Error in programming
I'm using arduino uno r3 on programming on arduinodroid I compiled the program and while trying to upload I got this ''ERROR: PROCESS RETURNED NOT ZERO RESULT CODE:139
I'm trying to upload again but it failed
I reseted Arduino but it failed
I even tried to program it with a computer but it didn't work
I was only able to upload it once
** **Please help** **
I suspect that this is more a question for an arduinoDroid forum. Does one exist?
Have you got an Arduino program that you cannot upload to and Arduino board ?
If not then this is not a question about programming an Arduino
Please, post your codes.
See if there's a hardware problem, does it load and run BLINK from your PC?
Otherwise, here's a page that took less than a minute to find:
Other problems
Please make sure you've tried everything from checklist above and report me about the problems on email using "menu / Help / Report issue". Confirm attaching android log with ArduinoDroid debug output which helps to understand what's going on. Log file will be compressed (small file size), no private data will be sent.
Everything includes steps that might not seem to be THE step you want.
