ERROR In function 'void loop()':
Hi i am having the following errors when trying to compile my script.
Arduino: 1.6.5 (Windows 8.1), Board: “Arduino/Genuino Uno”
Weather_Station_Snow_Maker.ino: In function ‘void dht22()’:
Weather_Station_Snow_Maker:58: error: expected primary-expression before ‘.’ token
Weather_Station_Snow_Maker:63: error: expected primary-expression before ‘.’ token
Weather_Station_Snow_Maker:68: error: expected primary-expression before ‘.’ token
Weather_Station_Snow_Maker.ino: In function ‘void loop()’:
Weather_Station_Snow_Maker:88: error: expected primary-expression before ‘.’ token
Weather_Station_Snow_Maker:89: error: expected primary-expression before ‘.’ token
PLEASE HELP
const int critical = -3; //critcal plant freezing temp in degree C
const int ledblue = 10;
const int ledgreen = 12;
float wetbulb = 0;
#include <DHT.h>
#include <LiquidCrystal.h>
#define LUMIN 11          // the number of the PWM output pin
#define BUTTON 10         // the number of the pushbutton pin
#define DHT22_PIN 2 // what digital pin we're connected to
int  val = 0;           // variable for reading the pushbutton status
int counter = 0;
byte temp[8] =             //icon for thermometer
  B00100,
  B01011,
  B01010,
  B01111,
  B01110,
  B11111,
  B11111,
  B01110
byte drop[8] =             //icon for water droplet
  B00100,
  B00100,
  B01110,
  B01110,
  B11111,
  B11111,
  B11111,
  B01110,
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
#include "Wire.h"
#include <dht.h>
#define DS3232_I2C_ADDRESS 0x68
#define DHT22_PIN 3
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val / 16 * 10) + (val % 16) );
void dht22()
  // READ DATA
  int chk = DHT.read22(DHT22_PIN);
  // DISPLAY DATA
  lcd.setCursor(0, 1);         // Position the LCD cursor (col 0, row 1)
  lcd.write(1);            // Print the new character labeled 1
  lcd.print(" ");
  lcd.print(DHT.temperature, 1);       // Print a message to the lcd.
  lcd.print((char)223);
  lcd.print("C");
  lcd.write(2);            // Print the new character labeled 2
  lcd.print(" ");
  lcd.print(DHT.humidity, 1);
  lcd.print("%");
  Serial.println("DHT22 test!");
  pinMode(ledgreen, OUTPUT);
  pinMode (ledblue, OUTPUT);
  lcd.createChar(1, temp);       // create a new character labeled 1
  lcd.createChar(2, drop);      // create a new character labeled 2
  lcd.begin(16, 2);         // set up the LCD's number of columns and rows
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = DHT.readHumidity();
  float t = DHT.readTemperature();
  wetbulb = (t * atan(.151977 * pow(h + 8.313659, 0.5))) + atan(t + h) - atan(h - 1.676331) + (.391838 * pow(h, 2 / 3)) * atan(.023101 * h) - 4.686035;
  if (wetbulb <= critical) {
    digitalWrite (ledgreen, HIGH);
  }  //wetbulb below critical trips led
  if (wetbulb >= critical) {
    digitalWrite (ledblue, HIGH);
    digitalWrite (ledblue, LOW);
  if (wetbulb >= critical + 3) {
    digitalWrite (ledgreen, LOW);
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(" ");
    Serial.print(t);
    Serial.println(" *C");
    Serial.print(" ");
    Serial.print("Wetbulb");
    Serial.print(" ");
    Serial.print(wetbulb);
    Serial.print("*C");
    Serial.print(" ");
    Serial.print("Freeze");
    Serial.print(" ");
    Serial.print(critical);
    Serial.print("*C");
    Serial.print(" ");
    lcd.setCursor (0, 0);
    lcd.print("Wetbulb");
    lcd.print(" ");
    lcd.print(wetbulb);
    lcd.print((char)223); // Prints degrees symbol
    lcd.print("C");
    dht22();
    delay (2000);
Weather_Station_Snow_Maker.ino (3.37 KB)
That backwards slash is likely to cause problems.
DuaneDegn: }   if (wetbulb >= critical + 3) {     digitalWrite (ledblue, LOW);   }\
i just removed that backwards slash still the same errors as before but thats for pointing that out to me. it makes it look a lot more cleaner.
.151977
Can't do that. You gotta have the zero in front of it.
0.151977
From this line:
You haven't instantiated DHT. It is complaining about your use of DHT.read22 etc.
Pete
  B00100,
  B00100,
  B01110,
  B01110,
  B11111,
  B11111,
  B11111,
  B01110,
I’m betting the last comma isn’t supposed to be there.
el_supremo: You haven't instantiated DHT. It is complaining about your use of DHT.read22 etc.
Pete
thanks pete that might be it but how do i do that
#define DHT22_PIN 3
DHT dht(DHT22_PIN, DHT22);
Pete P.S. .151977 is valid. You don't have to have a leading zero.
thanks pete tried that it still did not change any of the errors. all the same errors still exist
Did you see reply #3? Those need to be fixed.
Delta_G: Did you see reply #3? Those need to be fixed.
no they dont need to be fixed there is nothing wrong with them. they were working before i stated writing in the the new temp and humidity code
Ooops. the dht needs to be upper case:
DHT DHT(DHT22_PIN, DHT22);
and two other problems. When you get temperature and humidity from the DHT22 you need to use readTemperature() and readHumidity(). And I don't know what you intended with DHT.read22 but there's no such function in DHT22. Change the dht22 function to this:
void dht22()
  // DISPLAY DATA
  lcd.print(" ");
  lcd.print(DHT.readTemperature(), 1);       // Print a message to the lcd.
  lcd.print("C");
  lcd.print(" ");
  lcd.print(DHT.readHumidity(), 1);
  lcd.print("%");
Pete
