Error in asm
Hello, im trying to write a program in which some led strips lighten up depending on the value that 2 potentiometers send. Im using the fastLed library and im getting this error all the time.
"\servidor01\usuarios\esalamancam\Documents\Arduino\libraries\fastled/clockless_trinket.h:313: error: impossible constraint in 'asm'"
.Even when I ctrl+F and try to substitute all the "asm" for a blank space, it doesnt compile.
this is my sketch, can i have a bit of help?
#include "FastLED.h"
#define NUM_STRIPS 26
#define NUM_LEDS_PER_STRIP1 3
#define NUM_LEDS_PER_STRIP2 1
CRGB leds[NUM_LEDS_PER_STRIP1];
int pot1=analogRead(A0);
int pot2=analogRead(A1);
if (pot1>0,pot1<84){
FastLED.addLeds<NEOPIXEL, 10>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 12>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 14>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>85,pot1<169){
FastLED.addLeds<NEOPIXEL, 11>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 13>(leds, NUM_LEDS_PER_STRIP2);
FastLED.addLeds<NEOPIXEL, 15>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>170,pot1<254){
FastLED.addLeds<NEOPIXEL, 16>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>255,pot1<339){
FastLED.addLeds<NEOPIXEL, 17>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>340,pot1<424){
FastLED.addLeds<NEOPIXEL, 18>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>425,pot1<509){
FastLED.addLeds<NEOPIXEL, 19>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>510,pot1<594){
FastLED.addLeds<NEOPIXEL, 20>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>595,pot1<679){
FastLED.addLeds<NEOPIXEL, 21>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>680,pot1<764){
FastLED.addLeds<NEOPIXEL, 22>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>765,pot1<849){
FastLED.addLeds<NEOPIXEL, 23>(leds, NUM_LEDS_PER_STRIP1);
if (pot1>850,pot1<934){
FastLED.addLeds<NEOPIXEL, 24>(leds, NUM_LEDS_PER_STRIP1);
} if (pot1>935,pot1<1023){
FastLED.addLeds<NEOPIXEL, 25>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 32>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,33>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 26>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,28>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,29>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,30>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,31>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,34>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,35>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL, 27>(leds, NUM_LEDS_PER_STRIP1);
FastLED.addLeds<NEOPIXEL,32>(leds, NUM_LEDS_PER_STRIP1);
Whatever else might be wrong the lines line this
if (pot1>85,pot1<169){are almost certainly not doing what you think they are. I assume that you are trying to check for a range of values. If so you need an and (&&) in there instead of the comma.
Wow... On my copy of 1.6.4 it hangs the compiler! I just downloaded the latest FastLED library and it still hangs the compiler. The 'RGBCalibrate' example that comes with FastLED compiles just fine.
Mac OS X 10.10.3
Arduino 1.6.4
FastLED from December 24th, 2014: GitHub - FastLED/FastLED: The FastLED library for colored LED animation on Arduino. Please direct questions/requests for help to the FastLED Reddit community: http://fastled.io/r We'd like to use github "issues" just for tracking library bugs / enhancements.
Target: Arduino UNO
  int pot1 = analogRead(A0);
  int pot2 = analogRead(A1);
  if (pot1 > 0 && pot1 < 84) {
    FastLED.addLeds<NEOPIXEL, 10>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 12>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 14>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 85 && pot1 < 169) {
    FastLED.addLeds<NEOPIXEL, 11>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 13>(leds && NUM_LEDS_PER_STRIP2);
    FastLED.addLeds<NEOPIXEL, 15>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 170 && pot1 < 254) {
    FastLED.addLeds<NEOPIXEL, 16>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 255 && pot1 < 339) {
    FastLED.addLeds<NEOPIXEL, 17>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 340 && pot1 < 424) {
    FastLED.addLeds<NEOPIXEL, 18>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 425 && pot1 < 509) {
    FastLED.addLeds<NEOPIXEL, 19>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 510 && pot1 < 594) {
    FastLED.addLeds<NEOPIXEL, 20>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 595 && pot1 < 679) {
    FastLED.addLeds<NEOPIXEL, 21>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 680 && pot1 < 764) {
    FastLED.addLeds<NEOPIXEL, 22>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 765 && pot1 < 849) {
    FastLED.addLeds<NEOPIXEL, 23>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 850 && pot1 < 934) {
    FastLED.addLeds<NEOPIXEL, 24>(leds && NUM_LEDS_PER_STRIP1);
  if (pot1 > 935 && pot1 < 1023) {
    FastLED.addLeds<NEOPIXEL, 25>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 32>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 33>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 26>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 28>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 29>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 30>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 31>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 34>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 35>(leds && NUM_LEDS_PER_STRIP1);
    FastLED.addLeds<NEOPIXEL, 27>(leds && NUM_LEDS_PER_STRIP1);
there are values missing in your if ladder e.g if pot1 == 255
better do it this way
  if (pot1<84)
  } else if (pot1<169){
  } esle if (pot1 < ....
etc
all values are mapped and the number of comparisons is minimized.
