Error in PID based Line Follower code: "stray '\342' in program"
I am making a a PID based line follower.
I have attached the .ino file below so that you can compile it yourself and view the error messages.
I am getting the following error message -
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
PID:52: error: stray '\342' in program
proportional = (pos – 100); //randomly chosen set point
PID:52: error: stray '\200' in program
PID:52: error: stray '\223' in program
C:\Users\user\Desktop\PID\PID.ino: In function 'void setMotors()':
PID:38: error: 'en1' was not declared in this scope
analogWrite(en1,mod(l));
PID:38: error: 'l' was not declared in this scope
PID:38: error: 'mod' was not declared in this scope
PID:39: error: 'en2' was not declared in this scope
analogWrite(en2, mod(r));
PID:39: error: 'r' was not declared in this scope
PID:40: error: 'L1' was not declared in this scope
digitalWrite(L1, HIGH);
PID:41: error: 'L2' was not declared in this scope
digitalWrite(L2, LOW);
PID:42: error: 'r1' was not declared in this scope
digitalWrite(r1, HIGH);
PID:43: error: 'r2' was not declared in this scope
digitalWrite(r2, LOW);
C:\Users\user\Desktop\PID\PID.ino: In function 'void loop()':
PID:49: error: 'position' was not declared in this scope
position = readline();
PID:49: error: 'readline' was not declared in this scope
PID:52: error: expected ')' before numeric constant
PID:53: error: 'derivative' was not declared in this scope
derivative = proportional - last_proportional;
PID:53: error: 'last_proportional' was not declared in this scope
PID:60: error: 'powerDif' was not declared in this scope
powerDif = proportional * Kp + integral * Ki + derivative *Kd;
PID:73: error: 'power_difference' was not declared in this scope
if(power_difference < 0)
exit status 1
option enabled in File -> Preferences.
For this code -
int rmf = 3;
int rmb = 5;
int lmf = 6;
int lmb = 9;
int a[4];
int pos = 0;
int sensorSum = 0;
int derivitative = 0;
int integral = 0;
int proportional = 0;
int Kp;
int Kd;
int Ki;
Serial.begin (9600);
void sense(){
  for (int i = 0; i<5; i++)
    a[i] = analogRead(i);
    sensorSum += a[i];
  Serial.print(sensorSum);
  pos = (-2000*a[0] + -1000*a[1] + 0*a[2] + 1000*a[3] + 2000*a[4])/(a[1] + a[2] + a[3] + a[4]);
  Serial.print (pos);
void setMotors (){
 sense();
 Serial.println("position = ");
 Serial.println(pos);
 proportional = ((int)pos – 100); //randomly chosen set point
 integral = integral+proportional;
 last_proportional = proportional;
 Kp = 0.08;
 Ki = 0.0002;
 Kd = 1.0;
 const int max = 180;
 if(powerDif>max)
  powerDif = max;
 if(powerDif < -max)
  powerDif = (-1*max);
  setMotors(max+powerDif, max);
  setMotors(max, max-powerDif);
What changes should I make in my code ?
PID.ino (1.34 KB)
This happens sometimes when copy-and-pasting stuff from the web. The content shows up as white space, but i's not actually spaces and tabs and the compiler doesn't know what to make of them.
To fix, copy and paste all your code into Notepad or another editor which will display those stray characters, and replace them with ordinary spaces.
Paste your code in the reply box on this forum.
Next select it all and copy.
Next paste back in your sketch, completely overwriting what is current there.
That should do the trick. You do not have to post the reply.
