#include <TinyGPS.h>
#include <NewSoftSerial.h>
unsigned long fix_age;
NewSoftSerial GPS(2,3);
TinyGPS gps;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
void setup(){
GPS.begin(9600);
void loop(){
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
// retrieves +/- lat/long in 100000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
// time in hh:mm:ss, date in dd/mm/yy
/*gps.get_datetime(&date, &time, &fix_age);
year = date % 100;
month = (date / 100) % 100;
day = date / 10000;
hour = time / 1000000;
minute = (time / 10000) % 100;
second = (time / 100) % 100;
Serial.print("Date: ");
Serial.print(year); Serial.print("/");
Serial.print(month); Serial.print("/");
Serial.print(day);
Serial.print(" :: Time: ");
Serial.print(hour); Serial.print(":");
Serial.print(minute); Serial.print(":");
Serial.println(second);
getGPS();
Serial.print("Latitude : ");
Serial.print(LAT/100000,7);
Serial.print(" :: Longitude : ");
Serial.println(LON/100000,7);
void getGPS(){
bool newdata = false;
unsigned long start = millis();
// Every 1 seconds we print an update
while (millis() - start < 1000)
if (feedgps ()){
newdata = true;
if (newdata)
gpsdump(gps);
bool feedgps(){
while (GPS.available())
if (gps.encode(GPS.read()))
return true;
return 0;
//byte month, day, hour, minute, second, hundredths;
gps.get_position(&lat, &lon);
LAT = lat;
LON = lon;
feedgps(); // If we don't feed the gps during this long
//routine, we may drop characters and get checksum errors
error:expected'}' at the end of input.
In file included from sketch_mar10a.cpp:2:
C:\Intel\Downloads\arduino-1.0\libraries\NewSoftSerial/NewSoftSerial.h:33:2: error: #error NewSoftSerial has been moved into the Arduino core as of version 1.0. Use SoftwareSerial instead.
C:\Intel\Downloads\arduino-1.0\libraries\NewSoftSerial/NewSoftSerial.h:99: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\Intel\Downloads\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
In file included from sketch_mar09a.ino:2:
C:\Intel\Downloads\arduino-1.0.3\libraries\NewSoftSerial/NewSoftSerial.h:33:2: error: #error NewSoftSerial has been moved into the Arduino core as of version 1.0. Use SoftwareSerial instead.
C:\Intel\Downloads\arduino-1.0.3\libraries\NewSoftSerial/NewSoftSerial.h:99: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\Intel\Downloads\arduino-1.0.3\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
TinyGPS gps;
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
void setup(){
GPS.begin(9600);
//Serial.begin(115200);
void loop(){
long lat, lon;
// Retrieves +/- latitude/longitude in 100000ths of a degree.
getGPS();
void getGPS(){
// Every 1 seconds we print an update.
if (feedgps ()){
newdata = true;
if (newdata)
gpsdump(gps);
bool feedgps(){
return true;
return 0;
LAT = lat;
LON = lon;
{feedgps(); // If we don't feed the GPS during this long
//checksum errors.
A man goes to the doctor and says "I have a headache" Doctor says take 2 of these you'll be fine
Man says "Doctor I don't want no pills... Just Fix My Headache. NOW
My suggestion would be to just copy the serial data, which the gps device is sending to the arduino, to the serial monitor, without trying to parse it using the tinygps or anything else.
Then you will know, if your device and your serial communication is working. Then you can start worrying about processing the data.
The GPS will only work outside or if you have a really big window.
It's a good thing that the Iranian rocket program is run by smart people like you.
