloadURL().c_str());
        Serial.println(fbdo.errorReason());
  return;
I took a sourcee code from someone in the forums as well, but added a few tweaks (ddebounce for the motion seensor)
hello, i have fixed my problem, i unplugged thee PIR sensor whilee uploading but then this problem now happens
02:42:19.965 -> Picture file name: photo019.jpg
02:42:20.045 -> The picture has been saved in photo019.jpg - Size: 0 bytes
02:42:22.108 -> Uploading picture... file not found
this problem is i think focused to the firebase
Hi @jshu7.
Great news! Thanks for taking the time to post an update with your findings.
Since it is unrelated to the original subject of this topic, please open a new forum topic for that question. This will ensure it gets the attention of the forum helpers knowledgeable about the subject of your new question.
