hi everyone,
i'm using the parola library to display SMS to a dot matrix display. but whenever i'm sending an SMS like "hey" to the arduino, the only thing being display is a multiple of HHHHHH. i can't figure out how to fix this and what i did wrong.
Please refer to the attachment for the error receive.
Thanks a lot.
// Use the Parola library to scroll text on the display
// Demonstrates the use of the scrolling function to display text received
// from the serial interface
// User can enter text on the serial monitor and this will display as a
// scrolling message on the display.
// Speed for the display is controlled by a pot on SPEED_IN analog in.
// Scrolling direction is controlled by a switch on DIRECTION_SET digital in.
// Invert ON/OFF is set by a switch on INVERT_SET digital in.
// Keyswitch library can be found at http://arduinocode.codeplex.com
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <GSM.h>
GSM gsmAccess;
GSM_SMS sms;
#define PINNUMBER ""
char senderNumber[20];
// set to 1 if we are implementing the user interface pot, switch, etc
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#include <MD_KeySwitch.h>
#endif
// Turn on debug statements to the serial output
#define DEBUG 1
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// HARDWARE SPI
MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#define PAUSE_TIME 1000
#define SPEED_DEADBAND 5
// Scrolling parameters
#if USE_UI_CONTROL
#define SPEED_IN A5
#define DIRECTION_SET 8 // change the effect
#define INVERT_SET 9 // change the invert
#endif // USE_UI_CONTROL
uint8_t frameDelay = 25; // default frame delay value
textEffect_t scrollEffect = SCROLL_LEFT;
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE];
char newMessage[BUF_SIZE];
bool newMessageAvailable = false;
#if USE_UI_CONTROL
MD_KeySwitch uiDirection(DIRECTION_SET);
MD_KeySwitch uiInvert(INVERT_SET);
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 10, 150);
if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
(speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
P.setSpeed(speed);
P.setPause(speed);
frameDelay = speed;
PRINT("\nChanged speed to ", P.getSpeed());
if (uiDirection.read()) // SCROLL DIRECTION
PRINTS("\nChanging scroll direction");
scrollEffect = (scrollEffect == SCROLL_LEFT ? SCROLL_RIGHT : SCROLL_LEFT);
P.setTextEffect(scrollEffect, scrollEffect);
P.displayReset();
if (uiInvert.read()) // INVERT MODE
PRINTS("\nChanging invert mode");
P.setInvert(!P.getInvert());
void readsms(void)
static uint8_t putIndex = 0;
while (sms.available())
newMessage[putIndex] = (char)sms.read();
if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-2)) // end of message character or full buffer
// put in a message separator and end the string
newMessage[putIndex] = '\0';
// restart the index for next filling spree and flag we have a message waiting
sms.flush();
putIndex = 0;
newMessageAvailable = true;
// Just save the next char in next location
newMessage[putIndex++];
#if USE_UI_CONTROL
uiDirection.begin();
uiInvert.begin();
pinMode(SPEED_IN, INPUT);
doUI();
P.begin();
P.displayClear();
P.displaySuspend(false);
P.displayScroll(curMessage, LEFT, scrollEffect, frameDelay);
strcpy(curMessage, "Hello! Enter new message?");
newMessage[0] = '\0';
Serial.print("\n[Parola Scrolling Display]\nType a message for the scrolling display\nEnd message line with a newline");
// connection state
boolean notConnected = true;
// Start GSM connection
while (notConnected)
if (gsmAccess.begin(PINNUMBER) == GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("\n GSM initialized \n");
Serial.println("\n Waiting for messages \n");
#if USE_UI_CONTROL
doUI();
readsms();
if (P.displayAnimate())
if (newMessageAvailable)
strcpy(curMessage, newMessage);
Serial.print(curMessage);
P.displayReset();
