I get the error "File does not name a type" when I compile the example program "ReadWrite" in SDFat folder. Yet, when I compile the sketch "QuickStart" from the same source (SDFat examples), I DON'T get the error. In the latter the command is File file;
So...what's going on? I didn't change these at all, they are read-only examples. FYI, I had no errors with Arduino 1.8.15, the latest, but my Teensy didn't recognize anything more than version 1.8.13. So I un-installed 1.8.15 and installed 1.8.13. Teensy works but now File does not.
Here are the files:
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
//#include <SD.h>
#include "SdFat.h"
SdFat SD;
#define SD_CS_PIN SS
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
and
// Quick hardware test for SPI card access.
#include <SPI.h>
#include "SdFat.h"
#include "sdios.h"
// SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
// 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
// Set DISABLE_CHIP_SELECT to disable a second SPI device.
// For example, with the Ethernet shield, set DISABLE_CHIP_SELECT
// to 10 to disable the Ethernet controller.
const int8_t DISABLE_CHIP_SELECT = -1;
// Test with reduced SPI speed for breadboards. SD_SCK_MHZ(4) will select
// the highest speed supported by the board that is not over 4 MHz.
// Change SPI_SPEED to SD_SCK_MHZ(50) for best performance.
#define SPI_SPEED SD_SCK_MHZ(4)
#if SD_FAT_TYPE == 0
SdFat sd;
File file;
#elif SD_FAT_TYPE == 1
SdFat32 sd;
File32 file;
#elif SD_FAT_TYPE == 2
SdExFat sd;
ExFile file;
#elif SD_FAT_TYPE == 3
SdFs sd;
FsFile file;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
// Serial streams
ArduinoOutStream cout(Serial);
// input buffer for line
char cinBuf[40];
ArduinoInStream cin(Serial, cinBuf, sizeof(cinBuf));
// SD card chip select
int chipSelect;
void cardOrSpeed() {
cout << F("Try another SD card or reduce the SPI bus speed.\n");
cout << F("Edit SPI_SPEED in this program to change it.\n");
void clearSerialInput() {
uint32_t m = micros();
do {
if (Serial.read() >= 0) {
m = micros();
} while (micros() - m < 10000);
void reformatMsg() {
cout << F("Try reformatting the card. For best results use\n");
cout << F("the SdFormatter program in SdFat/examples or download\n");
cout << F("and use SDFormatter from www.sdcard.org/downloads.\n");
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
cout << F("\nSPI pins:\n");
cout << F("MISO: ") << int(MISO) << endl;
cout << F("MOSI: ") << int(MOSI) << endl;
cout << F("SCK: ") << int(SCK) << endl;
cout << F("SS: ") << int(SS) << endl;
#ifdef SDCARD_SS_PIN
cout << F("SDCARD_SS_PIN: ") << int(SDCARD_SS_PIN) << endl;
#endif // SDCARD_SS_PIN
if (DISABLE_CHIP_SELECT < 0) {
cout << F(
"\nBe sure to edit DISABLE_CHIP_SELECT if you have\n"
"a second SPI device. For example, with the Ethernet\n"
"shield, DISABLE_CHIP_SELECT should be set to 10\n"
"to disable the Ethernet controller.\n");
cout << F(
"\nSD chip select is the key hardware option.\n"
"Common values are:\n"
"Arduino Ethernet shield, pin 4\n"
"Sparkfun SD shield, pin 8\n"
"Adafruit SD shields and modules, pin 10\n");
bool firstTry = true;
// Read any existing Serial data.
clearSerialInput();
if (!firstTry) {
cout << F("\nRestarting\n");
firstTry = false;
cout << F("\nEnter the chip select pin number: ");
while (!Serial.available()) {
SysCall::yield();
cin.readline();
if (cin >> chipSelect) {
cout << chipSelect << endl;
cout << F("\nInvalid pin number\n");
return;
cout << F(
"\nAssuming the SD is the only SPI device.\n"
"Edit DISABLE_CHIP_SELECT to disable another device.\n");
cout << F("\nDisabling SPI device on pin ");
cout << int(DISABLE_CHIP_SELECT) << endl;
pinMode(DISABLE_CHIP_SELECT, OUTPUT);
digitalWrite(DISABLE_CHIP_SELECT, HIGH);
if (!sd.begin(chipSelect, SPI_SPEED)) {
if (sd.card()->errorCode()) {
cout << F(
"\nSD initialization failed.\n"
"Do not reformat the card!\n"
"Is the card correctly inserted?\n"
"Is chipSelect set to the correct value?\n"
"Does another SPI device need to be disabled?\n"
"Is there a wiring/soldering problem?\n");
cout << F("\nerrorCode: ") << hex << showbase;
cout << int(sd.card()->errorCode());
cout << F(", errorData: ") << int(sd.card()->errorData());
cout << dec << noshowbase << endl;
return;
cout << F("\nCard successfully initialized.\n");
if (sd.vol()->fatType() == 0) {
cout << F("Can't find a valid FAT16/FAT32 partition.\n");
reformatMsg();
return;
cout << F("Can't determine error type\n");
return;
cout << endl;
uint32_t size = sd.card()->sectorCount();
if (size == 0) {
cout << F("Can't determine the card size.\n");
cardOrSpeed();
return;
uint32_t sizeMB = 0.000512 * size + 0.5;
cout << F("Card size: ") << sizeMB;
cout << F(" MB (MB = 1,000,000 bytes)\n");
cout << endl;
cout << F("Volume is FAT") << int(sd.vol()->fatType());
cout << F(", Cluster size (bytes): ") << sd.vol()->bytesPerCluster();
cout << endl << endl;
cout << F("Files found (date time size name):\n");
sd.ls(LS_R | LS_DATE | LS_SIZE);
if ((sizeMB > 1100 && sd.vol()->sectorsPerCluster() < 64)
|| (sizeMB < 2200 && sd.vol()->fatType() == 32)) {
cout << F("\nThis card should be reformatted for best performance.\n");
cout << F("Use a cluster size of 32 KB for cards larger than 1 GB.\n");
cout << F("Only cards larger than 2 GB should be formatted FAT32.\n");
reformatMsg();
return;
// Read any extra Serial data.
clearSerialInput();
cout << F("\nSuccess! Type any character to restart.\n");
SysCall::yield();
