Error in DHT22 Arduino Code
I am using DHT22 sensor in Arduino UNO board. When i run the code, I am getting an error. From the error, I am not able to understand. I have attached the error below. Kindly assist me where I am wrong.
Error :
Flashing with command:C:/Users/k.b.soundarapandian/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/k.b.soundarapandian/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:/Users/KB7155~1.SOU/AppData/Local/Temp/arduino-create-agent297713070/sketch_apr4a.hex:i
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.
Mine DHT22 is working fine with SimpleDHT.h Library + UNO + IDE Example. Please, post your full codes with code tags so that we can see what library and what program you are using.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Have you tried to load your UNO with the Blink example in the IDE to see if its is a hardware rather than a software fault?
Thanks.. Tom.. :slight_smile:
