error in interfacing led with the message recieved in the 433mhz reciver.
#include <VirtualWire.h>
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
int LED= 13;
  Serial.println("Receiver is ready");
  // Initialize the IO and ISR
  vw_setup(2000); // Bits per sec
  vw_rx_start(); // Start the receiver
  pinMode(LED,OUTPUT);
  if (vw_get_message(message, &messageLength)) // Non-blocking
    Serial.print("Received: ");
    for (int i = 0; i < messageLength; i++)
      Serial.write(message[i]);
  if(Serial.println(obstacle absent));
  digitalWrite(LED,HIGH);
else()
  digitalWrite(LED,LOW);
  delay(200);
Here is my error
virtualwire_reciever:32: error: 'obstacle' was not declared in this scope
exit status 1
I have connected transmitter and receiver. The transmitter is connected with ir sensors and detect whether there is obstacle or not.
I want to light up led in the receiver when it receive 'obstacle absent' as a message
:o :o didn't you forget the quotes ("text") in   if(Serial.println(obstacle absent));
Regarding vw_get_message(message, &messageLength), read the documentation closely
uint8_t vw_get_message	(uint8_t * 	buf,uint8_t * len)
If a message is available (good checksum or not), copies up to *len octets to buf.
Parameters
[in]	buf	Pointer to location to save the read data (must be at least *len bytes.
[[color=blue]in[/color], [color=red] out[/color]]	len	[color=blue]Available space in buf[/color]. [color=red]Will be set to the actual number of octets read[/color]
You need to ensure that messageLength is reset to the full length of the buffer before calling that again otherwise you will send whatever was there before and may be it will be super short...
NO DOUBLE POST PLEASE
int LED= 13;
  if (uint8_t vw_get_message   (uint8_t *    buf,uint8_t * len)) // Non-blocking
  if(Serial.println("obstacle absent"))
if((Serial.println("obstaclepresent"))
{  digitalWrite(LED,LOW);
  delay(200);
exit status 1
expected '=' before ')' token
sorry for double post. It was done by mistake . I am newbie to Arduino. I want to light up led in the receiver when it receive 'obstacle absent' as a message . If there is any more error please make them correct. Thanks in advance.
if (uint8_t vw_get_message  (uint8_t *    buf,uint8_tYou appear to have crashed a function prototype into your "if"
