error in com
HI
i see this error in uploading my program to arduino,however i used the same one with the windows befor
         Using Port                    : COM20
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM20": The system cannot find the file specified.
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
maybe whatever you did prior to this blew out your Arduino
can't say for sure
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port or use a USB 2.0 hub plugged into your USB 3.0 port.
