Hello, I am trying to use a code that says that depending on which values 2 potentiometers send, there are different led strips that lighten up, and im having an error that is like this
“could not convert template argument ‘APA102’ to ‘EClocklessChipsets’”
so i think the problem obviously is in the part of the code in which i use “APA102”, but i dont know what the problem is. The code is actually pretty long but it is simple, there are a lot of variables that mean the same but it is written like this in order to be easy to explain to people that dont know what the code is about (a clock made out of words), so i am using 2 potentiometers (1 for the hours, the other for minutes) because depending on the hour of the clock there are going to be other elements (servos and leds) working, (so if i only read the hour from the PC, we wouldnt be able to see what would happen if it was 9 AM if i am showing my proyect at 10 PM, for example)
I cant post the code because the maximum is 9000 characters, but here is the part where i think the error is:
FastLED.addLeds<NEOPIXEL, ES>(ledsES, ESLEDS);
FastLED.addLeds(ledsES, ESLEDS);
FastLED.addLeds<NEOPIXEL, LA>(ledsLA, LALEDS);
FastLED.addLeds(ledsLA, LALEDS);
FastLED.addLeds<NEOPIXEL, S>(ledsS, SLEDS);
FastLED.addLeds(ledsS, SLEDS);
FastLED.addLeds<NEOPIXEL, SON>(ledsSON, SONLEDS);
FastLED.addLeds(ledsSON, SONLEDS);
FastLED.addLeds<NEOPIXEL, UNA>(ledsUNA, UNALEDS);
FastLED.addLeds(ledsUNA, UNALEDS);
FastLED.addLeds<NEOPIXEL, DOS>(ledsDOS, DOSLEDS);
FastLED.addLeds(ledsDOS, DOSLEDS);
FastLED.addLeds<NEOPIXEL, TRES>(ledsTRES, TRESLEDS);
FastLED.addLeds(ledsTRES, TRESLEDS);
FastLED.addLeds<NEOPIXEL, CUATRO>(ledsCUATRO, CUATROLEDS);
FastLED.addLeds(ledsCUATRO, CUATROLEDS);
FastLED.addLeds<NEOPIXEL, CINCOH>(ledsCINCOH, CINCOHLEDS);
FastLED.addLeds(ledsCINCOH, CINCOHLEDS);
FastLED.addLeds<NEOPIXEL, SEIS>(ledsSEIS, SEISLEDS);
FastLED.addLeds(ledsSEIS, SEISLEDS);
FastLED.addLeds<NEOPIXEL, SIETE>(ledsSIETE, SIETELEDS);
FastLED.addLeds(ledsSIETE, SIETELEDS);
FastLED.addLeds<NEOPIXEL, OCHO>(ledsOCHO, OCHOLEDS);
FastLED.addLeds(ledsOCHO, OCHOLEDS);
FastLED.addLeds<NEOPIXEL, NUEVE>(ledsNUEVE, NUEVELEDS);
FastLED.addLeds(ledsNUEVE, NUEVELEDS);
FastLED.addLeds<NEOPIXEL, DIEZH>(ledsDIEZH, DIEZHLEDS);
FastLED.addLeds(ledsDIEZH, DIEZHLEDS);
FastLED.addLeds<NEOPIXEL, ONCE>(ledsONCE, ONCELEDS);
FastLED.addLeds(ledsONCE, ONCELEDS);
FastLED.addLeds<NEOPIXEL, DOCE>(ledsDOCE, DOCELEDS);
FastLED.addLeds(ledsDOCE, DOCELEDS);
FastLED.addLeds<NEOPIXEL, Y>(ledsY, YLEDS);
FastLED.addLeds(ledsY, YLEDS);
FastLED.addLeds<NEOPIXEL, MENOS>(ledsMENOS, MENOSLEDS);
FastLED.addLeds(ledsMENOS, MENOSLEDS);
FastLED.addLeds<NEOPIXEL, ENPUNTO>(ledsENPUNTO, ENPUNTOLEDS);
FastLED.addLeds(ledsENPUNTO, ENPUNTOLEDS);
FastLED.addLeds<NEOPIXEL, MEDIA>(ledsMEDIA, MEDIALEDS);
FastLED.addLeds(ledsMEDIA, MEDIALEDS);
FastLED.addLeds<NEOPIXEL, CINCOM>(ledsCINCOM, CINCOMLEDS);
FastLED.addLeds(ledsCINCOM, CINCOMLEDS);
FastLED.addLeds<NEOPIXEL, DIEZM>(ledsDIEZM, DIEZMLEDS);
FastLED.addLeds(ledsDIEZM, DIEZMLEDS);
FastLED.addLeds<NEOPIXEL, CUARTO>(ledsCUARTO, CUARTOLEDS);
FastLED.addLeds(ledsCUARTO, CUARTOLEDS);
FastLED.addLeds<NEOPIXEL, VEINTE>(ledsVEINTE, VEINTELEDS);
FastLED.addLeds(ledsVEINTE, VEINTELEDS);
FastLED.addLeds<NEOPIXEL, VEINTICINCO>(ledsVEINTICINCO, VEINTICINCOLEDS);
FastLED.addLeds(ledsVEINTICINCO, VEINTICINCOLEDS);
FastLED.addLeds<NEOPIXEL, ARDUINO>(ledsARDUINO, ARDUINOLEDS);
FastLED.addLeds(ledsARDUINO, ARDUINOLEDS);
Also, i need to know if there is a way to only clear the leds that are attached to one of the 2 potentiometers with a function like FastLED.clear, because if i use that, when the minutes change, the hours would clear and the clock would only show the minutes.
