Error in Get/Put
I’m using a SIM900 module to connect to GPRS and I hace verified that the GPRS works! fine.
but I’m getting following errors while I execute the HTTP request code block in my Arduino sketch:
AT+CSQ
+CSQ: 31,0
OK
AT+CGATT?
+CGATT: 0
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","www"
OK
AT+SAPBR=1,1
OK
AT+HTTPPARA="URL","http://winacro.com/script.php?value=
Gagan
AT+HTTPACTION=1
ERROR
And, the code is as follows:
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and
  send a http request to the website, upload data to pachube.com by TCP connection,
  The microcontrollers Digital Pin 7 and hence allow unhindered
  communication with GPRS Shield using SoftSerial Library.
  IDE: Arduino 1.0 or later
  Replace the following items in the code:
  1.Phone number, don't forget add the country code
  2.Replace the Access Point Name
  3. Replace the Pachube API Key with your personal ones assigned
  to your account at cosm.com
#include <NewSoftSerial.h>
#include <String.h>
NewSoftSerial mySerial(2, 3);
  mySerial.begin(19200);               // the GPRS baud rate
  //after start up the program, you can using terminal to connect the serial of gprs shield,
  //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
  //if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
  if (Serial.available())
    switch(Serial.read())
     case 't':
       SendTextMessage();
     case 'd':
       DialVoiceCall();
     case 'h':
       SubmitHttpRequest();
     case 's':
       Send2Pachube();
  if (mySerial.available())
    Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
  mySerial.print("AT+CMGF=1\r");    //Because we want to send the SMS in text mode
  delay(100);
  mySerial.println("AT + CMGS = \"7503331543\"");//send sms message, be careful need to add a country code before the cellphone number
  delay(100);
  mySerial.println("A test message!");//the content of the message
  delay(100);
  mySerial.println();
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
  mySerial.println("ATD + +917503331543;");//dial the number
  delay(100);
  mySerial.println();
///SubmitHttpRequest()
///this function is submit a http request
///attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest()
  mySerial.println("AT+CSQ");
  delay(100);
  ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
  mySerial.println("AT+CGATT?");
  delay(100);
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"APN\",\"www\"");//setting the APN, the second need you fill in your local apn server
  delay(4000);
  ShowSerialData();
  mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+HTTPINIT"); //init the HTTP request
  delay(2000);
  ShowSerialData();
  String value = "Gagan";
  mySerial.println("AT+HTTPPARA=\"URL\",\"http://winacro.com/script.php?value=");// setting the httppara, the second parameter is the website you want to access
  mySerial.println(value);
  ShowSerialData();
  mySerial.println("AT+HTTPACTION=1");//submit the request
  delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
  //while(!mySerial.available());
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
  delay(100);
  ShowSerialData();
  mySerial.println("AT+CSTT=\"CMNET\"");//start task and setting the APN,
  ShowSerialData();
  mySerial.println("AT+CIICR");//bring up wireless connection
  delay(300);
  ShowSerialData();
  mySerial.println("AT+CIFSR");//get local IP adress
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+CIPSPRT=0");
  delay(3000);
  ShowSerialData();
  mySerial.println("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"");//start up the connection
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+CIPSEND");//begin send data to remote server
  delay(4000);
  ShowSerialData();
  String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
  String moisture = "1242";//you can replace these four variable to the real sensor data in your project
  String temperature = "30";//
  String barometer = "60.56";//
  mySerial.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube
  ShowSerialData();
  mySerial.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey
  ShowSerialData();
  mySerial.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey
  ShowSerialData();
  mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey
  ShowSerialData();
  mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":");
  ShowSerialData();
  mySerial.print(" {\"version\": \"1.0.0\",\"datastreams\": ");
  ShowSerialData();
  mySerial.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}");
  ShowSerialData();
  mySerial.println((char)26);//sending
  delay(5000);//waitting for reply, important! the time is base on the condition of internet
  mySerial.println();
  ShowSerialData();
  mySerial.println("AT+CIPCLOSE");//close the connection
  delay(100);
  ShowSerialData();
void ShowSerialData()
  while(mySerial.available()!=0)
Any idea’s anything I’m getting wrong? according to me I think I’m not able to make the HTTP request in the right manner and do not know how to make it correctly.
It probably does not like the CR/LF in the request, and no double quote. I would try this:
  mySerial.print("AT+HTTPPARA=\"URL\",\"http://winacro.com/script.php?value=");
  mySerial.print(value);
  mySerial.println("\"");
I have not tested it. I’m not sure if it needs a blank line like an ethernet request.
Hi Tim,
With this code in place as according to what you suggested:
 mySerial.print("AT+HTTPPARA=\"URL\",\"http://winacro.com/script.php?value='sheesha'");
  //mySerial.print('+value+');
AND Successfully! the stuff is loaded.
