I have got a problem in program from git.hub, i downloaded the code and then this error start show up, i dont know where is the problem, Please help!
git.hub project: GitHub - illuminateddan/Laser-X-Hacks: A hack of the Laser X, laser tag system
code:
- LASER X Land Mine Code
- Designed for use with the Laser X "laser" (infrared) shooting game.
- This code requires a PIR, an IR receiver, an IR LED (or multiple with a transistor), an RGB led,
- and probably batteries and a project box etc, etc
- Game Play:
- A player shoots the circuit, arming the mine for their team. A brief countdown begins and then the circuit fires
- multiple "shots" (the teams IR code - The unit fires back the activating IR signal).
- Red team kills blue,
- blue team kills red
- Renegade kills everyone including itself
#define redPin 11
#define greenPin 10
#define bluePin 9
#define PIRPin 12
#define ledPin 13
#include <IRremote.h>
int RECV_PIN = 2;
IRsend irsend;////An IR LED must be connected to Arduino PWM pin 3.
IRrecv irrecv(RECV_PIN);
decode_results results;
int codeType = -1; // The type of code
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
// IR codes for Laser X units
unsigned int teamA[] = {6050, 650, 400, 600, 1450, 600, 450, 600, 1450, 600, 450, 600, 400, 600, 1400, 650, 450};
unsigned int teamB[] = {6150, 550, 450, 600, 1450, 600, 400, 650, 1450, 550, 450, 600, 450, 550, 450, 600, 1400};
unsigned int renegade[] = {6100, 600, 450, 550, 1450, 600, 450, 600, 1450, 600, 450, 550, 400, 650, 1450, 600, 1500};
// 33EBDD7B - 871095675 A
// A3F34992 - 2750630290 B
// 33EBDD7A - 871095674 Renegade
int attackState = 0; // (0 everyone, 1 reds own, 2 blues own)
int attackTimes = 5;
bool active = 0;
long timer = 0;
int duration = 10000;
Serial.println("Hello! Laser X Mine!");
irrecv.enableIRIn(); // Start the receiver
pinMode(ledPin, OUTPUT);
pinMode(PIRPin, INPUT);
digitalWrite(ledPin, HIGH);
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
delay(3000);
digitalWrite(3, LOW);
digitalWrite(ledPin, LOW);
setLEDFlash(255, 0, 0, 1, 100);
setLEDFlash(0, 255, 0, 1, 100);
setLEDFlash(0, 0, 255, 1, 100);
} // setup ------------------------------------------------------------
bool PIRState = digitalRead(PIRPin);
digitalWrite(ledPin, PIRState);
Serial.print("Active:"); Serial.print(active);
Serial.print(" attackState:"); Serial.print(attackState);
Serial.print(" PIR:"); Serial.println(PIRState);
if (active) {
Serial.print("Active so...");
if (PIRState) {
Serial.print("Movement Detected: Attack ");
switch (attackState) {
case 0:
sendRenegade(attackTimes);
active = 0;
attackState = 0;
irrecv.enableIRIn(); // Re-enable receiver
case 1:
sendTeamA(attackTimes);
active = 0;
attackState = 0;
case 2:
sendTeamB(attackTimes);
active = 0;
attackState = 0;
} // PIR state
} // if PIR
} // active
if (!active) {
if (irrecv.decode(&results)) {
Serial.println("results in...");
storeCode(&results);
// irrecv.resume(); // resume receiver
//Serial.println(results.value, HEX);
Serial.print(results.value);
Serial.print(" - ");
irrecv.resume(); // resume receiver NOTE: NEEDS TIME TO DO OTHER STUFF BEFORE PROCESSING IR OR YOU GET BAD CODES
switch (results.value) {
case 871095675:
Serial.println("Red Team Hit");
setLEDFlash(255, 0, 0, 5, 500);
setLEDFlash(255, 0, 0, 5, 200);
setLEDFlash(255, 0, 0, 5, 100);
setLED(255, 0, 0);
attackState = 1;
active = 1;
case 2750630290:
Serial.println("Blue Team Hit");
setLEDFlash(0, 0, 255, 5, 500);
setLEDFlash(0, 0, 255, 5, 200);
setLEDFlash(0, 0, 255, 5, 100);
setLED(0, 0, 255);
attackState = 2;
active = 1;
case 871095674:
Serial.println("Renegade Hit");
setLEDFlash(255, 0, 255, 5, 500);
setLEDFlash(255, 0, 255, 5, 200);
setLEDFlash(255, 0, 255, 5, 100);
setLED(255, 0, 255);
attackState = 0;
active = 1;
default :
Serial.println("Not recognised ");
setLEDFlash(0, 255, 0, 10, 200);
setLED(0, 255, 0);
attackState = 0;
active = 0;
}// switch
} // if receive
} //not active
} // loop ------------------------------------------------------------
void storeCode(decode_results * results) {
codeType = results->decode_type;
int count = results->rawlen;
if (codeType == UNKNOWN) {
//Serial.println("Received unknown code, saving as raw");
codeLen = results->rawlen - 1;
// To store raw codes:
// Drop first value (gap)
// Convert from ticks to microseconds
// Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
for (int i = 1; i <= codeLen; i++) {
if (i % 2) {
// Mark
rawCodes[i - 1] = results->rawbuf * USECPERTICK - MARK_EXCESS;
- //Serial.print(" m");*
- } else { // i%2*
- // Space*
rawCodes[i - 1] = results->rawbuf * USECPERTICK + MARK_EXCESS;
* //Serial.print(" s");*
* //Serial.print(rawCodes[i - 1], DEC);*
* //Serial.println("");*
* } // if codetype unknown*
void sendCode() { // used to bounce back the IR code
_ if (codeType == UNKNOWN /* i.e. raw /) {_
_ irsend.sendRaw(rawCodes, codeLen, 38); // Assume 38 KHz*_
* Serial.println("Sent raw");*
} // void
void sendTeamA(int _times) {
* for (int i = 0; i < times; i++) {
_ setLED(255, 255, 255);*
* irsend.sendRaw(teamA, sizeof(teamA) / sizeof(teamA[0]), 38); // Assume 38 KHz*
* Serial.println("Sent Team A Fire Code");*
* delay(1000);*
* setLED(0, 0, 0);*
* delay(500);*
void sendTeamB(int _times) {
* irsend.sendRaw(teamB, sizeof(teamB) / sizeof(teamB[0]), 38); // Assume 38 KHz*
* Serial.println("Sent Team B Fire Code");*
* delay(1000);*
* setLED(0, 0, 0);*
* delay(500);*
void sendRenegade(int _times) {
* irsend.sendRaw(renegade, sizeof(renegade) / sizeof(renegade[0]), 38); // Assume 38 KHz*
* Serial.println("Sent Renegade Fire Code");*
* delay(1000);*
* setLED(0, 0, 0);*
* delay(500);*
void setLED(int _r, int _g, int _b) {
* analogWrite(redPin, _r);
analogWrite(greenPin, _g);
analogWrite(bluePin, b);
_}*
void setLEDFlash(int _r, int _g, int _b, int _times, int _delay) {
* for (int i = 0; i < _times; i++) {
analogWrite(bluePin, _b);
delay(delay);
_ analogWrite(redPin, 0);*
* analogWrite(greenPin, 0);*
* analogWrite(bluePin, 0);*
* delay(delay);
_ }*
