Error in code, not sure how to fix it
Hi I'm currently having an error with my programme and I'm not sure how to fix it properly so I thought I'd ask here to see. The project consists of a ESP8266, SIM 808 DRFBOT Arduino shield, LM35 and a LCD display
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\Owner\Documents\Arduino\libraries\WiFiEsp\src/WiFiEsp.h:30:0,
                 from C:\Users\Owner\Documents\Arduino\Dog_Tracker_Code\Dog_Tracker_Code.ino:14:
C:\Users\Owner\Documents\Arduino\libraries\WiFiEsp\src/utility/EspDrv.h:103:16: error: redeclaration of 'CLOSED'
  CLOSED      = 0,
In file included from C:\Users\Owner\Documents\Arduino\Dog_Tracker_Code\Dog_Tracker_Code.ino:5:0:
C:\Users\Owner\Documents\Arduino\libraries\DFRobot_SIM808-master/DFRobot_sim808.h:41:5: note: previous declaration 'Protocol CLOSED'
     CLOSED = 0,
C:\Users\Owner\Documents\Arduino\Dog_Tracker_Code\Dog_Tracker_Code.ino: In function 'void setup()':
C:\Users\Owner\Documents\Arduino\Dog_Tracker_Code\Dog_Tracker_Code.ino:56:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     sim808.sendSMS(PHONE_NUMBER, MESSAGE);
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
My code:
#include <DFRobot_sim808.h>
// My Mobile number to send SMS
#define PHONE_NUMBER ""
// Message warning
#define MESSAGE ""
DFRobot_SIM808 sim808(&Serial);
#include<LiquidCrystal.h>  //Header file for LCD Module
#include "WiFiEsp.h" // Library for ESP8266
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
char ssid[] = "";            // Network Name
char pass[] = "Network password goes here";        // Network Password
int status = WL_IDLE_STATUS;     // Wifi radio's status
int reqCount = 0;                // number of requests received
WiFiEspServer server(80);
LiquidCrystal lcd(12, 10, 5, 4, 3, 2); //lcd connected pins
const int sensor = A0;    //Assigning analog A0 to LM35
float tempc;              //Storing temp in °C
float tempf;              //Storing temp in °F
float vout;               //variable to store values from sensor
  // initialize serial for debugging
  // initialize serial for ESP module
  Serial1.begin(9600);
  // initialize ESP module
  WiFi.init(&Serial1);
  lcd.begin(16, 2);
  lcd.print("DOG TRACKER\nDEVICE");
  pinMode(A0, INPUT);
    while (!sim808.init()) {
      Serial.print("Sim808 init error\r\n");
    Serial.println("Sim808 init success");
    Serial.println("Start to send message ...");
    // phone number and SMS
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  // start the web server on port 80
  server.begin();
  printWifiStatus();
void loop(){
  vout=analogRead(sensor);
  vout=(vout*500)/1023;
  tempc=vout;             // Storing value in °C
  tempf=(vout*1.8)+32;    //conversion of °C to °F
  lcd.setCursor(0,0);
  Serial.println(tempc);
  if(tempc>=35) // Using a max of 35°C as an alert temperature for the LM35
    lcd.print("HIGH TEMP!!     ");
    lcd.setCursor(0,1);
    lcd.print("C=");
    lcd.print(tempc);
    lcd.print(" F=");
    lcd.print(tempf);
    lcd.print("Temp is within range");
    lcd.setCursor(0,1);
    lcd.print("C=");
    lcd.print(tempc);
    lcd.print(" F=");
    lcd.print(tempf);
    digitalWrite(9,0);
void printWifiStatus()
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in the browser
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
You could try using a Const char rather than #define.
Try reversing the order of the include files that are causing the redeclaration error - that sometimes resolves simple cases where there is no check.
Did you do a search on the forum for 'redeclaration'?
The following recent topic is one of the results, and the guidance in it may be of assistance: Arduino Forum
Looks like two different libraries are using the name "CLOSED". I think the only choice is to change one of the libraries to use a different name.
  CLOSED      = 0,
     CLOSED = 0,
