Error in compilation but only on new Arduino Uno R4
Here is my code
const byte BCD[10][4]={
  {0,0,0,0}, //Digit 0
  {0,0,0,1}, //Digit 1
  {0,0,1,0}, //Digit 2
  {0,0,1,1}, //Digit 3
  {0,1,0,0}, //Digit 4
  {0,1,0,1}, //Digit 5
  {0,1,1,0}, //Digit 6
  {0,1,1,1}, //Digit 7
  {1,0,0,0}, //Digit 8
  {1,0,0,1}  //Digit 9
byte Segments[10][7]={
  {1,1,1,1,1,1,0}, //Digit 0
  {0,1,1,0,0,0,0}, //Digit 1
  {1,1,0,1,1,0,1}, //Digit 2
  {1,1,1,1,0,0,1}, //Digit 3
  {0,1,1,0,0,1,1}, //Digit 4
  {1,0,1,1,0,1,1}, //Digit 5
  {1,0,1,1,1,1,1}, //Digit 6
  {1,1,1,0,0,0,0}, //Digit 7
  {1,1,1,1,1,1,1}, //Digit 8
  {1,1,1,1,0,1,1}  //Digit 9
#define dip_1 13
#define dip_2 A0
#define dip_3 A1
#define dip_4 A2
#define led_1  12
#define led_2  11
#define led_3  10
#define led_4  9
#define led_5  8
#define led_6  7
#define led_7  6
  pinMode(dip_1, INPUT_PULLUP);
  pinMode(dip_2, INPUT_PULLUP);
  pinMode(dip_3, INPUT_PULLUP);
  pinMode(dip_4, INPUT_PULLUP);
  pinMode(led_1, OUTPUT);
  pinMode(led_2, OUTPUT);
  pinMode(led_3, OUTPUT);
  pinMode(led_4, OUTPUT);
  pinMode(led_5, OUTPUT);
  pinMode(led_6, OUTPUT);
  pinMode(led_7, OUTPUT);
void displayDigit(int d) {
  digitalWrite(led_1,Segments[d][0]);
  digitalWrite(led_2,Segments[d][1]);
  digitalWrite(led_3,Segments[d][2]);
  digitalWrite(led_4,Segments[d][3]);
  digitalWrite(led_5,Segments[d][4]);
  digitalWrite(led_6,Segments[d][5]);
  digitalWrite(led_7,Segments[d][6]);
  int D4, D3, D2, D1;
  D4=digitalRead(dip_4);
  D3=digitalRead(dip_3);
  D2=digitalRead(dip_2);
  D1=digitalRead(dip_1);
  for (int i =0 ; i < 10; i++){
    if ( D4==BCD[i][3] and D3==BCD[i][2] and
         D2==BCD[i][1] and D1==BCD[i][0])
    displayDigit(i);
It compiles fine fro Arduino Nano. When I compile this simple code on Arduino Uno R4WIFI in the line
I get error
exit status 1
lvalue required as left operand of assignment
Any clues?
If you look in the pins_arduino.h file for the Uno R4 Wifi you will find your answer:
static const uint8_t D0 = PIN_D0;
static const uint8_t D1 = PIN_D1;
static const uint8_t D2 = PIN_D2;
static const uint8_t D3 = PIN_D3;
static const uint8_t D4 = PIN_D4;
Change your variables from D1, D2, D3, D4 to d1, d2, d3, d4 and your problem should go away.
I should have guessed that:)
Thank you.
You might want to think about marking the topic complete so that others don't try and solve something that's already done.
